#15 | |
For the original question, there's no harm in using a bleeder screw in place of the regular allen key, it'll seal the hole just the same. Just remember to bleed from the right one
#16 |
Unbolt the caliper from the bracket, invert it and bleed accordingly. When done re-install. It will be tedious and it will suck for future bleeds.
#17 |
^^ I wouldn't bleed like that, you'll have to remove the pads to retract the pistons after doing that unless you happen to hold it in place on another part of the disc while bleeding.
#18 |
NASA SpecE30 Racer
I don't remember there being anything special about the allen head plug, so if you want to find some in the same thread size and pitch with the same number of threads you should be fine using them.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#19 |
Drives: Legacy GT
I would think that it has something like an -AN taper to seal the caliper.
#20 |
Drives: 2014 Widebody Cosworth FR-S
Bleeders are cheap, readily available and you know they will fit. You could try finding a generic plug, but in the end I'm guessing bleeders will be the easy option.
-Zach |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | TAP Auto Parts (11-20-2012) |
#21 |
I am in the same boat as the OP. I got a pretty beat up set of 2004 STI Brembo's for next to nothing. I have the entire calipers apart for powdercoat/rebuild except for the 4 stripped allen heads. It is like they are welded in there. I used PB blaster, and heat before attempting them.
An EZ out on a 20V litihium drill wasnt strong enough either. Going to reattempt with a plug-in drill tomorrow. |
#22 |
Site Moderator
Drives: Stuff
What kind of torch did you try?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#23 |
Drives: Subaru BRZ Limited MT
To revive an extinct thread....
Just did this last night...fortunately my family owns a chrome plating factory with a decent maintenance department with access to some useful tools... I heated them up pretty hot with a torch as many suggested. Got 3/4 out clean using an impact gun to break them loose. There appears to be loctite on the threads that needs to be heated to a certain temperature in order to free them. The one I stripped, I just hammered in the next size up *english* (as opposed to the 5mm I was using) allen fitting, heated up even more, then backed it out...no problem. You can't use enough heat on these things. I had my entire calipers warm/hot by the time the screws backed out...
My Build Thread: http://www.ft86club.com/forums/showthread.php?t=76898
#24 |
ERO
Drives: '16 Subaru BRZ Series Hyperblue T
Anyone ever find replacement plugs that work properly? I'm also trying to put in all new hardware. I've already Got speed bleeders all I need is plugs?
#25 |
Drives: 2013 Ultramarine FR-S
#26 |
Drives: Exige, Miata, Ghia
It looks like a cap screw. They are dime a dozen at fastenal.
| GRB Brembo caliper on BRZ | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 11-15-2016 03:50 PM |
| Brembo BBKs Announced | oneday | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 83 | 06-11-2014 11:51 PM |
| The price of one Brembo Caliper. | chuttney1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-18-2013 05:32 PM |
| New Brembo BBK installed on shop car | vividracing | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 11-16-2012 02:48 PM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 11:08 AM |
