Old 01-16-2014, 05:49 PM   #43
xia
Drives: 1995 Supra TT & 2013 FRS
Originally Posted by DjDATZ View Post
Shouldn't this be as easy as just ordering a new bumper in Whiteout? Sure the paint might not match 100%, but tbh, it'd probably be cheaper than getting it fixed and then resprayed.
Also, I doubt there's nearly as much fade-difference on a Whiteout vs a Raven...
Where can I buy a brand new frs bumper painted in whiteout already? Please share. I want a spare.
xia is offline   Reply With Quote
Old 02-05-2014, 04:50 AM   #44
BanzaiZee
Street Ninja
BanzaiZee's Avatar
Drives: 2013 Whiteout FR-S
I know it's not as big as a bumper, but I had my 5 AD spoiler painted to match my whiteout (won it from a raffle and it came unpainted) and it looks fine. I was trippin' over if it would match and honestly... you can't tell. It was painted by a friend of a friend who has a small garage.
BanzaiZee is offline   Reply With Quote
Old 02-05-2014, 12:46 PM   #45
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
the curves really help hide any color match issues. if it were two flat panels butted up against each other it would be much more noticeable. sounds like you got a pretty good match though if you are happy with it
Old 02-05-2014, 04:55 PM   #46
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Straight from the factory the paint on my whiteout bumper and hood/fenders don't match. As others have said its the plastic bumper vs metal.
Just get the bumper painted and don't sweat the difference. Any good body shop should be able to do a match.
When I had my spoiler painted and installed they got the match perfect. That is fiberglass right up next to metal.
jadewbj is offline   Reply With Quote
Old 02-13-2014, 11:47 PM   #47
636
636's Avatar
Drives: '23 CWP BRZ
Shit from factory my rear bumper doesn't match, apparently it's super hard to paint match Whiteout.
636 is offline   Reply With Quote
Old 02-14-2014, 12:44 PM   #48
spitfire481
Drives: 2JZ FRS
I did two hours of tinting and spray out test cards to get a match on a whiteout bumper. It hasn't been installed on the car yet but it should hopefully look better than the factory match (or lack there of)
Old 02-14-2014, 01:22 PM   #49
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
I am on the same boat lol I am just going to buy another aftermarket bumper. Maybe Ings+1 or something else.
TOTO_86 is offline   Reply With Quote
Old 02-14-2014, 01:28 PM   #50
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
I was also thinking of this bumper, but I am not sure because of the turn signals lol
http://www.body-kitz.com/contents/me...t_bumper_1.jpg
Old 02-15-2014, 02:23 PM   #51
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
There is no certain technique for the pear coat to be laid on is there? Like will there be a difference in the look of the satin from the factory compared to aftermarket (in certain angles, due to thickness of layers, the application technique, etc...)
Old 02-15-2014, 04:51 PM   #52
spitfire481
Drives: 2JZ FRS
Application all depends on the paint system being used. The number of pearl coats will change the appearance both straight on, and on an angle. That's why it takes so much testing before actually spraying the car/part.
Old 02-27-2014, 11:41 PM   #53
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Originally Posted by MISTERLUCAS View Post
I work at a Toyota Certified Collision Center and we work on most makes. A few things I feel you guys need to know.
You bumper doesn't match as it is right now. And I haven't even seen your car. You will never find a metallic or pearl bumper that matches. The way paint dries and lays on plastic is different than metal.
They are correct that 'blends' on adjacent panels will help. The reasons being: When painted at the factory they have certain settings for the air flow, which would differ at every shop. This affects the way a pearl looks. So even on a metal adjacent panel a pearl will look different sometimes even with a blend. Your eye will be cheated though because the bumper will blend into the adjacent panels but adjacent panels then may not match panels further away.
At the factory they don't paint your bumpers on or even with the car. They are painted with a close variance on a different line. They pick one and put it on your car.
What you need to do is find a trusted, well maintained and up to date shop. Look for Water-borne paint logos usually indicating that they are up to date. Have the painter come out and discuss the variant, ask him for a swatch so you can pick the match. But don't blend all those panels, it won't help in the long run.
OR
If somewhere can fix the bumper then the match will already be there. They can 'blend' within the bumper panel and you should be fine.
^This^
But also there are a billion different tones of whiteout that different shops use. The "pearl whites," my friend had to have his tc repainted three times. It's not as much as finding the right paint but a shop that can match the color the best. Theres a shop around my area guarantees a match or they'll redo it as much as you want them to free of charge.
Vincenttam is offline   Reply With Quote
Old 04-04-2014, 03:47 AM   #54
suaveflooder
tri-stage colors are a total pain to match, especially if you are not blending the adjacent panels. it doesn't matter if you go to a dealership shop, or a lone guy who works out of his garage. it all depends on the paint system used, how well the painter can apply a tri-stage, and how well the painter can tint the paint system being used. i am a painter, and i would never own a pearl white car. take that for what its worth lol.
Yup, I just installed a stillen spoiler. While it looks AWESOME! It did not help the process at all. The entire car is smooth, the spoiler is sharp, that alone changes the color. Add in the variance in pearl, the white is slightly too light and you can tell in certain lighting. Funny part is that it's not really noticeable to anyone else but me, but I agree with you. I had to have the wing painted twice. The first time was too dark and a total eye sore. I could see it no matter how I looked at the car. The second time, it's a touch too light, but at least it doesn't stick out. I have to look at it in a specific light to notice. I'm quitting while I'm ahead No one will know but me really.
suaveflooder is offline   Reply With Quote
Old 04-04-2014, 03:50 AM   #55
suaveflooder
hmmmm….this is good to know. Maybe, I need more pearl. Straight on it's perfect. Add an angle and it goes off a bit.
Old 04-04-2014, 07:17 PM   #56
spitfire481
Drives: 2JZ FRS
On the bumper I did I had to spray 6 coats of Pearl and a drop coat. With my ppg envirobase system your basic pearl coat is considered 3 plus a drop coat. Color looked decent dead on. The flop (on an angle) was way too light at 3 coats. Almost a dead on match when I tested with 6 plus the drop. Matches the car way better than the rear, factory bumper matches the car lol
The Following User Says Thank You to spitfire481 For This Useful Post:
suaveflooder (04-05-2014)
bumper, color match, good body shop, new bumper
Search this Thread:
Advanced Search
White out paint match ?? xpicer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 10-11-2012 01:04 PM
Son of a @#$*&!!! I found out my dealer drilled holes on the front bumper RYU Scion FR-S / Toyota 86 GT86 General Forum 40 09-12-2012 08:23 AM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 03:02 AM
weak paint on bumper 1strwdcar Cosmetic Modification (Interior/Exterior/Lighting) 6 08-15-2012 10:19 PM
Bumper Plugs for License Plate holes by dealer? mikeg7827 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-13-2012 06:33 PM
