#127 |
Drives: Attitude
For those between Brembos (which move bias forward) and FHI 4 pots (no added heat mass) there IS another option. KNS brakes is apparently working on a bracket to mount Nissan Z32 calipers (identical to FHI Subaru units, but cheaper and with Nissan mounting points) that will allow the use of Legacy GT rotors (316mm x 30mm) up front. There's a thread on NASIOC about this if you want to do more research.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Respect BRZ (02-14-2016) |
#128 |
Awesome thread guys. I really think aluminum knuckles would be very beneficial to a lot of BRZ/FRS drivers. I am guessing you could cut the sprung weight of the stock knuckle by at least half if not more. Also you would get a benefit of greater heat transfer from the brakes/bearings based on what type of aluminum is used. Oh and also easier to press hub bearings in and out.
#129 |
NASA SpecE30 Racer
I was originally going to use heat on mine, but I didn't want to ruin the finish on the caliper. The plugs are put in with red loctite which is why the heat might be required. I can't believe that I got lucky enough to get all the plugs out with no heat and no issues. Your best bet is going to be a small nozzle propane torch that you can get the heat right on the bolt head. I took my plugs out after I had already mounted the calipers.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#130 |
Drives: White 2013 BRZ Limited 6MT
I've got a heat gun that I picked up a while back for doing tail lights. So I'm going to try that.
#131 | |
NASA SpecE30 Racer
No way a heat gun is going to get those threads hot enough to mess with the red loctite.
http://www.henkelna.com/industrial/r...ngth-12892.htm Quote:
- King Tut
#133 |
Drives: 1991 Acura NSX, 2013 Scion FRS
Would any of you that have done the swap be able to measure the distance from front of the rotor hat or rotor to the end of the caliper towards the wheel spokes. Just to see how much is needed to fit the front calipers?
My prodrives have about 25mm more clearance than the stock wheels. Im wondering if that is going to be enough. |
#134 |
NASA SpecE30 Racer
I will try to measure it tonight.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | fenixv8 (01-15-2013) |
#135 |
#136 |
#137 |
#138 |
Then I guess I'm going back to getting 18's.......it'll be a fun upgrade anyways
#139 | |
Site Moderator
Drives: Stuff
17s work, but you need to find wheels that specifically fit a 2004 STi.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| Tags |
| brakes, caliper, sti, swap |
| STI front brakes on BRZ (confirm) | michael317 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 123 | 05-23-2016 01:41 PM |
| GTS Front Brakes + Rotors + Pads | GC GTS Aero Kit | Australia Classifieds | 2 | 11-16-2012 06:20 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 11:08 AM |
