Old 03-06-2013, 10:13 PM   #43
Racecomp Engineering
Rates will be 400/400 with optional 500/500 or 400/450.
Same lifetime warranty all of our Tarmac II's have had since we started working with KW back in 2006 on private label/ co branded products.
Expect 4 weeks from now or less.
I have found them very streetable with STI group-n fronts and oem rears. I got -2.6 front camber on oem crash bolts. +6.7 caster too.
Camber plates yes would allow much more, but would introduce some NVH too.
Just a thought.
Myles
Old 03-06-2013, 10:27 PM   #44
ayau
Drives: Some rust bucket
Just a thought.
Myles
Can you explain the philosophy behind the rates that were chosen? Were they chosen for the daily driver/weekend racer in mind? I noticed 2/3 rates are 1:1. Whats the reasoning behind the 400/450 rate? Is it to make the rear a little more "loose"?
Old 03-06-2013, 10:43 PM   #45
The OPTIONAL 400/450 is there for those who prefer that. Yes MANY like and prefer that split of having 50lbs more in the rear. I will admit I feel that "thinking" on some's behalf is from the Impreza( 08-2013) crowd.
We are using EQUAL (400/400) as the standard rates to ship with. The car is very neutral with equal rates we have found at the limit. Solid tire temps running Michelins at -2.6 and -2.0(front to rear) . Hoosiers will require more front camber.
But some autocrossers like more rear rate. Some prefer the "loose" tail. Some will keep rear bar stock and use a HUGE front bar and yet still increase rear rates. Its not what I prefer but I'm not an autocrosser anymore either.
Myles
Old 03-07-2013, 01:00 PM   #46
createluck
Drives: 2013 Subaru BRZ Limited 6MT
Pre-ordered my set last week! Decided to go with camber plates for maximum adjustment flexibility.
createluck is offline   Reply With Quote
Old 05-24-2013, 02:26 PM   #47
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Getting very excited to install these on the weekend! What is the lowest recommended drop on the Tarmac II's?
OjiGeorge is offline   Reply With Quote
Old 11-17-2013, 12:02 AM   #48
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Any info on shock dynos comparing the STD V3s to these units? Really close to pulling the gun on these...
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
The RaceComp Engineering BRZ "Clubsport" Build Racecomp Engineering Member's Car Journals 100 12-18-2014 03:18 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Brakes, Suspension, Chassis 4 02-20-2013 02:34 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-15-2012 08:03 PM
Racecomp Engineering coilover sales: JRZ RS1 and KW V3 Racecomp Engineering Brakes, Suspension, Chassis 29 09-17-2012 11:46 AM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
