Old 11-16-2012, 03:42 PM   #15
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Originally Posted by CaptainSlow View Post
Yeah, that's normal. The GTO has enough torque to do it in 3rd...and I think I was able to do it in 4th in my old xA (gear ratio and weight). Also, not advised for long periods of time...slow/partial engagement of the clutch is going to eat up the organic material on the clutch surface faster than if you just engage it and go...but perfectly fine for inching up at a red light or something
So we should not do this and engage gas first then release clutch? I always get different responses to this.
Originally Posted by raul View Post
Any manual car should do that. Your car's idle RPM is enough to propel it forward if you engage the gear slowly enough. Same reason why Automatics creep forward when you put them on Drive gear. Brake doesn't have to be engaged, you just have to be precise. In the FR-S release the clutch slowly until you feel the transmission engage (car will shake slightly, RPM will drop slightly), when you feel that, release even slower.
Yep! I do this to inch forward in a parking spot, etc
Snoopyalien24 is offline   Reply With Quote
Old 11-16-2012, 03:55 PM   #16
CaptainSlow
CaptainSlow's Avatar
That's not what I'm saying. I'm just saying to minimize the amount of time the clutch is partially engaged. Obviously you also want to minimize RPMs while the clutch is partially engaged as well (faster spinning engine = faster wearing of clutch). Absolutely no problem doing this for short periods of time to slowly move up (or back), but I wouldn't drive down the road with the clutch half-engaged LOL
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 11-16-2012, 06:04 PM   #17
fistpoint
Drives: Supercharged Golf Cart
Ready to blow OP's mind...: you don't even need the clutch to move forward. If you just gently press the stick towards first gear, you can move the car that way too at stoplights.*
*of course not recommended, but you can do it. Welcome to the world of manual shifting.
fistpoint is offline   Reply With Quote
Old 11-16-2012, 06:29 PM   #18
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
I think what OP was trying to say was the car will stop you from stalling when slowing pulling out the clutch by automagically increasing engine rpm a bit higher when it drops down below 400 RPM.
I wish I had this on the Evo...(what a pain in the was clutch!)
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 11-16-2012, 06:46 PM   #19
4U-GSE
Drives: 2013 Scion FR-S MT Ultra Marine
The reason this works is because the flywheel is spinning with the engine seperate from the clutch and pressure plate. A flywheel is simply a mechanical means of storing energy. When you push in the clutch the pressure plate pushes the clutch and flywheel together. As long as the flywheel has enough energy stored in it to over come the initial friction of the drivetrain and tires the car will move forward and the engine will not stall. It really has nothing to do with the power of the engine; rather the energy stored in the flywheel and energy needed to overcome the initial friction. The crank shaft and other rotating parts in the engine also add energy but the fly wheel is the most important factor.
For example, the LS2 on the GTO has a flywheel, clutch, and pressure plate weighing about 48 pounds. It's very easy to drive compared with the roughly 22 lb flywheel, clutch and pressure plate assembly found in the lotus elise.
This becomes important if you are going to mod your car with a lightweight flywheel. You give up driveability in exchange for less rotational mass which means the engine revs up slightly faster in low gears. When I had my XRS I went from the stock 16 lb flywheel to a 7.5 lb flywheel. With the stock flywheel I could let the clutch out without any gas and roll forward on a flat road. With the lightweight flywheel I would stall unless I revved the engine a little while letting the clutch out.
2006 Corolla XRS 2ZZ-GE
2013 Scion FR-S 4U-GSE
4U-GSE is offline   Reply With Quote
Old 11-16-2012, 07:13 PM   #20
DarkSunrise
DarkSunrise's Avatar
On my FR-S, from a stop, if you shift to first and accelerate, then let off the throttle (keeping the clutch engaged), the engine will SLOWLY drop revs from 1500 rpm to idle.
It's annoying sometimes because if I'm actively braking, I'm basically fighting the engine to slow the car down in 1st unless I de-clutch. It's like the engine is tuned not to slam the throttle plate all the way closed in 1st. Possible reasons I've thought of are to avoid engine-braking below 1500 rpm in 1st (maybe to smooth out throttle on/off in 1st gear) or to allow for better stop-go driveability. But as I said, it can be annoying.
Anyone else's FR-S like this? I didn't notice it before my ECU was re-flashed.
Old 11-16-2012, 08:34 PM   #21
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
So when I take my foot off the clutch completly, in first gear, without gas, at a complete stop, ALL manual cars will roll forward? I know it will slightly from the friction/biting/engaging point. But past that, without giving gas, it usually stalls?
Originally Posted by TRBO2NR View Post
Almost any manual car will do that...
hmm. this is my 3rd standard car. the other 2 stall when i come off the clutch and do not apply gas. Which is why I thought this was cool. But apperently this is common.
You almost blew me ... but I don't understand. Guess i'll try it next time and figure this out.
grgonium is offline   Reply With Quote
Old 11-16-2012, 09:03 PM   #22
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
If the car idles at a ridiculously low RPM, or the clutch (or the car entirely) is too heavy for the idle RPM to propel the car forward, I guess I could see that happening. I've never owned heavier cars nor trucks. All of my cars have been compacts.
raul is offline   Reply With Quote
Old 11-16-2012, 09:26 PM   #23
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Yes, for most of the manual cars in stock form, as long as you release the clutch carefully before and at the engagement point, you can roll the car forward without gas.
If you simply release the clutch too quickly around the engagement point, the car/flywheel/engine/transmission cannot react to the sudden engagement and thus it will stall. This depends on how you release the clutch, and what the clutch is made off.
As @raul said, the releasing of clutch should be a fast/slow/fast motion: you can release fast from the bottom to the point prior to the engagement point, release slowly/gently at the engagement point, and fast once the transmissions grabs the flywheel from the engine.
Every car has different engagement point. Some are high, and some are low. Furthermore, people have different preferences to have this point high or low. You should try to learn finding the engagement point with this *no-gas* technique first, with either 1st or R gear, to feel the car. Once you know this point from your left foot, it will be very easy to control when you should (dis)engage your clutch given your situation.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 11-17-2012, 10:19 AM   #24
jesperswe
Drives: GT86
Almost all manual cars do that. And here 1 more thing. If you are in second gear and just let go of the accelerator pedal and don't touch the brake or clutch pedal, the car (and all manuals) will slow down and keep going forward at slow speed without stalling.
Not really sure how you get your driving license in USA but here in Sweden this part is one of the thing that you learn in the driving school. :p
jesperswe is offline   Reply With Quote
Old 11-17-2012, 11:26 AM   #25
Foobar
SLO NO MO
Foobar's Avatar
Here in the US, they just hand us a drivers license as a bonus once we get our gun license.
I kid, I kid.
US drivers education programs don't include manual transmission training these days. Haven't done so in at least a few decades now.
Sent from my Galaxy Nexus using Tapatalk 2
Search this Thread:
Advanced Search
Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon WTF Issues | Warranty | Recalls / TSB 12 06-14-2014 11:40 PM
Mine started stalling today Rob_g Scion FR-S / Toyota 86 GT86 General Forum 18 07-20-2012 11:27 PM
