#99 | |
^_^
Drives: 2013 BRZ Galaxy Blue Silica
I think that the mpg can only accurately be calculated by filling up the tank, setting the odometer to zero, running the tank down to near empty, filling up again and seeing how many miles you went and how many gallons you put in on the 2nd fillup. I can easily see that instantaneous mpg might be something crazy if you are driving along and suddenly let up on the gas or coast. But an average mpg for a whole tank is probably the only way to accurately determine the fuel economy. Because, after all, 99mpg isn't impossible for a few seconds while you are coasting, but that isn't going to save you any money at the pump unless you can do it for a whole tank repeatably.
2004 WRX sedan Java Black Pearl (manual)
2013 BRZ Galaxy Blue Silica (manual) |
#100 | |
tires arent what causes the size of the contact patch. its primarily a function of weight and tire pressure. whether it was on prius tires or 275 hoosiers, the tire the contact patch wouldnt really change in size. |
| The Following User Says Thank You to fatoni For This Useful Post: | carbonBLUE (10-28-2012) |
#101 |
Drives: 2010 Cooper S, 74 Beetle
#102 |
Drives: Attitude
Yeah, for a base model maybe...Germans gouge you on options.
There's a $20K USD difference in the base models those cars here. Heated seats? $500. Bluetooth? $750. iPod/USB adapter? $400. Navigation, alarm, handsfree (smartkey) entry? $2700. Bam, you've made a 1 Series M that costs twice as much as the BRZ and has comparable amenities. Yeah you're getting more, but you're paying more...whether it be a powerful AND more efficient engine, or the typical BMW accouterments. |
#103 | |
If we did not have insane HP taxes in Norway, but only CO2 like we have. Price difference would only be 15-20% extra for M135I (with many options!) compared to 86. (Since the 86 is quite bad on fuel consumption) In many other EU countries without stupid taxes price difference is not that much. yeye.. If you wanna talk about the M135I this is a better thread to do it in.
#104 |
Drives: Attitude
Again, point was that HERE the difference in money is what gets you that.
THIS car (the 86) is overpriced across the pond. Hell, it's overpriced here. I'm not saying it's a great engine either, it's just half as much as the one you're talking about so it's kind of expected that consumption vs. output isn't going to be as impressive. |
#105 | ||
Drives: Supercharged Golf Cart
By "shocking" I meant a modern V6 that can't do 20 city when a heavier(250+lbs) 420hp V8 vehicle comes damn close(the auto V8 GT). It shouldn't be close at all with such huge hp differences(278 vs 420). The 4 bangers of today from nearly every maker except BMW are still similar in mpg to that of 20 years ago. Yes I realize the cars have increased in weight, but so did the BMW's They just have magic engines I think.Quote:
I agree with this 1000x If the FR-S got RX-8 mpg numbers, I wouldn't even spend another second considering buying one and find something else. |
| The Following User Says Thank You to fistpoint For This Useful Post: | RaceR (10-28-2012) |
#106 | |
Drives: 12,000 miles per year
http://www.performancesimulations.co...on-tires-1.htm Sure, weight and tire pressure are the biggest factor when it comes to contact patch size, but all else equal, a wider tire will put down a larger contact patch than a more narrow tire. I did notice that you said "wouldn't really change", so I suspect that you already know that wider tires generally mean wider contact patches. |
#107 | |
#108 |
The poor fuel economy of the RX-8 is something that always steered me away from those cars. I never could understand how such a tiny engine could return such horrible fuel economy (for its size). The other thing that I don't like is the weak torque output too. Those rotaries just aren't very good when it comes to torque.
#109 |
www.fueleconomy.gov/feg/make.shtml
Searching by make, I am sticking with my original claim that BMW simply makes magic 4 cylinder engines considering the 240hp numbers equal most manufactures sub 200hp 4 bangers. Magic engines. "Lt. Dan, you got a magic engine!" |
#110 | |
Reverse Burnouts
Drives: 2013 Argento FRS
This is because of the simple fact of PSI, Pounds per square inch. If you have 35 psi in a tire and a car weighs x amount at that corner of the car, the weight of the corner of the car will only imply so much downward force on that wheel. ie 500 lbs in one corner only the contact patch would only be 14.9 square inches. now if you were to let some air out to 28 psi, the tire's contact patch is now 17.9 square inches. now those measurements are all relative but gives a simple explination that wider tires doesn't automatically mean a wider patch of contact unless the pressure is set accordingly. [ame="http://www.youtube.com/watch?v=r_IWa_qlt3g"]2013 Scion FR-S - YouTube[/ame] in that test they probably didnt use less tire pressure to take advantage of the bigger wheels, which resulted in the same cornering speeds because the contact patch didnt actually change because the same air pressure was used, if they had let a few lbs of air out the car would have made a faster lap time regardless of the fact that the wheels were indeed heavier.
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#111 |
Drives: 2013 FR-S Blue MT
Fuelly shows the 2012 BMW 328i at 25mpg average, whereas the FR-S and BRZ are at 28mpg average. Just because they are rated for 34mpg in the EPA test doesn't mean they actually acheive it in the real world.
There isn't anything magic about Turbo engines, they take just as much gas as a bigger engine to make (big) power, its just that they don't use so much when low output is needed. |
#112 | |
Drives: 2013 DZE/01 (sold for MX5 ND1)
After 5000+ miles in my BRZ 6MT (mostly short-around-town trips and only 1221 miles highway), I've averaged 29 MPG: 32-36 MPG highway 25-29 MPG in town (27-29 if I drop two of my fill-ups) That's 50-70% more than what my RX8 got, 30-40% more than my old 2L WRX, and is also better than what people report with the 328i. Anecdotal, but on par with what others seem to be getting. I've never felt the "everyday driving is below 5k RPM" argument to be especially persuasive. It's true that we spend most of our time at low RPMs, but that's simply because most of the time we don't need more than 30-50 hp. When I want to pass, I drop it into 3rd.
Last edited by Deslock; 11-01-2012 at 07:32 PM. Reason: Updated since I hit 5k miles |
| Canadian fuel economy different rating | Oilers99 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-04-2012 09:16 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
| Optimistic fuel economy? | nubbster927 | BRZ First-Gen (2012+) -- General Topics | 15 | 07-05-2012 09:50 PM |
| Subaru shows courage to cut horsepower for fuel economy | [es vi: eks] | Engine, Exhaust, Transmission | 11 | 05-01-2011 03:02 PM |
| Fuel Economy | Lexicon101 | Engine, Exhaust, Transmission | 38 | 02-22-2010 04:50 PM |
