#939 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
It only took so long because I was lazy about getting them. Haha.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following User Says Thank You to Wonderbar For This Useful Post: | chanomatik (07-24-2014) |
#940 | |
We opted not to use aluminum in favor of steel for a number of reasons. For people looking to shave ounces, the cheaper/lesser hood struts might be a better choice. Personally, I'd stick with the prop rod and just leave it out of the car when not in use, if that were the case. Mild steel was selected to ensure that the parts would outlast the car. Next time you've got your eye on something from GS, give me a call. I'd love to get my hands on a diffuser for our shop car. Matt Beenen Engineering |
#941 | |
Driveway labs.
![]() Carl@drivewaylabs.com
#942 |
Hood lift kit
Will this work with the Radium Dual Catch Can Kit ?
#943 |
It's untested, but I can only assume it would work just fine. I would just put the radium bracket on top of our bracket. I'm thinking all holes will line up again fine, despite the slight height change, but you might end up having to slot a bolt hole, but it is extremely unlikely.
Chase Engineering |
#944 |
Drives: Scion FRS Firestorm
Are these hood struts compatible with the Radium catch can setup?
Notice the mounting points in the photos here: http://www.radiumauto.com/Catch-Can-...RZ86-P374.aspx
#945 | |
Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | blackfireball5 (07-27-2017) |
| Replacing Struts and Installing Coil Springs | DarrenDriven | DIY (Do-It-Yourself) Guides | 196 | 04-26-2017 05:15 PM |
| Stock Springs/Struts FRS | jadewbj | Brakes, Suspension, Chassis | 1 | 12-18-2012 11:00 AM |
| WANTED (GA) - Stock FR-S/BRZ struts | xwd | Brakes, Suspension, Chassis | 8 | 11-07-2012 11:43 AM |
| performance/aftermarker struts | karma003 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-07-2012 12:26 PM |
| JDM BRZ Struts different than USDM BRZ Struts? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-30-2012 11:21 AM |
