Old 11-05-2011, 03:36 PM   #113
jayjayjayjay
Drives: AE86
Originally Posted by tranzformer View Post
Lot of boost there captain with 300psi. That is like 12034278 gigawatts of power.
Holly shit 300whp edited :-)
jayjayjayjay is offline   Reply With Quote
Old 11-05-2011, 03:38 PM   #114
madfast
Drives: 2010 Evo X MR-T
Originally Posted by ryridesmotox View Post
Im 100% convinced that forced induction is the way to go SC or TC. Depending on the flow characteristics of the motor I do believe a properly sized turbo is better due to:
1) less parasitic loss on the motor, SC uses a pulley, TC obviously uses exhaust gas. This allows for more WHP because the turbo uses less of the engine's energy to operate the turbo than the SC.
2) Due to the less "drag" on the engine, fuel consumption will be very close to stock
3) with the technology behind new turbos, spool lag is almost non existent (twin scroll design, ball bearings instead of journal bearings, "exotic" compounds like ceramic)
yes all true. but also irrelevant imo. the only thing to care about it the end result. if it takes hp to make hp, so be it. as long as the NET hp is good enough for you. when you go up in boost, or hp goal, then yes SC wont cut it. but for this car, for most people, i still vehemently believe SC is better suited. but who knows. lets get the car, you can slap a turbo on it and make a believer out of me. and i'll do the same with a SC kit
I believe we win either way.
that said, the roots style is not very efficient in general, but it is quite reliable and makes good power. Also if you want something more efficient, I'm sure procharger will come out with something as well.
not AS efficient, but WAY more efficient than it used to be.
but what you give up in efficiency, you gain in flat torque curve, throttle response, proportional boost, less heat, better packaging, easy pulley swaps, etc.
PS: thanks for a civil conversation on FI
madfast is offline   Reply With Quote
Old 11-05-2011, 03:43 PM   #115
jayjayjayjay
Drives: AE86
I didn't see this earlier... dude I'm sure you mean 30psi... maybe I dunno. but lemme help you out here... You select your turbo based on what kind of duty your car is doing. For example: a drag car will want a large turbo to increase flow in the upper rpm range to make more peak hp, a road or autox car would want a turbo a bit smaller than a drag car because you want a larger, more tractable powerband with a big meaty torque band. Usually for a dd you want a smaller turbo that spools quickly, but not so small as to congest the exhaust and cause excess backpressure. A daily driver turbo would build max boost +/- 3000rpm because, generally speaking that's the kind of range where you are going to be running quite a bit of the time. Keep in mind also, when you start doing turbo or supercharger builds, you will be moving your powerband to where the particular set up is most efficient, regardless of the stock powerband of the motor.
So in conclusion, you need to figure out what you want to do with the car first and foremost... then you make decisions on your build.
Nice reply. What 300 whp (my error). Drift track car only. Quick spooling. Was working on approx 8-10psi max. Assumption 25-30 hp gained through engine mods.
Preference to run E85.
Old 11-05-2011, 04:31 PM   #116
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Originally Posted by MatadorRacing_F1 View Post
TRD had a package for the tezza to take it to 270hp
That kit had the vvti delete, 13.5:1 compression, itbs 295 duration cams on both sides? Question: did the kit increase the stroke? How high did it rev to make that power?
cyde01 is offline   Reply With Quote
Old 11-05-2011, 06:17 PM   #117
Matador
hashiryu
Drives: Mk4 Supra
Foggy on the specifics, but I can tel you they changed;
Cylinder head Gasket
Piston&Piston Ring
Bearing
Connecting Rod
Crankshaft
Valve train system
Lubrication system
Intake(Quad-set independent throttle)
Exhaust
Think it revved to around 9k rpm.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 11-05-2011, 07:43 PM   #118
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Originally Posted by PuGZoR View Post
Oh, there's a bit of an issue with the option of transplanting a turbo WRX/STi engine into the FT86 for Australians. There's this crappy piece of legislation that says engines can be transplanted legally (I know this is a mere technicality for some people) if they're younger than the build date of the chassis they're being put into. Of course if they're intended to be a track car this isn't an issue, but for those that want to have a turbo FT86 on the road it is.
Thats the same rule thats here in California.
It won't be a problem in a couple years when more newer model WRX/STI's/Legacy/Forester turbos are wrecked and have drivetrains available, but in the meantime it can be a more expensive affair since you would need a 2013 or newer donor car.
Kostamojen is offline   Reply With Quote
Old 11-05-2011, 08:14 PM   #119
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
I plan to get ITB's on the FT... Even if I'm the first to do it!
Snaps is offline   Reply With Quote
Old 11-05-2011, 08:37 PM   #120
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Originally Posted by madfast View Post
supercharger? moving powerband? not if done right:
gains across the board. flat as flat can be tq curve.
Absolutely I couldn't agree more. In both charts it moved the torque band lower and broader, without the V-tec bump that you usually see around 6k rpm. Thanks for helping to prove my point, plus I don't really think of a civic SI or RSX as having a power band... more like a rubber band. I'm kidding, some Civic Si's are fast, I just haven't found one yet.
Couldn't agree more
That's funny cuz I was going to go find the flow charts for the little TVS's that Eaton makes. People in the SC'd cobalts are easily putting down 300whp with those, and supporting mods.
LOL no problem, it makes me laugh so hard when people get all crazy and emotional about it. Only one thing really matters... Performance! And everyone needs a certain criteria for a certain application. SC'd or TC'd it is going to be fun as hell with over 300whp in the automotive version of a track shoe. So... when I meet you at the track we can make a pass, or do our fastest lap and :happy0180: with no hard feelings dude.
E85 only if tuning can support that. The engine should easily be able to support ethanol due to the port injection. It's super easy to swap those, as opposed to a DI injector. I would think that people could get 50whp easy from bolt (ons, intake, header, exhaust and a tune) because DI responds quite well to tuning, in my experience with my car anyway.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
Last edited by ryridesmotox; 11-05-2011 at 09:04 PM. Reason: I needz teh speeling mod!
ryridesmotox is offline   Reply With Quote
Old 11-05-2011, 09:30 PM   #121
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Like this?
[u2b]ta6iJiKbfHg[/u2b]
quik1987 is offline   Reply With Quote
Old 11-05-2011, 11:59 PM   #122
serialk11r
Drives: '06 AM V8V Coupe
That doesn't have air filters...wouldn't stuff start blowing up pretty soon?
Old 11-06-2011, 03:56 AM   #123
cyde01
cyde01's Avatar
I'd like to also some day, but i have a bad feeling this car is gonna be dbw. Lets hope someone makes a good itbs kit and an ecu that can tune it.
Old 11-06-2011, 11:43 AM   #124
Barike
Drives: MB 300SD
Looks to me like it isn't complete either... That's an aweful lot of turbo piping that doesn't go anywhere. Just my $0.02 and my first post
Barike is offline   Reply With Quote
Old 11-06-2011, 04:20 PM   #125
Sully
Drives: In the market for something fun
Originally Posted by celicajim View Post
Wonder if Cosworth will have a go at the FA20?
Or even just s/c kits(Miata has one). They have engine kits for subaru's now, so we can hope. As well as the ford ducatec/mazda mzr. PRETTY ITB's for those engines So maybe...
Of course, cosworth is a really pricey option.
But hey, quality costs. Buying aftermarket the first few years will really be a crapshoot as far as quality/reliability. But cosworth will almost certainly be perfectly fine and trustworthy from day one.
Sully is offline   Reply With Quote
Old 11-06-2011, 07:01 PM   #126
Major Clod
Drives: RA23 Celica
My mate actually has 2 Beams 3S's in his garage, haha. His daily is a turbo'd 4A powered KE70 sedan
Another Brisbane Beams owner here - I have a Blacktop 3SGE in my '76 RA23 Celica. Great motor for a small car - glad the FT86 is similar in output, though I have to admit I'm ever so slightly disappointed it's specs are just under the Beams which was released 12 years ago.
On all the talk about extracting power out of these - High compression, small capacity, direct injection - sounds like its going to be an expensive / complicated little motor to mod and tune in the early days. Here's hoping there are few brave souls out there that get the ground work going on discovering any potential this motor may have.
Unless you're really willing to pay someone money to essentially do all the RnD for you - you're better off swapping for a proven Subaru turbo motor now (if laws allow) - or waiting until there has been some solid development done on this engine.
For reference, one of the most powerful modded N/A beams motors here in Australia makes approx 190kw at the wheels - stock is around 110-120kw atw.
This is with TRD headers, custom quad throttles, dual stage injection, motec, cams, pistons, rods, head work, etc... Built over years of trial and error with multiple motors and thousands upon thousands of dollars spent. Significant power can be extracted but it's NOT easy and its NOT cheap for these sorts of motors.
Major Clod is offline   Reply With Quote
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 09:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 10:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 05:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 10:46 PM
