#253 |
ProCrastinationConsultant
Put a block of wood on the axle shaft and swing harder?
#254 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#255 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
Figured as much; car is four years at this point. I'm gonna assume that bolting the wheel hub back on and removing the axle first won't do me much good?
#256 | |
Site Moderator
Drives: Stuff
If you don't have an air hammer put the axle nut back on until it's flush with the end of the axle and hit it with a BFH.
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | KR-S (05-25-2020) |
#257 |
Drives: Whiteout track car; lava donor
Nineteen pages of great info.
Can anyone confirm that the Vorshlag "65 mm" can be installed in the front without removing the hub from the car? I’ve replaced two stock studs now with stock. Quick and easy without taking off anything but the wheel. The 76 ARP are too long, but seem to be “just” too long to go in without removing anything. I’ll buy a set of Vorshlag "65 mm" to have at the track in case I break more studs. But if the hubs need to come out anyway, I’ll just go with the ARP instead. Thanks for the information. Last edited by Four_wheel_drifts; 06-21-2020 at 06:27 PM. Reason: Grammar |
#258 |
Can ARP 76mm long studs be installed in the REAR hubs without removing the hub from the car?
#259 |
Can confirm the the ARP studs can easily be installed on the front once the rotors are removed. The hubs don’t have to be removed from the car.
Still haven’t attempted the rears. That’s what the off (track) season is for. |
| The Following User Says Thank You to Four_wheel_drifts For This Useful Post: | JohnJuan (10-23-2020) |
#260 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
I don't think you're getting the rears done with them mounted on the car if the replacement studs are longer than stock. When I replaced my rears (with same size studs) I only had to remove the caliper and rotor, and there was a space around the 4 o'clock position where you could line up the stud you wanted to remove/replace without having to remove any other components from the assembly. Anything longer than a stock one isn't going to have the same convenience.
-O/D
2016 FR-S, Hot Lava |
| The Following User Says Thank You to Overdrive For This Useful Post: | Four_wheel_drifts (10-26-2020) |
#261 | |
Site Moderator
Drives: Stuff
-Dave
#262 | |
Drives: 17 Asphalt 86
You can install 63mm(2.5") on the rears with the hub on. You will have to cut the nipple at the end of the stud off, then they will slide in. |
#263 |
This thread has been incredibly helpful for me in replacing my wheel studs, so I thought I'd share my experience as well.
After several stripped or broken studs, I opted to install OEM length replacements from ARP (part number 100-7727, $32 for a five pack from Summit Racing). I was also weary of hammering on my wheel hubs, whether or not the risk of damage was high, and opted for the ball joint separator tool. I picked up the one from Advance Auto (part number W83022, $25), and it worked swimmingly. I didn't need to modify it at all, and it worked to both remove the studs and reinstall the front ones. I'll include a couple of photos below. I also wanted to disassemble as little as possible, not to be lazy (though I am) but to avoid the hassle of rusted on parts (this car is my daily driver in very snowy & salty winters). So I only removed the wheels, calipers and rotors. I greased the bolt threads on the ball joint separator, and used a 15/16" wrench to turn it (all by hand, no air tools). Went a little slow, maybe 1-1.5 hours total per wheel, but it went smoothly. When removing the studs I used the wider jaw setting on the tool, and when reinstalling the studs I used the narrower setting. On removal, the stud would make a loud popping sound each time it moved, usually two pops before it was free, and by the last wheel I had almost stopped jumping every time it happened. Pressing the new studs in on the fronts went fine. The tool didn't fit on the rears, so I did the lug nut and washer method there. I used seven 1/2" washers and a new lug nut. I was concerned about over torquing the studs, so I used my torque wrench set to 89 ftlbs to pull the studs in, and somewhat surprisingly it didn't take a huge amount of force, and the wrench never clicked. Now hopefully I won't have any more problems with the studs. For me it was always when removing a lug nut. It would start to stick rather than come off smoothly and I immediately knew it was done. If it was due to user error, the only thing I can come up with is that I didn't clean off the threads really well before reinstalling, and perhaps a small bit of metal got lodged in there and tore things up. But I never had to meticulously clean threads on previous cars, so I don't know. But regardless, I'll be cleaning the studs and nuts thoroughly from now on just in case. |
#264 |
Drives: '22 BRZ
I installed Eibach's 10mm extended stud/spacer kit using the balljoint spreader tool method on my 2022 BRZ today. Pretty simple as it is on the first gen or most other cars. Warning though, the 2022+ BRZ with aluminum knuckles uses different torque specs than first gens (now 88.5 ft-lbs for the two caliper bracket/knuckle bolts and 70.1 ft-lbs for the four hub/knuckle bolts) but more annoyingly, the knuckle is in the way and there's no way to install extended studs without pulling the hub. Not a huge deal and overall pretty simple!
| The Following 4 Users Say Thank You to DocWalt For This Useful Post: |
#265 |
Drives: 2022 BRZ
If you pull the dust shield, there's enough room on that side to slip the extended studs on the 2022. I was able to do front and rear without pulling any hubs off.
#266 |
Drives: 2022 BRZ
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 05:30 AM |
| Wheel stud | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-11-2012 03:42 AM |
| Lug Nut Stud | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-22-2012 11:26 PM |
| Scion FRS center wheel caps replacement? | Silverback | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-03-2012 03:16 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 01:28 PM |
