#57 | |
![]() It's better to ask questions rather than worry about things. I remember, back in the day, when I was about 8 years old, I offered to change the oil in my grandfather's new 1950 Pontiac. Yep, he pulled that machine up on a gravel incline in the barnyard so as I could get to the drain plug (and drain the oil down through the gravel into the ground)...... ![]() After I unscrewed the drain plug, and as the oil was draining out, I noticed it was a pretty red color and quite clear. I mentioned that to my grandfather and that it didn't look like the oil needed to be changed. He was not happy with me! I had just drained the oil out of the automatic transmission! DANG ...... what is an automatic transmission? See, I SHOULD have asked a question, but, NOOOOO..... I thought I knew it all .....
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | GoTornado (01-22-2014), Young_makaveli (01-22-2014) |
#58 |
Drives: 2013 Subaru BRZ
I find that our cars take an awful long time to warm up fully. Maybe it's just where I live, weather is always cold most of the time.
#59 | |
Drives: Subaru BRZ Sport Tech Satin White
The temp gauge doesn't have to read very high for the engine to be at proper operating temperature. If you have climate control the engine is warmed up when the heater begins delivering any heat. |
#60 |
There is some great info in this thread. I had someone just yesterday tell me they let their car idle for 15 minutes until the drive it when it is this cold (10 degrees to -40). When I asked why they told me "their dealer told them to". At that point I dropped it...
#61 |
Drives: 2014 Scion FR-S
Anyone got any data on proper engine oil. I try to keep an eye on temps and would like to know the minimum oil temp before ripping on it. I know the water temp hit operating range before the oil. I just went for an easy 20 minute drive and oil temp was 186 when done IIRC
Sent from my SM-N900T using Tapatalk |
#62 |
Oh btw yes this thread it's old as can be but figured it's better than starting a new one. I googled my nuts off and found this one.
#63 |
Just a dude
Drives: Scion FR-S 2013
Common sense says let things warm up. End of discussion?
#64 |
TuRD
Drives: FR-S Mono Mt Fuji Red
Your car is warming up the second you start it. You might as well roll out of the drive and slowly be on your way. Better than just sitting there. Unless you have an on ramp nearby!
#65 |
#66 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
transmission and diff need warming up as well, they also have gears, moving parts, and oil in them.
I just get in car, start immediately, then do all my things like sunglasses, seatbelt, radio, etc. Once I'm done, I drive off. Drive gently until engine/tranny/diff/etc are all warmed up. I see no point in idling for a while unless you're in super cold weather, but that's usually just to heat the interior or defrost windows from what I understand.
'14 BRZ LTD MT DGM
#67 |
Drives: 2015 UltraMarine, MT, Borla Exhaust
When I start mine, it starts at a high Idle, and I religiously wait the minute to minute and a half for it to idle down before starting off, and even then, I drive with Kit Care Gloves until the fluids come to temp. Knowing when I wake up in the morning, I want to wake up a little before being driven balls to the walls... Just Sayin...
#68 |
Drives: Whiteout FRS, Audi A4, 135i (sold)
I never wait. I turn the car on, put it in reverse, drive away.
boooooooooooooooooost
#69 |
Drives: '14 Genesis Coupe 3.8 Grand Touring
I pop the clutch in reverse as my wife pushes me out the garage and floor it.
#70 |
Drives: EVO X
is reverse even necessary? I've seen people that just put it in neutral and just roll down their driveway
| "vent" setting very warm to hot | MTeator | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 02-12-2023 10:35 AM |
| good warm-white LEDs? | Elfreda Blau | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-13-2012 11:06 PM |
| a thought about the warm air coming from the vents... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 08-02-2012 11:06 AM |
| Warm vs cool Weather performance | EsoBOFH | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-10-2012 12:45 PM |
