86WORX
Old 10-22-2012, 03:39 PM   #15
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Actually the previous cases were with prokit and some teins IIRC.
OP: Did you impact on the strut top nut?
This post is irrelevant as my comment was directed to incorrect installation of the springs(doesn't matter which brand or spring) by over using an impact on that top nut.
But anyways just to stroke your ego(OP has been edited)... http://www.ft86club.com/forums/showt...ghlight=eibach
lol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-22-2012, 03:54 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
lol
Yep, cause that's what I'm here for, my ego.
If you read that thread you'll see that Eibach (and myself somewhat) pointed out that the sportlines weren't even on sale yet. Those were Prokit springs, the very ones I mentioned in my post.
My point was that this isn't related to the Sportline springs like your post made it sound.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-24-2012, 12:42 PM   #17
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Clunking, missing bumpstops and leaking struts? I'd suggest getting the Eibach bumpstops and taking a part the suspension to inspect everything. Also, take a look at this link that was already quoted above.
Originally Posted by Jackson View Post
What happened? There's a couple of things. I'm by no way discrediting your friend or Toyota technicians. I am simply posting this information for others to see so they do not make a common mistake with installing our spring kit or other spring kits.
We found out the hard way that if you zap off the factory top nut with an impact gun that you can actually spin the shaft internally causing it to click. If you spin the shaft too far this will cause the shaft to come disassembled internally and could, over time, cause the shock to leak. There is a special tool that needs to be used to lock the shaft from spinning when assembling and disassembling the front suspension.
If the special tool was not used and something else was used to hold the shaft, this could cause scoring on the shaft that could damage the internal seals, thus causing the damper to leak.
Has your friend called Eibach directly so our techs can help diagnose what is going?
Jackson is offline   Reply With Quote
The clutch is clunking Ashley Scion FR-S / Toyota 86 GT86 General Forum 22 11-14-2021 11:30 PM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 08:42 PM
Eibach Pro Kit - In stock! No Limit Motorsport Brakes, Suspension, Chassis 3 08-15-2012 06:21 PM
Eibach Pro Kit IslandImportPerformance Brakes, Suspension, Chassis 1 07-19-2012 12:33 PM
Eibach Pro Kit WithNolock Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-30-2012 12:50 PM
