#99 |
Drives: subatoy
Turbo kits go for around $5k plus around $1500 for installation.
For $6,500 you can buy a WRX engine and put it in the car and maybe save some money. the mounting points are exactly the same for the pure reason that they want to allow people to swap for other Subaru engines. This car would be an insane beast with a newer 265hp Subaru engine. |
#100 | |
Is a Monster
Drives: AE86, MA70
#101 |
Drives: ZZT231 Celica
Wonder if Cosworth will have a go at the FA20?
#102 |
Long time obsessor
Drives: AE86 & depressing SUV
Oh, there's a bit of an issue with the option of transplanting a turbo WRX/STi engine into the FT86 for Australians. There's this crappy piece of legislation that says engines can be transplanted legally (I know this is a mere technicality for some people) if they're younger than the build date of the chassis they're being put into. Of course if they're intended to be a track car this isn't an issue, but for those that want to have a turbo FT86 on the road it is.
IIRC HKS or GReddy used to have some pretty cool kits designed for fitting a turbo to a NA engine. Not only did it come with the exhaust manifold, turbo, lines, etc, but they also came with low comp pistons and that kind of thing. Fingers crossed that there's no inherent weak points in the engine that would stop kits like this being made, and that they've made it as over-engineered as they have previous engines. |
#103 |
Drives: Slowly
#104 | ||
hashiryu
Drives: Mk4 Supra
#105 | ||
Drives: '12 BRZ [CBS]
#106 |
Drives: AE86
What might be interesting for FI fans is to go for the smallest possible turbos to keep the weight gains down. Smaller turbos will also keep lag to a minimum. 300psi (edit to 300whp) with lower boost keep weight down will see the car on a lot of drift tracks.
#107 | |
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
2010 Chevy Cobalt SS Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91 |
#108 | |
Delights in pure handling
Drives: Zoom Zoom
#109 | |
So in conclusion, you need to figure out what you want to do with the car first and foremost... then you make decisions on your build.
#110 | |
Drives: 2010 Evo X MR-T
assuming the ECU is tuneable, the hardest part will be to either 1.) convince a major manufacturer to adapt their SC kit to the boxer, or 2.) custom kit that isnt horribleim 100% convinced that supercharging is the way to go, for this car. we'll just have to wait and see...
#111 | |
1) less parasitic loss on the motor, SC uses a pulley, TC obviously uses exhaust gas. This allows for more WHP because the turbo uses less of the engine's energy to operate the turbo than the SC. 2) Due to the less "drag" on the engine, fuel consumption will be very close to stock 3) with the technology behind new turbos, spool lag is almost non existent (twin scroll design, ball bearings instead of journal bearings, "exotic" compounds like ceramic) That said though, the SC is nearly instant boost... I say nearly because there is a bypass in most modern SCs. This allows for better fuel economy at cruise speed. The bypass closes almost immediately, and much faster than a turbo builds boost. Plus I love the sound of a SC when you put the hammer down (that whine/grown makes me cum in my pants). I believe we win either way. And hopefully someone does make a SC for these cars, I'm sure Eaton will come out with one... they made some for the old cobalt ss, so they are experts in making small, very efficient SCs that play to the advantage of a "smaller" displacement 4 cylinder (that said, the roots style is not very efficient in general, but it is quite reliable and makes good power). Also if you want something more efficient, I'm sure procharger will come out with something as well.
#112 | |
![]() ![]() gains across the board. flat as flat can be tq curve. |
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 09:53 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 10:22 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
| Super Bowl! | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 01-29-2010 05:02 PM |
| Super Lap Battle | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 0 | 12-10-2009 10:46 PM |
