Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 12-07-2012, 02:53 AM   #29
Crewzern
Crewzern's Avatar
Drives: 86
So this is the same kit Perrin has on there vortech car. 210kw flywheel or wheel ? ... when Perrin dynoed there vortech kit they got around 250 whp, thats ~ 185wkw ... would have been nice if RGM offered the ECUTek option as opposed to piggy back
Price is
Crewzern is offline   Reply With Quote
Old 12-07-2012, 02:58 AM   #30
v3rgil
Drives: Toyota 86 Black (Standard)
High Performance Supercharger Kit
for Scion FR-S / Toyota 86 / Subaru BRZ
OEM Fitment Twin Screw Supercharger
TWIN SCREW SUPERCHARGER - The twin screw (positive displacement) supercharger provides unrivaled low and mid range torque while still providing impressive peak power. The proprietary internal design of the supercharger offers exceptional isentropic efficiency when compared to other supercharger and turbocharger designs and only requires servicing every 30,000 miles!
INTEGRATED INTERCOOLER - The intake manifold features highly efficient Laminova® liquid to air intercooler cores inside (Stage 2 only).
FUEL SYSTEM UPGRADES - The Stage 2 kit includes high flow injectors and a fuel pump to support higher horsepower levels.
TUNING - All kits include a professionally engineered EcuTek calibration to provide optimum performance and "OEM" driveability.
OEM AIRBOX - The original airbox and MAF sensor is maintained on the suction (cold) side to prevent damage to sensitive electronics, maintain OEM appearance and provide excellent air filtration.
HIGH PERFORMANCE INTAKE MANIFOLD - The purpose built intake manifold is a direct replacement and provides superior performance over the stock intake manifold.
v3rgil is offline   Reply With Quote
Old 12-07-2012, 03:02 AM   #31
v3rgil
i think we should all take a back seat and give about another 6 to 8 months, before we even consider buying a kit, there are so many manufactures whom want a piece of the 86,
that the competition is going to get so steep and force prices to drop. lets wait and see what happens, and also consider that know one has done any safe miles with a kit to give any indication of reliability.
Old 12-07-2012, 03:30 AM   #32
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Wow that really looks the part hey
GeeTee86 is offline   Reply With Quote
Old 12-14-2012, 08:43 AM   #33
JouMaSeHoes
JouMaSeHoes's Avatar
Drives: Toyota 86 RED!
A quick update on Braam's 86 Supercharger build:
We tested my car on his dyno as a baseline and got 100kw at the wheels (not bad for 35 deg C ambient!)
Later in the afternoon he tested his . . . . 156kw at the wheels
Wow.
JouMaSeHoes is offline   Reply With Quote
The Following User Says Thank You to JouMaSeHoes For This Useful Post:
Vic_RSA (12-14-2012)
Old 12-14-2012, 08:49 AM   #34
JouMaSeHoes
Sorry wrong pic. Here are some new ones.
Old 12-18-2012, 04:45 AM   #35
Crewzern
Crewzern's Avatar
Drives: 86
Can you post your dyno graph.
Old 12-18-2012, 04:49 AM   #36
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
And a sound clip if possible - from inside and outside.
Vic_RSA is offline   Reply With Quote
Old 12-18-2012, 05:00 AM   #37
JouMaSeHoes
I've asked him for digital copies of the dyno runs, I'll see if we can get together for a video clip sometime.
Vic_RSA (12-18-2012)
Old 05-20-2013, 02:35 PM   #38
Rommies
Rommies's Avatar
Drives: Toyota
http://www.ft86club.com/forums/showthread.php?t=37000
Rommies is offline   Reply With Quote
Old 05-27-2013, 05:16 PM   #39
Adam86
Adam86's Avatar
Drives: Toyota 86
only 210 kw? and thats on the flywheel not on the wheels... for that price you might aswell import a TURBO because it gives more power. RGM is abit crazy for 85k
Adam86 is offline   Reply With Quote
Old 01-10-2014, 04:53 AM   #40
BigBear
Drives: Ford Focus ST
Originally Posted by TheGooseman View Post
Just got the official info back from Rob....
This is AWESOME....!!
It looks absolutely BRILLIANT....!!
And the power..... OH MY WORD...!!
See below for all the details:
RGMOTORSPORT SUPERCHARGED 210kW(280bhp) TOYOTA 86
The fun-to-drive car is back, and the Toyota 86 platform is the most exciting thing to come along in years! However, most people believe there is one thing missing... more power! With RGMotorsports legendary history of improved performance through efficient boost, the team of Engineers at RGM-Vortech have designed a kit that makes these great cars even more enjoyable to drive. Design, detail and execution exceed OEM standards for a look you will be excited to show off at the car show or the track.Boost your Toyota 86 to the next level of performance with the new centrifugal supercharging system from RGM-Vortech.
View of the 86 engine compartment with the RGMotorsport-Vortech Supercharged installation
System Features
• Gear-driven V-3 H67BC centrifugal supercharger, designed specifically for the FA20 Boxer engine.
• The V-3 features an internal oil reservoir. No connection between the oil pan and the compressor gear case is required; no oil line. Includes a remote fluid drain hose (attached to supercharger) that allows for simple
fluid changes without removing the supercharger from the vehicle.
• Technologically advanced, high-efficiency, 5-Axis machined billet impeller and high-diffusion housing developed in our SAE-J1723-compliant supercharger test cell.
• Stylized airbox and filter housing design allows for additional flow, while retaining the factory cold air ram intake. Quick release fasteners allow for simple access to filter for change/cleaning.
• Integrated air/air charge cooler configuration features all aluminum tube ducting and an oversized cooler core to provide maximum cooling with minimum pressure loss.
• Discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps.
• CNC machined billet mounting bracketry with black anodized finish for attractive and functional "factory-type" appearance and rigidity.
• Complete bolt-on system including all necessary belts, pulleys and reusable high-flow air filter.
RGM is proud to be releasing this joint supercharge venture into the South African market place, in January 2013.
Our kits will be available as follows :
RGM- Vortech supercharger kit, engine mapping is via Uni Q unichip .This installation includes our 6 months/20 000km warranty Cost R 75000.inc
RGM Techniflow 63mm stainless steel performance exhaust system (this system also eliminates the catalytic convertors ) This exhaust system does give you the option of using the OE tailpipes
Cost R 9950.inc
The performance gain expected 210Kw(40% plus gain) including our exhaust system
This image portrays the high quality of the kit with a view of the individual components.
http://WWW.RGMOTORSPORT.COM
http://www.youtube.com/user/RGMDonovan?feature=watch
RGMotorsport Supercharged Toyota 86
[ame="http://www.youtube.com/watch?v=rx8xitKLSBA"]RGMotorsport Supercharged Toyota 86 - YouTube[/ame]
RGMotorsport Supercharged Toyota 86 Install video!! Weve improved this Standard 147kw powered Toyota 86 to a Mind Blowing 220 kW 315 Nm Powered sports car! Top speed of 270.99 km/h and 0 - 100 in 6.2 seconds!! For more info email us on info@rgmotorsport.com or visit our website www.rgmotorsport.com!
Very Nice conversion just price 70k hectic but hopefully the Price=Quality as they claim.
BigBear is offline   Reply With Quote
Old 01-10-2014, 05:37 AM   #41
BigBear
From 147kw 197 bhp
To 221 kw 296 bhp
Good gains.
Old 01-14-2014, 08:14 AM   #42
BigBear
[ame="http://www.youtube.com/watch?v=hzOsLqSxRCw"]RGMotorsport SUPERCHARGED Subaru BRZ on Ignition Channel![/ame]
RGMotorsport has SUPERCHARGED Subaru Southern Africa's Very own Subaru BRZ. Here is the video from Ignition Channel where Southa African Rally Star Gugu Zulu took it around Zwartkops Raceway! For more info on the SUPERCHARGED Kit for the Toyota 86 / Subaru BRZ From RGMotorsport visit our website at www.rgmotorsport.com or email us on info@rgmotorsport.com !
Zwartkops Lap Time 01:16
The Following User Says Thank You to BigBear For This Useful Post:
sav (01-14-2014)
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
HKS Supercharger Style Forced Induction 75 08-06-2012 03:25 AM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-28-2012 12:42 AM
