Old 05-26-2013, 06:45 AM   #197
BongMan
Smile Torch Only?
Is there a way to switch the bleeders without using a torch?
I have some 04 STI take offs that i want to try out. I thought King Tut said he didn't use a torch but i don't remember him saying what method he did use.
Also if anyone has done the torch method do you have any after pictures? I would like to get an idea of how much browning one should expect.
Thanks!
BongMan is offline   Reply With Quote
Old 05-28-2013, 08:36 PM   #198
derek1ee
Drives: BRZ/FRS/STI/M3
Thanks!
I did the 19mm bolt yesterday and now the bleeder swap is next, would like tot hear how people did it.
derek1ee is offline   Reply With Quote
Old 06-16-2013, 01:50 AM   #199
slava
slava's Avatar
Drives: brZed
I want to do this with the megan or hard race 5x114 hub conversion. shouldn't make a difference with the aftermarket hubs right?
slava is offline   Reply With Quote
Old 06-17-2013, 11:17 AM   #200
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Is this a hub conversion or a spacer wheel pattern conversion? If it is a spacer wheel pattern conversion it won't work and you will still need 5x100 rotors. If it is actually swapping out the entire hub to a 5x114 hub, then you will be good to go.
Old 06-17-2013, 11:19 AM   #201
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks!
The difference between mine and most was that mine were relatively new 08-12 calipers and not really old 04 calipers, so my bleeder screws and plugs came out with no heat. I just used an allen socket and a 3/8" breaker bar. I don't know how much browning you should expect, but if you get a small enough torch you can hopefully just heat the plug head to loosen the red threadlocker.
Old 06-18-2013, 12:20 PM   #202
slava
slava's Avatar
Drives: brZed
Hun conversion. Thanks man!
Old 07-06-2013, 10:40 PM   #203
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
Very sexy indeed... neat yet cool awesome job..
dokterdewe is offline   Reply With Quote
Old 07-18-2013, 04:00 PM   #204
Phoenix 6.0
Drives: 2013 WRB BRZ Premium
One trick to getting red locktite bolts out is to use a soldering iron and put the tip on/in the bolt head. Gets the bolt hot but not the surrounding area like a torch would
Phoenix 6.0 is offline   Reply With Quote
The Following 2 Users Say Thank You to Phoenix 6.0 For This Useful Post:
civicdrivr (07-18-2013), Turbowned (07-19-2013)
Old 07-19-2013, 12:54 PM   #205
Turbowned
Turbowned's Avatar
How many other people have done this conversion? I'm getting ready to pull the trigger on some '08 Brembos today; found a sweet deal!
Old 08-01-2013, 06:32 PM   #206
kuhlka
Drives: 2013 BRZ Limited AT
Originally Posted by koyv90 View Post
thanks for the link i guess my second question is do you think this is better then stock?
The brakes on my STI are amazing when they're bled, especially with EBC Red Stuff pads. I'm not a big fan of the Hawk HPS pads at all.
kuhlka is offline   Reply With Quote
Old 09-16-2013, 08:41 PM   #207
Turbowned
Turbowned's Avatar
So I'm gonna try Centric high-carbon rotors with this conversion. Didn't see the value in spending a thousand bucks on rotors when I could spend $282 with shipping for all four from Rock Auto. Granted I would've loved to have put DBA 5000 series two piece rotors on the car, but it just seemed silly. The calipers I'm buying are take-offs from a 2013 STi that was being made into a rally car, so they have just 300mi of use and brand new OEM pads, too. I'm also ordering Stoptech stainless lines. We'll see how it all works!
Old 09-17-2013, 03:56 PM   #208
King Tut
NASA SpecE30 Racer
King Tut's Avatar
What are you doing about the rear rotors for 5x100? I was not aware of the Centric rotors being dual drilled for the rears. You are getting a rotor from a 2008-2013 STI for the rear right? I don't think the DBA 5000 series are worth the extra cost, but I am still loving my DBA 4000 series. I think I only paid like $700 along with a set of Hawk HPS pads for all four corners.
Old 09-17-2013, 04:06 PM   #209
OrbitalEllipses
Drives: Attitude
C-clamp? Check.
Proper diameter metric drill bit? Uhh...check!
High-speed cordless drill? Check!
Beer? Check!
Old 09-17-2013, 04:08 PM   #210
King Tut
NASA SpecE30 Racer
King Tut's Avatar
C-clamp? Check.
Beer? Check!
Don't forget the following:
"Hold my beer..."
"Hey, watch this..."
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
