| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
#16 |
Drives: Attitude
This is my first manual as well, and I stalled a fair bit in the first few weeks. If I tried to describe the clutch on this car I'd say the pedal is soft, with some dead travel at the beginning and a wide area of modulation. It definitely took some getting used to, but I find it to be really forgiving though feel is definitely a problem; the friction area isn't necessarily hard to find, rather it's numb at its "borders" so to speak.
Gurus feel free to correct, |
#17 |
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
DIY for Clutch Adjustment - http://www.ft86club.com/forums/showthread.php?t=8040
It makes a huge difference |
| The Following User Says Thank You to kykiee For This Useful Post: | arleewa (01-02-2013) |
#18 | |
Drives: sc00ter
I'm so glad I'm not the only one that needs some time getting used to driving frs/brz clutch.. for a minute, i thought i suck at driving stick haha |
#19 |
Haha yeah I felt the same way a couple of times in the first few weeks I had the car. Try the DIY clutch adjustment posted above. I eventually got that done and it helped a lot for me since I was used to cars where the clutch engages early on. Much better/more intuitive now.
2022 BRZ Build 2013 FR-S Build |
#20 | |
Drives: sc00ter
#21 | |
Drives: 2013 Subaru BRZ
#22 |
Drives: 2013 BRZ WRB 6MT Sport Tech
Indeed ! Clutch is way easier specialy in heavy traffic compared to my past LGT. Wouldn't go back.
#23 |
Drives: FR-S 6MT Ultramarine (BeeDrill)
I think I've stalled the car once but I will definitely be adjusting the clutch a bit. I'm coming from a 2010 WRX where the revs dropped too slow and made fast shifting hard where as the revs drop much quicker in this car and make leisurely shifting harder. I'm finding the revs dropping too far and I have to tap the gas to bring them back up to engage the clutch in the next gear. This is really only an issue when the trans is cold and I need to shift easy. Once it is warmed up and I can shift faster it isn't as much of an issue. Glad to hear other people have the odd issue though, makes me feel like I'm not too much of a shit driver.
2013 Scion FR-S - Ultramarine 6MT
#24 |
Drives: Skoda Yeti DSG diesel 4x4
I found the throttle response pulling away in first was delayed when it was new but after over 1000km it has come good. I'm assuming this was ECU learn but it was strange I only noticed it pulling away and could double clutch easily, which needs a quick response.
I wish the brakes were a bit more responsive. Last edited by sierra; 01-02-2013 at 10:53 PM. Reason: missed word |
#25 | |
When In Doubt...
Drives: Slowww
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
| The Following User Says Thank You to Laika For This Useful Post: | A5D5TRYR (01-02-2013) |
#26 |
Thanks for the tip. I've done this a few times and I seem to be fine once it's warm but the engine RPM just doesn't act the same when it's cold and makes it really hard to engage smoothly when it's cold. I've only had the car almost two weeks so I figure with practise I'll get better. Changing out the trans fluid will likely help as well as I should be able to shift faster when it's cold. To be fair it is way easier to drive this car smoothly than my WRX was and much easier to launch without bogging the engine.
#27 |
Drives: '15 WRX '13 Legacy '07 Colorado
Yup, pedal feel has nothing to do with power. My 4cyl pickup is neither sporty nor powerful, but you almost have to stand on the clutch pedal.
#28 | |
Drives: Attitude
| Clutch.. | RedRocket | Forced Induction | 37 | 11-11-2012 05:52 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 11:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
