#295 | |
Drives: Harrop TVS86 STi BRZ tS
#296 |
Snow Don't Hurt!
Glad I came in here. My brake squeals have been atrocious on my Brembos. I replaced the pads and added some lubrication to the shims. I got new rotors for the front since that's where most of the squeals are coming from and the rotors look pitted. Since I have new rotors I'll swap them anyways and also apply the anti-squeal stuff you guys recommended. Thanks!
Sent from my SAMSUNG-SM-G925A using Tapatalk
#297 |
Snow Don't Hurt!
Also I had an STI previously and never had it this bad until I went to Hawk pads. I have Akebono pads right now because they're supposed to be quieter than stock, although I wasn't using stock pads anyways.
#298 | |
#299 | |
When you picked up the brembo said did you get a set of stock pads or just the calipers? Sent from my iPhone using Tapatalk
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#300 | |
Just the calipers. Sent from my iPhone using Tapatalk
#301 |
The pads come with additional shims which to my knowledge are there for sound. Those shims should be transferred over when the pads are changed. Unfortunately Subaru will not sell the shims separately; have to buy the pads. If you look at the drawing for an STi, the shims I'm talking about have an angled cut to them. Sent from my iPhone using Tapatalk
@dsomegax.cars
#302 | |
Yeah those shims are rather elusive. I've wondered if they would solve the problem. The hawk pads supposedly have anti squeal shim built in but clearly they aren't working in my case. I assume you're using the shims and are squeal free? Sent from my iPhone using Tapatalk
#303 | |
BoostedBRZ
Drives: Turbo BRZ
#304 | |
Are you using stoptech rotors and pads? Just rotors? Just pads?
#305 |
BoostedBRZ
Drives: Turbo BRZ
Nice! DBA rotors are sick, I've always wanted to get them... and Right now I'm just running the stop tech high performance street pads. And then some basic centric standard rotors. both from rockauto.com since the prices are usually the cheapest. I'm on the edge about buying expensive rotors because they'll just get trashed on the track...
#306 | |
#307 |
BoostedBRZ
Drives: Turbo BRZ
"I recently lubed every contact point in my calipers/pads and they stopped squealing for a while but it came back."
doh! I just missed this. Now it makes sense, I can bet that what's actually causing it is the compound of the pads themselves to not getting up to temp. And, yes absolutely when you put the anti-squeal stuff on it goes away. The reason why the squealing comes back is because there's friction between the brakes and the anti-squeal stuff just gets rubbed off due to friction. But then again, I could just be over simplifying things as it's late here in Chicago lol and I could just be getting tired. |
#308 | |
| Tags |
| brakes, caliper, sti, swap |
| STI front brakes on BRZ (confirm) | michael317 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 123 | 05-23-2016 01:41 PM |
| GTS Front Brakes + Rotors + Pads | GC GTS Aero Kit | Australia Classifieds | 2 | 11-16-2012 06:20 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 11:08 AM |
