02-10-2016, 10:22 PM | #281 |
Drives: Scion FR-S 10 Series #2263
Ah, that isn't a recall level problem, so I can see why they would refuse to do the work if you are out of warranty. Usually when there is a safety recall, the work can be done regardless of warranty status. The TSB is merely Toyota's instructions for how to fix the specific issue, not a command to fix every car with that issue. I know that isn't what you wanted to hear, I'm sorry...
The Following 4 Users Say Thank You to aegisdrgn For This Useful Post: |
02-11-2016, 02:15 PM | #282 | |
Waited 5 years for this
Drives: '18 MX-5 Club
The Following 2 Users Say Thank You to Sigh-on-Rice For This Useful Post: | FRSBRZGT86FAN (03-04-2016), Ultramaroon (02-11-2016) |
02-11-2016, 02:28 PM | #283 | ||
TSB stands for "Technical Service Bulletin" and it is simply the instructions to the Techs on how to fix the problem. It should not be confused with a Recall which means they have to fix the problem.
The Following User Says Thank You to Tcoat For This Useful Post: | HotLeopardMama (02-26-2016) |
02-11-2016, 03:19 PM | #284 |
1st86 Driver!
Exactly, and if you need proof look at my "weeping" tail light that was not fixed per the TSB because it started less than 200 miles after the warranty period.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | HotLeopardMama (02-26-2016) |
02-15-2016, 03:41 PM | #285 | |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
The Following User Says Thank You to Fenix For This Useful Post: | HotLeopardMama (02-26-2016) |
04-15-2016, 04:13 AM | #286 |
Hey again I just wanted to add this one FOR SUBARU BR-Zs: It is TSB #16-96-15 TCM Reprogramming File Availability for Engine Idle RPM Fluctuation on 6AT- Equipped Models This bulletin announces availability of reprogramming files for optimizing the Transmission Control Module (TCM) on all 2015 and some early-production 2016MY vehicles to control an engine idle speed fluctuation condition when in Park or Neutral. The cause is incorrect operation of a back-up program the TCM uses in the event of a turbine speed sensor problem. Affected vehicles may see a fluctuation of approximately 200 rpm (between 600 – 800 rpm idle speed). I don't have the proper documentation pdf for this one as I don't have access to the Subaru equivalent of techstream, but the issues this fix are the same as 2015-2016 owners were experiencing including myself here: http://www.ft86club.com/forums/showthread.php?t=96615
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: | Sigh-on-Rice (04-15-2016), treminaor (06-03-2016) |
04-15-2016, 03:17 PM | #287 | |
05-16-2016, 07:56 AM | #288 |
1st86 Driver!
Southeast Toyota/Scion Recall of some 2016 FR-S
Another minor recall.
The Capacity Modification Label is incorrect in some models, including the FR-S manufactured 1/28/2016 to 3/14/2016. Details here. Now don't be overloading those vehicles! SUMMARY: Southeast Toyota Distributors, LLC (SET) is recalling certain model year 2016 Toyota Yaris, Rav4, Land Cruiser and 4Runner vehicles, and Scion FR-S, iM, and TC vehicles manufactured January 28, 2016, to March 14, 2016. The Load Carrying Capacity Modification Label may not reflect the correct added weight of the installed accessories. As a result, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 110, "Tire Selection and Rims for Passenger Cars."
The Following User Says Thank You to Dadhawk For This Useful Post: | FRSBRZGT86FAN (06-03-2016) |
05-16-2016, 05:14 PM | #289 | |
The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | Dadhawk (05-17-2016) |
06-01-2016, 11:55 PM | #290 |
my stealership never called me back about the ignition key recall after i contacted them several times..so i gave up trying to get them to look at it especially after i tried to remove the key in another gear than Park and it seems to work as intended
06-02-2016, 01:52 AM | #291 |
Drives: 2016 Halo FR-S
I finally thought to look at this thread and was so happy to see:
S-SB-0021-15 : Idle Fluctuation in Park or Neutral This is the problem I've just been silently dealing with for almost a year. Armed with this TSB and a video I made of the problem, I'm getting this taken care of... FINALLY! |
The Following User Says Thank You to Astral Abyss For This Useful Post: | chaoskaze (06-03-2016) |
06-03-2016, 01:15 AM | #292 |
Drives: 2013 Firestorm FR-S
So with all of those problems listed can I take my FRS to my Toyota dealer to get them fixed? I just bought a 2013 FRS.
06-03-2016, 07:37 AM | #293 | |
1st86 Driver!
A car purchased used can still be under warranty. A 2013 is very unlikely to still be under the 36 month/36K bumper to bumper warranty, although I suppose its possible if it were purchased late in the 2016 model year (the 2013 first went on sale in 05/2012). The powertrain warranty (60/60) may still be in place, and would cover a few of them. If you aren't the original owner and have no proof of when it was originally purchased the dealership will use the VIN to determine the start of warranty, which will be the day it was originally sold. One I would consider getting done is the fuel pump one, but I would put it off until near the end of the warranty period. Not so much because it's a real mechanical issue but because it ends up giving you a new fuel pump.
06-03-2016, 02:27 PM | #294 | |
Bear in mind this is for the auto only
Tags |
chirping, high pressure fuel pump |
Similar Threads | ||||
Recall I think so!!!! | RWD-boxer | Issues | Warranty | Recalls / TSB | 16 | 10-07-2012 10:39 AM |
FRS recall? | totally | Issues | Warranty | Recalls / TSB | 8 | 08-30-2012 12:01 AM |
Recall! already | earthsscum | BRZ First-Gen (2012+) -- General Topics | 1 | 06-07-2012 07:00 PM |
Owners Manual Recall | Opie | BRZ First-Gen (2012+) -- General Topics | 8 | 06-05-2012 10:09 PM |
Did anyone get a call from toyota about a recall yet? | AustinTCLN | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-04-2012 11:45 PM |
