Old 09-17-2013, 04:09 PM   #211
OrbitalEllipses
Drives: Attitude
Don't forget the following:
"Hold my beer..."
"Hey, watch this..."
Turbowned (09-17-2013)
Old 09-17-2013, 05:41 PM   #212
Turbowned
Turbowned's Avatar
What are you doing about the rear rotors for 5x100? I was not aware of the Centric rotors being dual drilled for the rears. You are getting a rotor from a 2008-2013 STI for the rear right? I don't think the DBA 5000 series are worth the extra cost, but I am still loving my DBA 4000 series. I think I only paid like $700 along with a set of Hawk HPS pads for all four corners.
2004 STi rotors in 5x100. If the DBA 4000 are dual-drilled to fit 2004-2013, logic dictates that 2004 5x100 rotors should be the same dimensions as the 2005-2014, no? And if they aren't then hey, I got new rotors for my STi!
Old 09-18-2013, 02:31 AM   #213
OrbitalEllipses
Drives: Attitude
Only front rotors are the same. Rear rotors changed hat offset and such in 2008; you can NOT use GD STI rear rotors.
Old 09-18-2013, 09:56 AM   #214
Turbowned
Turbowned's Avatar
Poop. Why then do the DBA's come dual drilled?
Old 09-18-2013, 09:59 AM   #215
OrbitalEllipses
Drives: Attitude
Why's the sky blue?
It just is.
Old 09-18-2013, 10:03 AM   #216
Turbowned
Turbowned's Avatar
Not quite the answer I was looking for but oh well, like I said now I have new rotors for the STi for next year. One of my buddies has a hookup for DBA so I'll just wait a bit and get them once the calipers get back from powdercoating.
Old 09-18-2013, 10:05 AM   #217
OrbitalEllipses
Drives: Attitude
Sorry cupcake.
04-07 STI rotors from DBA are dual-drilled because the dimensions didn't change, only the bolt pattern did. Why have two P/Ns for what is essentially the same item?
08-13 STI rotors from DBA dual-drilled? Because swaps.
Turbowned (09-18-2013)
Old 09-18-2013, 08:07 PM   #218
wallace03
wallace03's Avatar
Drives: WRB BRZ
if someone would do an DIY for the 04-07 brembos and 08+ you would be awesome.
wallace03 is offline   Reply With Quote
The Following User Says Thank You to wallace03 For This Useful Post:
SmsAlSuwaidi (09-23-2013)
Old 02-28-2014, 03:51 PM   #219
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Just wanted to bump this tread back up because it is very useful and I had to re-read it as I am going through this process (slowly) right now
Old 02-28-2014, 04:43 PM   #220
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
How does this upgrade hold more heat than the stock stuff? Bigger mass on rotor? Pad? Sorry late to the party on this thread
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 02-28-2014, 04:48 PM   #221
OrbitalEllipses
Drives: Attitude
326x30mm Brembo vs 294x24mm stock front brake rotor.
316x20mm Brembo vs 290x18mm stock rear brake rotor.
OEM pad front: D1539
OEM pad rear: D1124
STI Brembos pad front: D1001
STI Brembos pad rear: D961
kiichiro (03-01-2014)
Old 03-01-2014, 12:08 AM   #222
kiichiro
Ok, thanks, worthy stop gap measure, possible negating need for a bbk, huh
Cool thread
Can someone sell all this as a kit or what?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 03-27-2014, 02:45 PM   #223
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
So, terrible news. One of the bleeder bolts totally stripped, and it stripped in a fantastic way. The bot was so heated, that when it stripped, it turned into a bullet wound. Machine shop now says they will probably have to drill press it, cannot guarantee the threads will be salvageable and may need to over side it, put in a sleeve and do other work to make a bleeder usable.
So basically, I have one messed up bleeder plug, could cost me over $300 to fix (yay Regina Canada for not having more machine shops to promote lower costs....). Do I just leave it? The other bleeder swapped over fine, the other caliper is good to go. should I just leave it as is and remove the caliper when I need to bleed the system (we don't do that often, right?) or should I hunt for a new caliper?
Opinions, thoughts?
Old 04-23-2014, 05:26 PM   #224
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
^ In response to the above post, (which I could edit, but this just bumps a useful thread)
My father was able to take out the strip bolt and chase the threads and have it perfect in like 30 minutes all utilizing stuff he had in the garage. $300 at repair shop...free at my parent's garage...yeah, that's a win.
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
