Old 10-20-2012, 10:11 PM   #29
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by Racecomp Engineering View Post
below
thanks. appreciate your contribution.
what i really mean is a sticky FAQ thread.
Nardi330 is offline   Reply With Quote
Old 10-20-2012, 10:22 PM   #30
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Oh sorry BRZ ATL....my point was this about BRZ perch and sTOCK shocks....
I think the issue would be that you would RAISE the front of the car 5mm if you used it with stock shocks......
something thats not an issue with coilovers as you can just lower the perch.
Myles
I see, so how do you recommend those of us with stock shocks and RCE yellows to keep the Com-C's from binding up with the OEM welded flat washer? Is it possible to use WRX upper spring perches without the welded washer and then use the OEM conical washer to allow them to contact the right area of the Com-C inner bearing? That way the ride height isn't changed.
Either way, I think something needs to be in between the upper spring perch and the Com-C's. They were hitting each other over bumps when I used the Com-C's. I think that the FLAT-ness of the OEM welded washer is also not playing nicely with the angle it's attacking the Com-C bearing due to the increased negative camber added.
Old 10-20-2012, 10:29 PM   #31
ATL BRZ
Driving Coach
ATL BRZ's Avatar
I don't want to have to buy coilovers just to use the Com-C's without destroying them or compromising the ride height given by the RCE yellows.
It's reasonable to expect the combination of parts included in the RCE suspension starter pack to all work together or at least be tested to ensure this kind of issue doesn't arise.
Old 10-21-2012, 11:38 AM   #32
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Bump
Old 10-21-2012, 12:06 PM   #33
Adding a conical washer on top of the OEM spring perch MAY solve your issues. It will add maybe 5mm of ride height though. You can't use the older Impreza spring perch because the spring diameter is not the same.
The WL tops were tested on our car and have been working fine on many cars. The fact of the matter is, and I'm sure you'll agree, the quality control on both the bearings and the rubber of the whiteline com c mounts is very disappointing. I think the bearings you received were bad, and I think the rubber in your tops was deforming too much too. Frankly if I were you I would not feel comfortable running the WL tops anymore and we're a little disappointed ourselves. At this point I would recommend group n tops with the AVO control arm bushing, which is what we are running now. If you want to try the conical washer on the OEM perch with the com c tops, its worth a shot but if you want to get rid of them we would like to help.
- Andrew
Old 10-23-2012, 06:09 PM   #34
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
FWIW, a video of the stock top hats while turning the wheel while stopped showed the exact same behavior.
TomR
ABQautoxer is offline   Reply With Quote
Old 10-23-2012, 06:44 PM   #35
D1cker
Drives: B9 S4/ND2
Oh ok, well that makes sense. I'm going to install the washers tomorrow morning (just got them in today) and I'll see if there was any change. The mount spins freely when out of the car.
D1cker is offline   Reply With Quote
Old 11-11-2012, 08:56 PM   #36
Nardi330
Nardi330's Avatar
Drives: 86
i thought i'd just continue here rather than starting a new thread regarding my issue with Com C and KW.
i had the above installed by a mechanic on Friday with the Subaru conical washers and it was fine for a few days. then after getting alignment done today, the right hand side is making knocking sound while turning. the alignment guy only undo the 2 big bolts at the bottom of the strut and didn't touch the strut top. he got me to turn the steering while putting his hand on the Com C rubber and he said he could feel the knock from it. does this mean the bearing is bad now?
thanks in advance.
Old 11-11-2012, 09:25 PM   #37
ABQautoxer
ABQautoxer's Avatar
Is it a loud PING sound?
TomR
Old 11-11-2012, 09:34 PM   #38
Nardi330
Nardi330's Avatar
Drives: 86
no, it's just "knock" "knock" "knock" as i turn. the rubber seems to be in proper shape (ie. not like the video posted by OP).
Old 11-11-2012, 09:42 PM   #39
ABQautoxer
ABQautoxer's Avatar
It's your helper spring slipping on the coupler to your main spring possibly. Lube it with teflon spray.
TomR
Old 11-11-2012, 09:44 PM   #40
Nardi330
Nardi330's Avatar
Drives: 86
thanks. let me try this. very much appreciated.
would lithium grease be ok to lube? i have a spare can at home.
Old 11-11-2012, 10:04 PM   #41
ABQautoxer
ABQautoxer's Avatar
Sorry that's actually what I meant. Use sparingly due to dust/dirt attraction. You can also try WD40 type stuff since it might actually get between the spring and plastic spacer.
TomR
The Following User Says Thank You to ABQautoxer For This Useful Post:
Nardi330 (11-11-2012)
Search this Thread:
Advanced Search
+++ALL INVIDIA PARTS FOR FRS/BRZ (N1, Q300, FRONT PIPE) at AMAZING PRICES! +++ genometuning Engine, Exhaust, Bolt-Ons 249 01-17-2015 10:51 PM
Took her to the NASA Auto-X at VMP today! (video inside) xjohnx Tracking / Autocross / HPDE / Drifting 4 08-27-2012 10:54 AM
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 09:06 AM
Idle RPM dip.... video inside. CSG Mike Engine, Exhaust, Transmission 24 08-17-2012 02:45 PM
My fists are made of hams. Paint help question inside... Mitch Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-14-2012 03:05 AM
