Old 12-01-2016, 02:50 PM   #463
Kris86
Kris86's Avatar
Drives: RHD Gt86
Any companies do rhd gauges pods?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 01-07-2017, 06:34 PM   #464
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
Any photos of Block8Head with 60mm gauges, guys?
In1t is offline   Reply With Quote
Old 01-10-2017, 05:24 PM   #465
Irace86
Drives: BRZ + Ducati M796
Bought the Ortiz custom dual pods. I plan on running oil pressure and oil temp there and running a 60mm boost gauge in the vent. It'll be a few months before it comes in. Any tips on where to port the gauges to?
Irace86 is offline   Reply With Quote
Old 01-11-2017, 02:43 PM   #466
snowdog
Drives: 2013 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=108488
I did the Ortiz dual pod a while back. Works great.
snowdog is offline   Reply With Quote
Old 03-17-2017, 03:38 AM   #467
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
https://goo.gl/photos/T5UtodbPqQkNqtHt5
I got to installing my Defi gauges in the ATI ring vent pod and the Ortiz pod. I'm running boost/vac, oil pressure and oil temp.
Old 03-21-2017, 01:25 AM   #468
Irace86.2.0
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
BirdTRD (04-28-2020), Rosticles (03-22-2017), Suparu (05-28-2020)
Old 05-15-2017, 02:13 PM   #469
Njjawn
Drives: None
I waited long enough for something like this to be released, and gave up. Fits 3 52mm gauges perfectly. I'm relocating the USB/AUX to be under/above the 12v in the center console.
Njjawn is offline   Reply With Quote
The Following 2 Users Say Thank You to Njjawn For This Useful Post:
BigHugeFatGuy (08-25-2017), michaelxchristopher (06-28-2018)
Old 05-15-2017, 02:29 PM   #470
reeves
Are the gauge pods pointed slightly inward, towards the driver? Or are they simply facing out directly straight/parallel?
reeves is offline   Reply With Quote
Old 05-15-2017, 07:32 PM   #471
Irace86.2.0
They are pointing in at an angle.
FYI, I finally got the relocation bezel with the new glued on switch. Im not sure if I will attempt to do the same job they did better because their cutouts looks like an amateur Dremil job. I could imagine I could do better. Also, in retrospect, I probably could have wrapped the new cluster bezel fake carbon fiber like the rest of my interior to cover blemishes. I may try that but it isn't high on my priority list.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
reeves (05-16-2017)
Old 06-08-2017, 10:46 PM   #472
nunonuna
nunonuna's Avatar
Just spotted this while browsing ebay
I thought to share for someone if anyone like this.
http://www.ebay.com/itm/13-15-Subaru...FYr19S&vxp=mtr
nunonuna is offline   Reply With Quote
Old 06-08-2017, 11:24 PM   #473
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Late reply, but Blitz offers it w/ their gauges.
-alex
Old 06-09-2017, 08:54 AM   #474
Kris86
Kris86's Avatar
Drives: RHD Gt86
-alex
Thanks for the reply, I already got a custom 3 gauge pod made
Old 06-26-2017, 01:57 AM   #475
Irace86.2.0
I decided I didn't care for their repainted switch relocation bezel so I modified the stock one. Their bezel left only one of four tabs. Mine has three of four, including the screw. I made an aluminum cutout so when dremeling I wouldn't over-cut. It isn't perfect of course but an improvement without needing to paint and looks good enough that I can live with the imperfections.
Breadman (05-08-2021)
Old 06-29-2017, 11:17 PM   #476
Heat Sinker
Drives: 2016 FR-S
http://www.ft86club.com/forums/attac...1&d=1427586304
With this set up, do you need to modify to car to make the gauges fit or is it as simple as putting them in?
Heat Sinker is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) -- General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) -- General Topics 17 12-12-2011 12:39 PM
