#15 |
Updated the build to include the new amp rack v2.0. Now with carbon fiber!
#17 |
Drives: 2013 Subaru BRZ Limited SWP
Very nice setup... making me want to put together a setup...
That new PDX V9 is an audible improvement over the older PDX's? I have a PDX4.100 floating around that never made it into my old setup, but I was planning to sell it and get a 5 channel I want to keep the BRZ Navi, so I was thinking of doing a MS-8 to try to get the time alignment and tuning right, but I haven't researched enough to know how well it works inthe BRZ. Sounds like you have a very NICE HU, I used to have an old 980BT which was a step down from their serious SQ Competition decks of that era, but still had some great features like the Burr Brown DSP, 16 band graphic EQ, and time alignment and I loved the sound I could get from it, much better than a lot of HU's that claimed similar or better specs. Too bad you're across the country from me, I'd love to hear it sometime.
Derek
2013 BRZ Limited SWP Professional driver in search of closed course.. |
| The Following User Says Thank You to WolfSongX For This Useful Post: | wheelhaus (04-03-2013) |
#18 |
Thanks! Yes, I noticed an improvement in the PDX V9, but it was mostly due to the better SN ratio; it has noticeably less hiss at low volumes, and overall sounds a slight bit cleaner. Also, with the 4.100 in this car, I couldn't alleviate a subtle ground loop problem (that was not present with the 4.100 in two other cars) that made the BRZ's alternator whine slightly audible around 2-3k rpm. The V9 alleviated this as well, so it made an improvement on several levels.
I've read some singing reviews of the MS8 and that it does a great job with EQ-ing and TA, it's definitely a solid option. I'd love to get one just to play with! |
#19 |
Drives: Scion FR-s
You need to mass produce that amp shelf I so want one!!!!!!!!!!!!!!!!
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake |
#20 |
Drives: SWP 2013 Subaru BRZ Limited
#21 |
Drives: Galaxy Blue BRZ
How have I missed this thread until now?? That amp shelf is *superb*. I'm looking at going the MS-8 + PDX V9 route so this has certainly given me some ideas. Nice job.
| The Following User Says Thank You to Redmist For This Useful Post: | wheelhaus (04-03-2013) |
#22 |
Thanks! I just noticed I hadn't "thanked" anyone in the thread yet, lol... If you need any ideas or help, let me know.
#23 |
Drives: 2013 Scion FR-S (Raven)
Looks great! I'm curious about the receiver kit setup you have. All the ones I've seen have that goofy pocket underneath. Did you just fabricate a panel to around the HU, or was there a kit available?
Edit: Found what you did in another post. I really gotta start searching more often! Last edited by cmarks20; 04-19-2013 at 06:54 PM. Reason: Should have searched |
#24 |
ProCrastinationConsultant
quick question for the OP-- i'm going to be in the same boat install-wise as your original setup-- planning on running the prs80 deck, full active into an f4, and m6 amp.. what made you install the amps under the rear parcel shelf? is there not much room elsewhere in the vehicle to mount them out of the way?
i'm just not crazy about taking away vertical height in the trunk from that method..
#25 | |
I thought about hiding it under the trunk mat, cutting a section out of the foam so it would be completely hidden. Some others have done this but I didn't want it to be a chore to gain access. I wanted to put it somewhere it would be accessible and look attractive, and I like making things, so there it went. The faceplate on the V9 comes off to access a slew of adjustments, so having it high makes for easy tuning. |
| The Following 2 Users Say Thank You to wheelhaus For This Useful Post: | DAEMANO (04-17-2015), soundman98 (04-30-2015) |
| FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 05:34 AM |
| Custom audio in the FRS | Kwise1 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-12-2012 07:27 AM |
| Custom Start-Up Sound/Audio? | joergasm | Electronics | Audio | NAV | Infotainment | 1 | 10-25-2012 04:54 PM |
| Custom Audio Shop | LPC_FRS | Mid-Atlantic | 0 | 09-17-2012 08:42 PM |
| Custom Audio Shop | LPC_FRS | Mid-Atlantic | 0 | 09-17-2012 07:11 PM |
