#29 |
Drives: 2013 FR-S Whiteout
Why is everyone concerned about hydro-locking? Where are ya'll driving? In a lake?
#30 | |
A lot of cars that have CAI wont hydrolock unless you submerge the car into the water. Only an idiot would do that too. I would love to get this duct and add a WORKS drop in filter and a Zeta/Avo silicone tubing. I think all 3 would be VERY nice together. Works claims to add 10 whp and AVO/Zeta both claim about 1-2 whp from changing the tubing. I doubt they would add 11-12 whp to the car but I atleast think that you would see a significant gain then just using the intake duct it self. Also I believe the Injen gets great gains because of the positioning of the MAF so it kinda tricks the car by leaning it out which isnt really a good way to get more power as I have read. The engineers at Toyota/Subaru spent millions of dollars on engineering this car I doubt they would overlock the air box and just put any sort of design on their. Everything you see from the tubing, bends of the tubing, MAF placement all have a reason in the design. Unlike most intake companies who do very little R&D and throw stuff together to make a sale. And with a tune this would probably work even better then any intake on the market, even if those got tuned. Atleast for now since the better companies like Perrin are still doing the R&D on their intakes. |
| The Following User Says Thank You to TwinRz For This Useful Post: | Spartan65 (11-15-2012) |
#31 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
"Ram-Air" was just the first cold-air intake. These days a "Cold-Air" intake is just a smoother intake path.
There won't be any real gains with this. It's before the big restrictions, and the stock intake is already in a cool-air area once the car gets moving. Now what I do see this doing is keeping intake temps lower when the car is stopped or driving slowly. So there's *potential* for it to get you more consistent runs at an AutoX. But I wouldn't expect much. |
#32 |
Drives: Whiteout FR-S
There are some other silicone intake tubes coming to market very soon, i have 2 of them on the way that i will be reviewing. Zeta and Avo won't be the only ones...
| The Following User Says Thank You to JoeBoxer For This Useful Post: | Spartan65 (11-15-2012) |
#33 |
How much is this duct?
#34 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
In Japan it's 12,600 yen about 160.00 but by the time I can get it here probably 300.00?
Spartan65's DROID RAZR
#35 |
I might be in around $200, probably not $300 though.
#36 | |
If in doubt,flat out
Drives: 2013 brz
#37 |
Drives: Skoda Yeti DSG diesel 4x4
It's easy enough to accidently drive into deep water after a storm, assuming it's shallow or not even seeing it. I drove a Subaru Sherpa into a flooded dip in the road during a cloud burst and it actually floated to the other side. The engine had cut out, both cylinders ;-) and I cranked it out with the starter in 1st before it flooded the inside.
The point is it can happen anywhere and catch you out. The other point was that this intake appears to block a large part of the cooling air to the radiators? If it does that's a serious design fault with practical and warranty implications. Apart from that I like it. |
#38 | |
Registered you sir
Drives: 99 impreza coupe
Plenty of the A/C condenser (then rad) is already exposed, this should hardly block any part of the lower grill. @ the people that dont think this would be an improvement.
#39 | |
If this blocks any of the heat exchangers cooling air it's a bad design. |
#40 |
Drives: waiting on a 2021...
[QUOTE=TwinRz;5592
because of Syms intake only changes the front portion of the air box and it gains +8 whp/+10 wtq. Show me another intake that does that right now. It also uses the STOCK AIR BOX, just like this intake duct but the syms is made of carbon fiber so it costs 5 times as much. [/QUOTE] Show me an independent dyno test of this intake. So far the only dyno chart I have seen is from the manufacturer's website. I bet Airaids dyno chart showed a gain with their intake also. Same thing with Works. You have to remember that at speed the whole area in front of the radiator is a higher pressure zone because air won't flow as fast throughout the radiator / A/C condenser as will flow through the grill opening. I wonder what the area of the opening in the front of the filter box is compared to the throttle body or the airflow sensor. I wonder which one actually has the smallest cross section. That will tell you where the restriction lies. |
#41 | |
Registered you sir
Much of the radiator can be blocked without consequence, it still gets plenty of flow. Check out some FMIC setups. |
#42 | |
5" lower!! You are joking of course? That's pure assumption on your part based on a safety factor built in but you have no idea what that factor is in 45c ambient temps. Neither do you appreciate the loss of efficiency as the system ages. There is high pressure in the nose since the heat exchangers restrict the airflow so there is no need to place the intake where they put it. It gains nothing and it puts the engine at risk from water ingestion and overheating. Bad design, it's as simple as that. Last edited by sierra; 11-16-2012 at 07:24 AM. |
| FRS bumper duct | VENOM~ | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 12-12-2015 01:15 PM |
| Carbon Fiber Brake Cooling Duct | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-25-2012 01:03 AM |
| What vendor stocks Team Dynamic | Ricepuddin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 08-31-2012 01:41 AM |
| Brake cooling duct kit | tranzformer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 12-14-2011 02:37 PM |
| forgo foglights for air duct to cool brakes? | Slide | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 11-30-2011 08:58 AM |
