Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 11-28-2012, 05:26 AM   #15
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Originally Posted by caldine View Post
I've got a couple of TRD 2 way Mechanical LSD's if anyone is interested .
$NZ 1200 shipped .
Shipped to Australia?
Gir is offline   Reply With Quote
Old 11-28-2012, 05:43 AM   #16
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
Originally Posted by Xauterus View Post
If you are going to change the diff centre then its probably worth changing the ratio at the same time. Also for the track, look at removing the rear sway bar to give you some more droop.
Can't change the ratio.. it's the rules and they do check ... but thanks for the advice..
CR
000 Racing is offline   Reply With Quote
Old 11-28-2012, 05:45 AM   #17
000 Racing
000 Racing's Avatar
About to put Super Pro 20mm front and 18mm rear.. seems to be the tuners choice on size..
Old 11-28-2012, 05:48 AM   #18
000 Racing
000 Racing's Avatar
$NZ 1200 shipped .
Might PM you re this..
Chris R
Old 11-28-2012, 06:28 AM   #19
BRZRR
Drives: Black BRZ
I was of the understanding the cheaper model didn't have an LSD, only the GTS.
BRZRR is offline   Reply With Quote
Old 11-28-2012, 06:40 AM   #20
Cappuccino
Drives: 2012 Tornado Grey Toyota 86 GTS
Only the Auto GT is an open diff.
Manual/Auto GTS is a Torsen LSD as well as the GT Manual.
Cappuccino is offline   Reply With Quote
Old 11-28-2012, 06:45 AM   #21
Gir
Gir's Avatar
GT Manuals have LSD's too.
Old 11-28-2012, 07:37 AM   #22
Xauterus
Drives: GTS 86 Galaxy Blue
To quote someone on the racing forum on here:
If you find the rear of the car too loose, the last thing you want is more rear bar. And with the limited droop travel you don't really want more rear bar trying to pick up on, and unload the Torsen. Just today pulling in my shop I got stopped dead when the right rear came up and there I was with no drive..... Who wants to make that worse?
What spring rates are you running on your car now? I would try swapping the front sway bar in first with the stock rear bar, then test with both new bars, then no rear bar.
This is for racing not drift?
Xauterus is offline   Reply With Quote
Old 11-28-2012, 04:54 PM   #23
86drift
86drift's Avatar
Drives: Toyota 86 GT
Give it a try on the track before you spend the $$$.
I find the LSD great up until you get a rear wheel off the ground. Which I'm sure happens more often in a rally car than a track car.
I'm keeping the centre for now and will be looking for 4.9 or 5.1 gears.
Also, clutch pack LSDs can induce understeer where the torsen doesn't.
86drift is offline   Reply With Quote
Old 11-28-2012, 06:47 PM   #24
000 Racing
000 Racing's Avatar
Hi Josh, I agree.
Having racing many cars with locked diffs the big disadvantage is that you can't get on the throttle too early as you tend to pick up the front and with a driving inner you understeer badly.. with these cars the advantage is driving through mid corner as they don't have the power to jump on the gas on exit..
I will run the car in.. see what times I can put in.. I have a good idea where I think it should be once I get my head around the lack of power.. no more 400rwhp !!!
It has to be kept in mind that I am running Dunlop D03 R spec tyres so grip will be good.. I think it's a matter of staying off the ripple strips.. in any case when you look at how light the arms are that's a given with these.. too many hits and they will break.. I do like the idea of the two way diff though.. budget is running out at present...
Old 11-28-2012, 06:56 PM   #25
caldine
Drives: Verossa VR25 Turbo Manual
Yep. EMS 3 - 5 day turnaround .
caldine is offline   Reply With Quote
Search this Thread:
Advanced Search
Is the Limited slip differential identifiable? jabbajaw99 Engine, Exhaust, Transmission 10 09-14-2012 08:23 AM
Video: FR-S / BRZ Torsen Limited Slip Differential Explained Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 06-29-2012 08:22 PM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 12:26 PM
Scion FR-S, Limited slip dif (LSD)? Dbringer Scion FR-S / Toyota 86 GT86 General Forum 20 06-13-2012 04:02 AM
Torsen limited slip BMWDavid BRZ First-Gen (2012+) -- General Topics 41 06-12-2012 10:04 PM
