#169 |
Action Thriller
Drives: E46M3
just swap for an EJ257 and call it a day.
#170 |
Drives: Toyota Supra SZ
Why would you wan't to swap out a superior engine for and old and quite frankly inferior engine just because it came with a turbo from factory?
Id gladly turbo charge the 86 as it is and see what it can do. With direct injection you can take liberties you couldn't before with port injection. |
#171 | |
Drives: N/A
If you do either one, I highly doubt you could sell the car without incurring a huge loss. So it's up to you. Just don't disrespect the car(s) or someone else's opinion and you won't get any problem from me. If bolt-ons make the 230-260BHP that people want/need for bragging, that should cover 99% of the drivers. The 1% who can afford to swap the engine or turbocharge can do it. |
#172 |
Drives: 2006 Subaru LGT
#173 | |
High CR petrol turbo setup's aren't a rare thing in this day and age so it's not something i'd worry about as I like to push boundaries that others dare not to but that's just the way I think. |
#174 | |
Drives: '20 Hakone 86
I agree with this statement for the most part. Pro drift cars now adays have full teams as support, thus having the funds to do whatever regarding an engine build/swap. In D1 and other Japan series, I'm sure they'll stick with this motor setup, if not, switch to a 1J/2J setup. Here in the states, where we ruin everything, they'll more than likely swap it out for a built LS motor. V8s are really the only way to be competative in Formula D now and it sucks. Grassroots drivers in most cases are running mid-high 300s. Especially with the S chasis. 400hp is about the limits for an SR with a stock block and the tranny is notorious for grenading at just over the 400tq mark. Plus, unless you're trying to drive on a competative level, you don't need 400hp. If 400hp is the only way you can initiate and maintain a drift while staying on line and control your speed and angle......you cant drift. PS. not aiming this statement directly to anybody, just making a general statement. |
#175 |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
I'd Be happy with 300-350 hp on this thing!
#176 |
MODERATOR-SAMA
Drives: Swagtron Scooter
We have discussed this in the past...if the BRZ would go turbo, theres a large chance that the system would use silimar dimensions to current Legacy Turbo Locations.
2010+ legacy EJ255 turbos are lower front mounted just below the engine front cover, eliminating the uppipe found on impreza models, and providing more turbo response being closer to the exhaust ports. This is unlike the picture you posted and can be used compactly.
#177 |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
Turbo in front of the engine?
I think there is definitely enough room there... Remove the noise tube and the other thing near the airbox and I think you'll have plenty of room there. If it's heating up the belts too much, it's not hard to make (or get one made) a heat shield to block that problem, though I've never heard of problems with V8's having turbo's mounted in front of the engine.
#178 | |
MODERATOR-SAMA
We are a group of people from a wide range of places and professions...I do not claim to be a engineer nor a professional, I only know from my own experiences and what iv seen and what iv read. Which I use to contribute to a list of questions that could be used to find an appropriate answer. So based on the knowledge I have at hand, the ONLY reasonable direction i can come up with to answer to this thread is talking about how the current Legacy and the 1.6DIT locates their turbos...snug up against the front cover and oilpan. Plus im having a hard time trying see your point when comparing the legacy and impreza bay to the BRZ. Now I may be wrong, but you don't need to try to make me feel like an idiot. This is the location that iv been thinking of that would be viable. Its location does not interfere with anything besides the radiator which in the BRZ/86 is slanted.This way is similar to the Legacy Turbo Configuration and Its about the same dimensions and compactness of the FA/FB1.6DIT while also being built to be low slung.
#179 | ||
hashiryu
Drives: Mk4 Supra
#180 |
Troll Feeder
Drives: boosted scion tc.
i just hope they work it so an S cover can fit. i've been limited to a B compressor cover for a long time on my scion and it has been a real headache.
#181 | |
Troll Feeder
#182 |
Troll Feeder
i stand corrected. you are right he switch back to the 2az.
i couldnt find if he switched due to rules or if he switched because of the high HP the 2az can handle. |
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 09:53 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 10:22 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
| Super Bowl! | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 01-29-2010 05:02 PM |
| Super Lap Battle | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 0 | 12-10-2009 10:46 PM |
