#15 |
#16 |
Drives: Legacy GT
No, and those are for people using sti bearings and uprights that want to keep 5x100. The front brz uprights are completely different and sti or tribeca hubs don't bolt in. The only way to do it would be to make a custom upright. The rear sti hub and bearing might work. Someone just has to go try it.
Doing it just for the bolt pattern is pointless. The reason to upgrade on a wrx is for the stronger bearings, and unless people start blowing them out after a couple track days no one's going to bother with a conversion. |
#17 | |
Drives: Australian GT86
bulletproofautomotive have the Kicks 100 - 114.3 spacers. |
#18 | |
Every Mackin dealer has those spacers but as pointed out they ruin the ability to run decent offset wheels. A few months ago they talked about 10mm conversion spacers but they have not been released as of yet. |
#19 | |
I have some works VSKF in 114.3 I picked up for nix that are +38 and +42, so it might be ok... |
#20 |
Drives: FR-S, NA8, S13
even running a 15mm conversion would leave you with almost 10mm of stock stud... most wheels, cheap wheels anyway, wont allow it without a back pad that has enough room recessed to allow that much stud sticking out.
just order correct sized 5x100 wheels. |
#21 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Some of us already have 5x114 wheels from other cars. Currently two of my cars use 5x114 bolt pattern, but I also have two with 5x100 and two with 4x100.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| The Following User Says Thank You to Miniata For This Useful Post: | dori. (10-25-2012) |
#22 |
Drives: On track
Dont forget about your brake rotors...or finding some that will work with the FRS/BRZ brakes and a 5x114.3 bolt pattern.
#23 |
Drives: Legacy GT
#24 |
Registered you sir
Drives: 99 impreza coupe
5x114.3 conversions will continue to be an unrealistic dream for this car.
#25 |
Yeah, I'd just look at selling the wheels you have. And due to the popularity of the car there will be a gazillion 5x100 wheels out for the car in no time.
Custom uprights = $$$$ |
#26 |
Drives: 2013 Whiteout Scion FRS
Yeah, I think you all would be better off selling your old rims and buying a set of the tons of 5x100 rims out and coming out.
Other than the bolt pattern there is no benefit to the hub switch so it is really only for people who have an old set of rims they are not willing to sell, not a large market. |
#27 |
Drives: On track
| Some news about the BRZ release in NZ - mispost, see front AU/NZ forums | Metabrz | Australia Classifieds | 0 | 10-03-2012 02:44 AM |
| Chances of Someone Developing 5x114.3 HUBS (not spacers)? | Entropy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-04-2012 04:35 PM |
| 5x114.3 | jdmboss86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 06-30-2012 04:12 AM |
| Bolt Pattern, Wheel Hubs and Studs | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 03-08-2012 03:49 AM |
| Replace stock hubs with different bolt patern ones? | ahausheer | Other Vehicles & General Automotive Discussions | 12 | 02-07-2012 01:24 AM |
