86WORX
Old 07-28-2015, 02:47 AM   #71
Lust
Drives: 2017 Subaru BRZ
I just had the Perrin transmission mount stiffener and rear shifter bushing installed. It improved the shifting feel for sure. Anyone have experience with the whiteline kit in comparison to the Perrin? I could be wrong but I don't think that the Perrin trans mount + rear bushing + whiteline kit would work together or am I wrong?
Lust is offline   Reply With Quote
Old 09-30-2015, 02:43 PM   #72
Lord09
Drives: 2015 BRZ
A bit OCD, but any tips for aligning the stock T-bolt when installing the whiteline bushing? Mine is rotated slightly when tightening the 17mm nut.
Lord09 is offline   Reply With Quote
Old 09-30-2015, 02:51 PM   #73
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
same here. wont affect anything if you're looking at it
Old 11-15-2015, 03:31 PM   #74
shdobxr
Drives: 2015
Just put in the whiteline kit along with the Perrin rear bushing. Great write up. My son and I kept cracking up about the parts about "much force needed". We kept making Star Wars jokes. Indeed the force was needed on that dam Perrin bushing.
shdobxr is offline   Reply With Quote
Old 11-15-2015, 09:46 PM   #75
shdobxr
Drives: 2015
So what I can say about the kit is that there is a small amount of increased drivetrain noise but that is to be expected from all of the polyurethane bits carrying noise better. However after the gearbox warms up 1st to 2nd is much easier. Including 2nd to 3rd up shifts. However 3rd to 2nd is extremely improved when downshifting.
Old 11-22-2015, 12:59 PM   #76
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Just did this yesterday. I don't know where people are coming up with added drivetrain noise with just the bushing. I do have an exhaust but it's a Perrin, so it's pretty quiet, and I know what transmissions sound like (had an STi with PU shift bushings, very loud whine).
Definitely improved shifts, probably due to less flex between the transmission mounts since this effectively makes it so that the rear mount doesn't have as much give. The factory setup is two pieces of rubber sandwiched inside of the mount, likely to separate the chassis acoustically. You're stuffing poly into that sandwich.
On a lift, this should take you about 45 minutes if you're going slow and reading instructions. It's that easy.
Luftwaffel is offline   Reply With Quote
Old 11-22-2015, 01:41 PM   #77
mscamp02
Drives: 2013 FRS
very nice write up. Looks like I need to place an order.
mscamp02 is offline   Reply With Quote
Old 11-25-2015, 05:16 AM   #78
kuno
Help people, I followed the suggested torque setting for the rear # 1 mounting insulator at 50 ft lb as shown in the pic and stripped one of the thread. I can't tightened it well now. Does it matter if i leave that bolt it much as it is currently securely hold by the rear #2 mounting insulator. Or do i need things like heli coil insert to fix the stripped thread?
kuno is offline   Reply With Quote
Old 11-25-2015, 06:58 AM   #79
shdobxr
Drives: 2015
I'd take it to a shop and point out the problem. Shouldn't be an expensive thing to fix. This is your drivetrain its kind of important. Sorry that happened to you. Let a pro do it. Good luck!
Old 11-25-2015, 01:41 PM   #80
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I don't think the picture in the thread and Whiteline's provided torque specs match. Specifically the one that says 48 ft lbs in the picture. I seem to remember them all being 30 ft lbs.
Old 11-25-2015, 02:48 PM   #81
kuno
Yeah they dont match. I must have followed the torque on the picture. Well I learned my lesson. Has anyone here used the loctite thread repair ?
Old 08-05-2016, 12:45 PM   #82
Leland
Drives: BRZ JDL uel headers oft Perrin 2.5
Just on the odd chance anyone is still reading this thread, does anyone know of any comparisons between the Whiteline and the Torque solutions parts? They seem the same design. Speed factory lists stiffness ratings for the Torque solutions but I cannot seem to find any such information for the White line piece. Anyone know how they compare? Thanks.
Leland is offline   Reply With Quote
Old 08-07-2016, 12:17 AM   #83
zc06_kisstherain
Drives: SWP BRZ
^you probably wont feel anything between two. i still would go with whiteline though
Old 11-18-2016, 12:41 PM   #84
Silverfrs86
Drives: Silver Ignition 2013 frs
Whats up guys! I just ordered the perrin shifter bushing and the whiteline transmission bushing but i ordered it in black; is there a difference between the black and the yellow or is it just looks to add some color to the tranny mount?
Sent from my LGMS631 using Tapatalk
Silverfrs86 is offline   Reply With Quote
bushing, diy, positive shift kit, whiteline
Subaru Dealer Whitelist (positive experiences, truthful dealings) Deslock BRZ First-Gen (2012+) -- General Topics 285 05-15-2023 06:35 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 08:45 PM
IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! 10k Redline Brakes, Suspension, Chassis 6 10-16-2012 06:32 PM
which one is positive and negative frs Scion FR-S / Toyota 86 GT86 General Forum 1 08-04-2012 11:42 PM
Speaker wiring. Positive or negative?? |-Goku-| Electronics | Audio | NAV | Infotainment 9 07-28-2012 11:24 PM
