Old 01-15-2013, 07:02 PM   #141
OrbitalEllipses
Drives: Attitude
Originally Posted by omegared19 View Post
I'm eyeing a set of Advans.....I'm pretty sure they'll work. Just a guess tho
http://forums.nasioc.com/forums/showthread.php?t=448097
King Tut (01-15-2013)
Old 01-15-2013, 07:56 PM   #142
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Lol, thnx. I also was looking at stealing the wheels off this Schwinn outside my apartment. Wonder if those'll fit??
omegared19 is offline   Reply With Quote
Old 01-15-2013, 08:23 PM   #143
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
Would this list represent what would fit on the twins with the brembos?
1991 BB NSX . 2013 WO FRS . 1978 Yamaha SR500
fenixv8 is offline   Reply With Quote
Old 01-15-2013, 09:06 PM   #144
omegared19
omegared19's Avatar
I believe it would good sir:happy0180:
The Following User Says Thank You to omegared19 For This Useful Post:
fenixv8 (01-15-2013)
Old 01-15-2013, 09:19 PM   #145
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Would any of you that have done the swap be able to measure the distance from front of the rotor hat or rotor to the end of the caliper towards the wheel spokes. Just to see how much is needed to fit the front calipers?
My prodrives have about 25mm more clearance than the stock wheels. Im wondering if that is going to be enough.
Okay the distance from the rotor hat to the furthest out point on the caliper near the spokes is about 1.5" or about 38 mm. My 18x8 +42 wheels only have about 1/4" or about 6 mm of clearance.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
fenixv8 (01-15-2013), omegared19 (01-15-2013)
Old 01-15-2013, 09:21 PM   #146
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Great link.
Old 01-15-2013, 09:30 PM   #147
fenixv8
fenixv8's Avatar
Thanks King Tut!
Old 01-16-2013, 07:15 PM   #148
jumbaco
jumbaco's Avatar
Drives: FD
damn, looks great!
jumbaco is offline   Reply With Quote
Old 01-17-2013, 09:10 PM   #149
omegared19
omegared19's Avatar
So I just got off the phone with the kids over at AP Raring, and they're going to be putting together a 326mm front and 316mm rear rotor set with 5x100 hats for me. Project Suuupa Grrripa in effect
Old 01-21-2013, 02:22 PM   #150
hypermax
hypermax's Avatar
Drives: BRZ Limited
Once again for the update, I am getting all my brake parts this Wednesday, can't wait to do project this weekend.
hypermax is offline   Reply With Quote
Old 01-21-2013, 03:04 PM   #151
STEVEOSTI
Speed Freak
STEVEOSTI's Avatar
Drives: 2005 Subaru WRX STi
If you're looking for cheap 17" wheels that will clear brembo's check out the XXR 522's. I run the 17x8" with a +48 offset on both my STI and the BRZ. The goal was to add larger callipers on the BRZ so I chose a wheel I liked the looks of with the ability to add bigger brakes down the road. These come in flat black and chrome black as well. Also come in an 18x8.5 +48 for guys looking to run larger wheels. My 17's weigh 21lbs each.
Steve
STEVEOSTI is offline   Reply With Quote
Old 01-21-2013, 03:11 PM   #152
omegared19
omegared19's Avatar
Not a bad look
Old 01-21-2013, 05:07 PM   #153
orthojoe
Great thread and informative. I may consider this setup should R comp tires prove to be too much for the stock braking system.
OT: King Tut, why did you decide to get rid of the Cayman R in favor of the BRZ?
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 01-21-2013, 06:43 PM   #154
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Are the rear rotors dual-drilled STI rotors? Or WRX rotors?
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
