#197 |
MODERATOR-SAMA
Drives: Swagtron Scooter
whoa whoa whoa....ok this thread is getting muddied up.
Sorry Driftster, I had to reread everything you have posted these past few pages..and I THINK I finally understand what your talking about. But you know what your problem is? You talk to much! you add so much information and fluff to your posts that your point gets lost and nobody really gets what your trying to say so they respond to you without addressing what your post means. What your trying to say....correct me if im wrong! 1. That this engine specifically, could be more friendly to CURRENT average turners if this engine was a basic design. Without DI, without fancy pistons, without high compression. To cater to a wider variety of current tuners be it N/A or Turbo users..Having that basic design for tuners to build on without defined factory limits. Right? 2. That your angry that Toyota and Subaru, very capable companies built a engine for this sports car, that has very strong defined limitations. And they have the audacity to claim the engine and car was built for enthusiasts and tuners..when only a small population of tuners can even freely precision tune this "tuner friendly car" IF this is correct...i totally get you... but you really didn't have to post SO much information to get your point across.
#198 |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
#199 | |
Drives: N/A
I'm not reading all of that!
A turbo kit might make +50HP before stuff gets dangerous , a EJ207 swap would make +100HP with room to grow.There is no cheap option either way. |
#200 | |
Rocket Bunny FRS
Either way your looking at over 5k+ to buy the engine and put it in. on a already 20k+ car |
#201 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
well it's true that the bluetop 4a-ge had lower compression, big ports and a strong block that could handle a lot of boost with stock internals.
later generations were less boost friendly stock with higher comp, itbs, etc etc but still remain very popular with tuners. i see fa20/4u-gse as toyota/subaru starting off with the blacktop/silvertop (optimized n/a engine)rather than the blue top (not a lot of stock performance but good for n/a tuning or boosting). if toyota/subaru tried to build an engine that was good both for boosting and n/a tuning, i believe we would have all been disappointed by the stock performance numbers. either way a supercharged version is supposedly in the works. who knows, maybe with some creative plumbing even the turbo fa20 going in the next gen wrx might fit in the frs/brz. |
#202 |
Drives: Reanult Megane R26
The vast majority of cars won't get tuned. The high compression and direct injection do make a large difference to fuel consumption.
The pressure on OEMs to improve fuel consumption is fast becoming the first priority for new cars, whether it be from customers or from governments. If they had ditched the hgih tech engines for sonething more tuner friendly they probably would have also had to ditch the idea of selling the car in Europe too and that is the biggest sports car market in the world. |
#203 | |
Hot Dog
Drives: quicker than arghx7
The only thing I can make out is: *You're scared aftermarket tuners are incompetent with DI strategy *OEM has locked or encrypted the ECU, making reverse engineering of ECU strategy difficult *static CR is too high to add boost and meet power demands on pump gas Does that just about sum it up?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#204 | |
Drives: 2013 Firestorm FRS
The combination of port and direct injection is going to help a TON with the people who want to go FI. Its not going to hinder it. Especially if the fueling set up can easily be converted to e85. There is also plenty of room to mount a turbo kit aftermarket. EASILY. The extra few inches in piping isnt going to make so much of a difference that when you drive it you are going to think "damn that extra 5 hp would sure come in handy now" Everything you are saying is almost complete over generalization and paranoia, with a smidge of 86 hate thrown in for good measure. I dont see what all the worry is about. This is going to be a very popular car. The aftermarket support is going to be great. Besides that a 2.0l na motor making 200hp from the factory with pre installed 12.5:1 pistons would be a K20 owners dream come true. Im sure someone will develop some cams and with bolt ons and a tune Im sure there will be 210-225whp 86's running around in no time. if the aftermarket community wants this car to be fast. It will be fast. Frankly knowing subaru I am more worried about how the tranny would hold up if someone boosts the car to the 250-275whp range, than I am about the engine internals, or turbo kit fitment. |
#205 |
By the way. A turbo wrap blanket will keep the heat down. You can touch one of those blankets with your bare hands after someones been running the car. No worries about "melting a serpentine belt" or whatever hyper paranoia people were blathering about a few pages ago. Calm down.
#206 | ||||||||||||||||
Supra Owner
Drives: 1995 Toyota Supra UK Spec
, I'm sure it was more performance-oriented than that!Quote:
![]() Quote:
#207 | |
Drives: 1992 Toyota Supra
#208 | |
hashiryu
Drives: Mk4 Supra
A similar unit (AZ6, Aisin designation) would also be found in the RX-8, S2000, S15 Silvia etc. It's easily at least as strong as the W58 (400hp|300ft/bs?), although we really wouldn't know where the limits are of this particular box until it's in the hands of capable tuners and they reach the point where they break them.... So speculation is fairly useless. The auto is IS-F based, for sure that will easily support at least 400hp/400ft-lbs torque as they say it's the same (minus 2 gears). I think the tranny and diff are the least of your worries. Everybody ranting about power this and power that keep forgetting how light this car is. At 2850lbs with 400whp, it's approaching the power-weight ratio of the LFA/458 Italia/Gallardo Superleggera/Z06 C6 vette. At 300whp it's already blown past BPU Supras, IS-Fs, M3s, C63s, RB26 Swapped S13/14s, Standard C6 vettes and approaching GT-R levels. Seriously guys... As an engineer, tuner, racer and car lover I admire your enthusiasm but please, grab some perspective. |
#209 |
Hot Dog
I haven't seen anyone be able to prove either way so far. If you have proof a turbo can't fit in the engine bay, please share.
#210 |
hashiryu
Drives: Mk4 Supra
1LR-GUE V10, 12.0:1 Compression ratio.
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 09:53 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 10:22 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
| Super Bowl! | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 01-29-2010 05:02 PM |
| Super Lap Battle | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 0 | 12-10-2009 10:46 PM |
