Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 05-27-2013, 10:09 AM   #43
Whitigir
Drives: 450 awhp twin turbo vr4
The second gear is like that to many cars, even in my old vr4. It is not a bad sign. Take steps
1/ warm up the car idling
2/ throw into second gear, even if it is not going in, keep on it, dont force it, and it will go in.
This has to be the design of the transmission with the safety mechanism, but you are fine. Try change transmission oil, it will work better as this was what i did in my vr4
Whitigir is offline   Reply With Quote
Old 05-27-2013, 12:41 PM   #44
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Yeah, mind doesn't like second while cold either. I also find myself getting hung up on something when downshifting from 5th to 4th quite often. You really can't move the stick "diagonally" at all when doing that or there's some gate or something that it catches on. Very annoying. That happens at all temps.
Ganthrithor is offline   Reply With Quote
Old 05-30-2013, 10:52 PM   #45
maverickar15
maverickar15's Avatar
Drives: 06 STI
1st-2nd is smooth once it gets to working temperature. Before it gets warm, I take it easy while shifting 1st to 2nd because it feels like I'm grinding it even when I'm not.
13 SWP BRZ
06 WRB STI
maverickar15 is offline   Reply With Quote
Old 05-30-2013, 11:19 PM   #46
Subie
Seņor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I don't have as many issues shifting into second as I do shifting out of it. When cold, it tends to "stick" in second making the 2-3 shift a bit more labored.
Subie is offline   Reply With Quote
Old 05-30-2013, 11:24 PM   #47
radroach
Drives: car
I had this for awhile too. Learned that if I go slower in second, stick in the powerband for a bit longer and basicly "push" the car from 2nd, giving a little more throttle right before shifting, I can usually get a 2nd-3rd gear shift with much smoother syncro action.
Old 06-25-2013, 11:49 PM   #48
synister808
Drives: 2013 Subaru BRZ
Just hit 1,000 miles, and my 2nd to 3rd started to be clunky. It's like something is not lining up.
synister808 is offline   Reply With Quote
Old 06-26-2013, 07:51 AM   #49
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Machines are designed to work at work temperatures. Let it warm up properly. The engine is NOT the only thing that needs a warmup. There's the differential and suspension system, for instance. Anyone involved in racing knows what 'cold' tires can / cannot do.
BRZfan is offline   Reply With Quote
The Following User Says Thank You to BRZfan For This Useful Post:
Ganthrithor (01-09-2014)
Old 06-26-2013, 07:52 AM   #50
BRZfan
BRZfan's Avatar
Old 01-07-2014, 11:39 AM   #51
ZeHeadBanger
Stuck like Glue
ZeHeadBanger's Avatar
Drives: WRB BRZ Limited
Late to this party, but I too have been having this issue from the time I got the car. I currently have 7800 miles on the ODO.
Frankly, I thought this was one of the safety mechanism features installed on the vehicle that saves you from shifting into second gear at high speeds. I see the logic in this as my friend blew his engine up when he shifted accidentally from 5th to 2nd on his e46.
This problem is at its worst during cold weather and right now its buttfuckin' cold, here in Michigan! So it takes a lot of time to heat the engine up.
Also, if it helps others, once you start driving and the issue is still present, try changing gears below 7mph. That kinda works for me, though its not really smooth. As I drive along and the trans oil heats up, it goes back to its 'buttery' state. Frankly, I love the MT in BRZ and this is just something I have agreed to adjust to while driving!
ZeHeadBanger is offline   Reply With Quote
Old 01-07-2014, 11:00 PM   #52
Darkrune
Darkrune's Avatar
Drives: 2017 86
Originally Posted by Mochikomi View Post
Double clutching helps for large skips and keeps your synchros more healthy. eg. Downshifting from 6-3, 5-2 or some such can either take longer or put a lot of work on the synchros, but if you double clutch it will slide right in.
It's also a good thing to have in the tool belt in case you have a synchro fail. It's not necessary, but it still has its uses.
Darkrune is offline   Reply With Quote
Old 01-07-2014, 11:42 PM   #53
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Yeah, same issue here. Can shift into 2nd no problem, downshifting is a different story.
Old 01-08-2014, 02:47 PM   #54
radroach
Drives: car
Have you considered using an engine block heater or a transmission heater?
Old 01-08-2014, 09:04 PM   #55
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Actually, I find the BRZ warms up quite quickly. You can tell by the climate control. The engine itself warms up more rapidly than the temperature gauge would indicate because the temp sender is downstream of the thermostat, as it is on most cars.
The transmission should begin shifting smoothly in cold conditions after just a few miles. Only the first couple of shifts are baulky. I expect the transmission will get much smoother with mileage, most do.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Old 01-08-2014, 09:27 PM   #56
ZeHeadBanger
Stuck like Glue
Nope, never actually thought of that! Might try that!
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 08:15 PM
Backfire when shifting canu_50 Issues | Warranty | Recalls / TSB 39 09-27-2012 02:55 AM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 04:28 PM
Paddle Shifting switchkick Scion FR-S / Toyota 86 GT86 General Forum 13 08-14-2012 04:29 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
