86WORX
Old 10-18-2013, 12:24 AM   #225
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I bet ya they will do everything they can to blame it on the intake.
Muaddib is offline   Reply With Quote
Old 10-18-2013, 11:10 AM   #226
frs10
Drives: tezla
Originally Posted by PERRIN_Mladen View Post
We provide you with a hose cap that gets installed over the plastic fitting to keep the air from entering the cabin.
do we remove the entire noise generator assembly up to the firewall?
frs10 is offline   Reply With Quote
Old 10-18-2013, 11:26 AM   #227
Prowl647
Drives: Brz premium
No
Prowl647 is offline   Reply With Quote
Old 10-18-2013, 12:33 PM   #228
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
You remove it to the frame rail. There is a plastic fitting there that gets capped off.
Installed, the inlet will look like this -
PERRIN_Mladen is offline   Reply With Quote
Old 10-18-2013, 03:11 PM   #229
frs10
Drives: tezla
why did you guys decide to keep that last part? why not just remove the entire thing and plug the hole from the firewall?
Old 10-18-2013, 03:54 PM   #230
PERRIN_Mladen
Drives: '11 535i
We did it due to the location of where you would have to cap it off.
The firewall location is much harder to get to, so we chose to stop at the frame rail for ease of install.
The Following User Says Thank You to PERRIN_Mladen For This Useful Post:
JR007 (03-31-2014)
Old 04-15-2015, 06:01 PM   #231
Privman
Drives: 2015 frs
Is it still possible to cap off at firewall if wanted to?
Privman is offline   Reply With Quote
Old 04-15-2015, 07:12 PM   #232
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Sure! It's just really hard to get to, since it's buried in there.
PERRIN_Chris is offline   Reply With Quote
Old 04-15-2015, 07:15 PM   #233
Privman
Drives: 2015 frs
Okay, just asking. I just placed order for intake and inlet pipe.
Old 04-15-2015, 07:17 PM   #234
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Cap it off from inside the car, Subaru even gives you a plug in your glove compartment.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Mr.Impreza (02-19-2016)
Old 04-16-2015, 03:30 AM   #235
churchx
churchx's Avatar
Drives: 2014 GT86
Indeed, no need to order separate soundtube plug, if for quick tests there is one on glove compartment cigarette lighter (which i use for powering usb devices anyway).
From what i experienced though, that if i plug sound tube, even if with quietening engine noise it quietens road noise too .. i miss engine noise too much (with stock exhaust) at daily driven low rpms and even while performance numbers should be same .. it felt subjectively lifeless/slower . Hence i'll probably go for complete sound tube delete only when also installing catback exhaust or non stock catless header, any of which should increase noise to compensate for that
Old 02-18-2016, 10:36 PM   #236
jg7
Drives: 2016 Scion FR-S
Hello,
I’m thinking of adding one of the Perrin intakes tubes to my 2016 FRS. I’m mostly trying to neatly eliminate the sound tube (save a little noise/weight), but also to help clean up the engine compartment a bit. I’m not really doing this with any hope of increasing power. As I understand, it’s miniscule at best without other modifications to the intake/exhaust.
My question to those who have used it is: Do you just install it and drive away or, is there anything special that needs to be done with the computer. Do I need to disconnect the negative battery cable or anything, or will the computer adjust by itself to the slight change?
There did not seem to be a consensus and this thread has not been active in a while.
Thanks in advance for any feedback.
jg7 is offline   Reply With Quote
Old 02-19-2016, 10:22 AM   #237
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
That's exactly right. Install, ensure everything is tight, and go.
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
Old 02-19-2016, 09:49 PM   #238
jg7
Thanks! That's what I'll do.
-jg7
Search this Thread:
Advanced Search
Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters ZetaPerformance Engine, Exhaust, Transmission 95 11-05-2014 08:42 PM
Maxracing dynamic intake duct Mars2 Engine, Exhaust, Transmission 123 09-23-2014 09:39 PM
AVO Silicone Intake and Sound Tube install and review ESC POD Engine, Exhaust, Transmission 38 05-21-2013 08:18 AM
Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters ZetaPerformance Engine, Exhaust, Bolt-Ons 41 05-13-2013 03:00 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 05:58 PM
