Old 11-30-2012, 06:35 PM   #29
GC86
Drives: Ft86
Originally Posted by ebphoto View Post
these look awesome.
wonder how they ride low... just ride on bump stops or..?
interested in being able to run a koni race setup... low.
Actually, they do not ride on the bumpstops. The GC struts are shorter than both the stock struts or the stock struts with Koni inserts. Additionally, the camber/caster plates stick up higher for more clearance too.
Remember though, a GC race setup is RACE. It is not "trackday" or "driver school".
Our very first street kit should be for sale on Monday, and the front camber/caster plates and rear mounts are different than the autocross/race/trackday mounts .
GC86 is offline   Reply With Quote
Old 11-30-2012, 07:44 PM   #30
GC86
Drives: Ft86
They use Konis. I believe they are making their own housings but I'm not sure. You can pick between Koni Sport single adj, Koni Yellow Race, or Koni double adjustable, presumably on the yellow Sports, but not 100% sure. The rears are a Koni 30 series shock, sucks to adjust the damping setting on them (has to be off the car), that's the only bad thing though.
They 30 series RACE /TRACK /SCHOOL rear, actually do not have to be removed from the car. You do however want to jack the car up, it is easier to reach the rebound adjuster through the springs.
The STREET GC Koni rears are adjusted from in the trunk, but unfortunately are not intended for as much spring.
The Following User Says Thank You to GC86 For This Useful Post:
Dave-ROR (11-30-2012)
Old 11-30-2012, 07:47 PM   #31
Celica00
Celica00's Avatar
Drives: 86
holy hell, those are some sexy parts. definitely going this route if the reviews are positive.
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
GC_Adam (11-30-2012)
Old 11-30-2012, 08:09 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ah, my bad. I didn't realize you guys were offering anything but the Series 30 in the rear. Good to hear that it doesn't have to be removed, I didn't think the shaft would spin freely (well easily by hand anyways) with the top hat tightened down.
Good info
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-30-2012, 10:40 PM   #33
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
What spring rates are you providing when someone orders one of the defined options on website, such as "touring," "aggressive," etc?
At what spring rates, do you recommend using each of the three damper options?
These seem to check all the right boxes. Nice job!
uspspro is offline   Reply With Quote
Old 11-30-2012, 11:54 PM   #34
_F-R-S_
Drives: 13 whiteout scion frs
Cant wait for those tax returns. Lets get to some more talking about a good setup on autox and track
_F-R-S_ is offline   Reply With Quote
Old 12-03-2012, 01:50 PM   #35
GC86
Drives: Ft86
Thanks for the compliments on the Blue GC kit.
Your "defined options" question is more appropriate for the "GC f.a.q. thread", because it is THE most frequently asked question by far. I will cut and paste, and answer there.
Search this Thread:
Advanced Search
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 06:48 PM
Galaxy Blue - NZ diss7 AUSTRALIA 5 09-25-2012 07:51 AM
16" or 17" for winter? Blue rims on blue car? TPMS or not? Deslock Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 01:33 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
blue FR-S subaruferrucci Mid-Atlantic 1 05-31-2012 12:47 PM
