Old 07-02-2014, 08:42 PM   #183
mike the snake
No pics. If you feel up inside the fenderwell it's obvious where you need to grind.
The Following User Says Thank You to mike the snake For This Useful Post:
brzerk1 (07-02-2014)
Old 09-01-2014, 12:20 PM   #184
X Factor
Drives: 2013 Red BRZ Limited
Sorry if I'm repeating this question but I did not see it answered.
Will 18x8.5 w/245 front & 18x9.5 w/265 work on the STOCK suspension with no rubbing/clearance issues?
X Factor is offline   Reply With Quote
Old 09-01-2014, 12:28 PM   #185
brzerk1
brzerk1's Avatar
Drives: SWP BRZ LIMITED
Yes. This is my current set up on stock suspension. Running Hankook Ventus V12. Name:  ImageUploadedByTapatalk1409585314.138100.jpg
brzerk1 is offline   Reply With Quote
Old 09-01-2014, 12:32 PM   #186
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by itdansharpe View Post
No rubbing.
What is your front and rear camber?
Old 03-25-2015, 05:45 AM   #187
Jamesbrz
Drives: White BRZ
How are you guys finding the handling of the car compared to stock? a lot of talk about under steer with staggered setup, if so is it bad
Jamesbrz is offline   Reply With Quote
Old 03-25-2015, 03:23 PM   #188
Agent 86
Drives: 2017 Cayman S
I have the same wheel setup with 245/35 front and 265/35 rear tires. I agree that there is a bit more push, but unless your driving close to the limit, I don't think you'll notice it.
I should mention that I haven't had an alignment done, so i'm expecting even less understeer when that's completed.
I have driven a little more aggressive on back roads, but that's it. On the street, if you are experiencing the understeer you are probably driving a little hotter than I would on public roads.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 03-25-2015, 04:04 PM   #189
congee
congee's Avatar
Drives: SSM BRZ
Anyone have the 18x9.5 all around set up on a silver / white 86??
Is camber needed for both rear and fronts? or just fronts? Scared the 9.5 might be too wide for the front.
New to tires but a local tire shop has RE760 tires 245/35/18 with a load index 88w for cheap. Will those work?? I noticed that the load index is lower than most tires. What troubles will I run into??
congee is offline   Reply With Quote
Old 03-26-2015, 01:41 PM   #190
Agent 86
Not sure if you're looking to see 18x9.5 square on silver/white specifically, but within this thread there is at least 1 car (another color) running that size at all 4 corners.
Old 03-26-2015, 02:47 PM   #191
congee
congee's Avatar
Drives: SSM BRZ
Yeah, looking for a white or silver one specifically with black 9.5 all around. Theres a red, blue marine and a black one in this thread that have the 9.5 set up. Tried to photoshop them but can't get an accurate picture of what a silver one would look like, lowered with the matte black set up.
Old 04-05-2015, 09:35 PM   #192
Jamesbrz
Drives: White BRZ
Hi guys really cant decide weather to go 8.5 square or 8.5 in the front and 9.5 in the rear, I am lowering with coilovers but cant decide due to the fact I hear staggered setup affects handling and I defiantly don't wont that. Also I don't wont any rubbing or out like that any advice id love to hear. Also do bigger brake kits fit no worries with this offset. Thanks
Old 05-12-2015, 07:17 PM   #193
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Hi guys really cant decide weather to go 8.5 square or 8.5 in the front and 9.5 in the rear, I am lowering with coilovers but cant decide due to the fact I hear staggered setup affects handling and I defiantly don't wont that. Also I don't want any rubbing or out like that any advice id love to hear. Also do bigger brake kits fit no worries with this offset. Thanks
go square, 4 of the same size all around. It preserves the neutral balance of the car, but it's only noticable really when you drive at a corner speed to where the tires start slipping so it really wouldn't be noticeable unless you are at a track. Rubbing will work itself out if you are low enough, just don't slam it and you will be fine. Big brake kits fit these wheels fine, look a few pages back there's a silver one with 9.5 I think with a BBK.
Readytoxplod is offline   Reply With Quote
Old 06-02-2015, 09:47 AM   #194
zuurdeegfrs
Drives: Scion frs Raven Black
Originally Posted by GuerillaRacing View Post
Check out the wheels we snapped at SEMA last week... Looks exactly like the ones we brought in for FR-S / BRZ fitment!!
Enkei
Raijin Wheels
18x8.5 +45 front
18x9.5 +45 rear
What do you all think about them?
Will I be able to fit this setup on stock suspension??
Thanks
zuurdeegfrs is offline   Reply With Quote
Old 06-08-2015, 12:30 PM   #195
X Factor
I'm thinking about going 8.5 all around with 245's, any know clearance issues on the stock suspension? I've searched the forum but haven't seen this question asked.
Old 06-08-2015, 01:26 PM   #196
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Given that people are running much more aggressive set ups while lowered you won't have any issue.
KevinK121 is offline   Reply With Quote
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 12:37 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 04:51 PM
Enkei Raijin Mesh Wheels - 18x8.5 / 18x9.5 in custom 5x100 FR-S / BRZ fitment GuerillaRacing Wheels and Tires 193 05-26-2015 06:55 PM
Enkei Raijin Wheels: IN STOCK - 18x8.5 & 18x9.5 Concave Touge Factory Wheels and Tires 27 04-03-2015 06:33 PM
enkei raijin 18x8 raven frs thebear21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-06-2012 04:03 PM
