Old 12-27-2013, 06:43 PM   #1527
xDanger_208x
xDanger_208x's Avatar
Drives:
Not bad. I'm just trying to get an idea of when they'll have my EL header/front pipe/over pipe done. It's been almost 6 weeks.
xDanger_208x is offline
Old 12-27-2013, 06:47 PM   #1528
FR-S Matt
They're probably making sure it gets done right and with the holidays, that sounds about right. Hang in there man, they'll make sure you're taken care of.
FR-S Matt is offline
The Following User Says Thank You to FR-S Matt For This Useful Post:
xDanger_208x (12-27-2013)
Old 12-27-2013, 07:46 PM   #1529
toeout
I ordered my UEL on 11/08 and haven't gotten it yet. Just a point of reference.
toeout is offline
Old 12-27-2013, 08:03 PM   #1530
FR-S Matt
Yeah, a lot of us in the groupbuy were waiting for a while. Trust me, it will be worth it. The JDL UEL made my car a TON more exciting once it was on. The engine will love you more for it.
toeout (12-27-2013)
Old 12-29-2013, 04:36 PM   #1531
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Just installed the headers! They sound great! I just have one concern. One of the pipes ever so slightly touches the oil pan. Anyone else have this problem?? If so is it something to worry about in the long run?
IAmNotTheDriftKing is offline
Old 12-30-2013, 09:13 AM   #1532
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@bprayogo had the same issue with oil pan....look up his post on page 69
Fizz is offline
The Following User Says Thank You to Fizz For This Useful Post:
IAmNotTheDriftKing (12-30-2013)
Old 12-30-2013, 02:04 PM   #1533
IAmNotTheDriftKing
Originally Posted by bprayogo View Post
Finally I received the long awaited package being thousand miles from you here in Indonesia Im a bit worried the header wont fit nicely .
But hey its a OK except for 1 small problem .. the header touch the oil pan a bit, the remedy for me is to double the right side gasket . and all is well .
A nice piece of art! great sound very addictive, and great power according to my butt dyno , going to the real dyno soon
Did you have any problems with the oil or the pan? With this slight touch?
Old 12-30-2013, 07:13 PM   #1534
BRZFern
Drives: 2013 SSM BRZ
I've had mine for almost a month and no issues. The contact with the oil pan is very minimal...just a pinhead, but it's been a concern on the back of my mind. I'm not sure if the contact will cause any issues in the long run, but considering how HOT the header gets, I don't want it touching the oil pan. I'm changing the oil this weekend and haven't torqued the bolts a second time after installing the header, so I plan on adding a second gasket on the passenger side also.
BRZFern is offline
Old 12-30-2013, 07:16 PM   #1535
IAmNotTheDriftKing
This seems to be the quickest and easiest solution to the problem. Do you think that adding a second gasket would cause any leaks in the exhaust.
Old 12-30-2013, 07:50 PM   #1536
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I would look and see if anyone makes double thick gaskets vice putting two on...I know grimmspeed makes some for the wrx.
GR86 MT premium
StormTrooper is offline
Old 12-30-2013, 07:57 PM   #1537
BRZFern
I'm positive won't cause any leaks. Had @bprayogo not pioneered this fix, the only thing I would question is if adding the second gasket would be successful to disassociate the two. I can let you know after this weekend just for the additional confirmation.
BRZFern is offline
Old 12-30-2013, 08:54 PM   #1538
IAmNotTheDriftKing
I got the grimmspeed ones on the car right now. They are only 20% thicker than the OEM ones, the header still slightly touch the oil pan. I will google search other possible makers of gaskets.
Old 12-30-2013, 08:56 PM   #1539
IAmNotTheDriftKing
Well he said he did, but he never said anything about leaks, so I guess I can assume it works. And please do tell if it works. I don't want a busted oil pan or hot engine oil.
Old 12-30-2013, 11:14 PM   #1540
xxscaxx
Drives: 2013 SWP BRZ
My replacement header didn't have any clearance issues with the oil pan. it was close, but it wasn't touching.
xxscaxx is offline
Search this Thread:
Advanced Search
UEL Header Development 86drift Engine, Exhaust, Transmission 77 07-07-2016 02:45 AM
SRT Header Back Exhaust System Intro Piricing Swift Racing Technologies Engine, Exhaust, Bolt-Ons 51 09-25-2012 11:00 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
