86WORX
Old 04-23-2014, 05:49 PM   #225
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by SkAsphalt View Post
^ In response to the above post, (which I could edit, but this just bumps a useful thread)
My father was able to take out the strip bolt and chase the threads and have it perfect in like 30 minutes all utilizing stuff he had in the garage. $300 at repair shop...free at my parent's garage...yeah, that's a win.
Doesn't surprise me. The bleeder is not something that needs a ton of torque or is a fastener. It just needs to thread down and seal. It needs no more torque than your smallest wrench can provide. I would have whipped out my tap and dye set and had it fixed to useable in no time.
Old 04-23-2014, 05:56 PM   #226
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
That is because you are the King
Old 04-24-2014, 06:13 PM   #227
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Well played. Enjoy your brakes.
Old 04-24-2014, 06:47 PM   #228
gator2b2003
Drives: 2013 Raven FRS
I'm going to be doing this swap as soon as my rotors come in. I ordered DBAs like you @King Tut but they have been on back order for over a month and look to stay that way for another few weeks. I'm starting to look into other options and just want to make sure I have everything correct.
I bought 2011 STI brembos, which means I could use the 04 front rotors that would already be 5x100, but need redrilled/custom drilled rear rotors because they need to be 08+.
Thanks for the clarification in advance.
gator2b2003 is offline   Reply With Quote
Old 04-25-2014, 12:00 AM   #229
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If you get the DBA 4000 rear rotors for 08+ STI they're already dual drilled at the factory, so need to re-drill.
Fizz is offline   Reply With Quote
Old 04-25-2014, 01:03 AM   #230
gator2b2003
I know, thats what I have on order. But they have been on backorder for a month already and I was told it will be at least another 2 weeks. Trying to see what my other options are.
Old 04-25-2014, 01:40 AM   #231
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Oh sorry didn't know.....how about KNS did u try them?
The Following User Says Thank You to Fizz For This Useful Post:
AZP Installs (04-25-2014)
Old 04-25-2014, 08:33 AM   #232
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
KNS is THE place to get brakes from. Unless you get them from us.
-mike
AZP Installs is offline   Reply With Quote
Old 04-25-2014, 10:59 AM   #233
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I contacted each of the vendors on NASIOC to see who had the best price on the DBA rotors and who had them in stock. There is a good chance you can find one that has them in stock.
Old 04-25-2014, 06:48 PM   #234
OrbitalEllipses
Drives: Attitude
-mike
Love KNS.
Old 04-28-2014, 06:10 AM   #235
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Has anyone tried using tin snips to cut off the "lip" on the rear dust shields? Will it work? (I don't have an angle grinder at home).
Was planning to use those tin snips and then a dremel grinder to de-burr the edges. Then give it a lick of paint.
Old 04-29-2014, 04:03 PM   #236
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am pretty sure I removed mine with tin snips.
Old 04-30-2014, 10:48 AM   #237
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Great...did the shields cut off easily with those? I've used tin snips on flat sheet metal before but never cut a dust shield....especially to get a nice radius around it.
Old 04-30-2014, 07:37 PM   #238
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I wouldn't say it will cut off a nice radius. It also depends on what type of tin snips you are using. They got the job done, and then I used a hammer to bend a lip into what was left so the sharp edges left from the tin snips wouldn't show. A body hammer or a cut off wheel would do a much better job, but I didn't feel like braking out my cut off wheel.
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
