#29 |
Drives: Whiteout FR-S
Excellent writeup. I don't think I have read a more thorough and well thought out review of a product. Nice job making the exhaust work and not just returning it in a panic like some of us probably would.
| The Following User Says Thank You to JoeBoxer For This Useful Post: | F1point4 (10-14-2012) |
#30 |
Drives: '13 DGM BRZ Limited
You mention that you followed Grimmspeed's directions to remove the overpipe which doesn't involve jacking up the engine. Did you have to jack up the engine to install the Perrin overpipe or were you able to snake it in from the top?
| The Following User Says Thank You to cnk For This Useful Post: | F1point4 (10-14-2012) |
#31 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
I can only imagine how hard it is on jack stands. While possible, it would not be fun breaking loose the oem nuts that hold the exhaust in place. Last edited by F1point4; 10-14-2012 at 11:29 AM. |
#32 |
Berz
Looks great! Are you using the OEM exhaust bushings, or did you upgrade those as well?
#33 |
Photo Specialist
#34 |
1500$ for a headerback? Good lord. You can't even hear the resonated version!
Really nice build quality. A bit disappointing that you need to hammer your car so that it doesn't rattle, though.... |
#35 |
Berz
#36 | |
Photo Specialist
Let us know how your install goes |
| The Following User Says Thank You to F1point4 For This Useful Post: | 2pt5RS (10-14-2012) |
#37 |
Drives: 2013 Asphalt FR-S
Well done review! This exhaust is fantastic. Now, I hate to be that guy, but specs on the wheels???
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#38 | |
Photo Specialist
Since then I lowered the car on Racecomp Engineering Yellow Springs. |
| The Following User Says Thank You to F1point4 For This Useful Post: | Opposed (10-14-2012) |
#39 | |
Drives: 2013 BRZ, 2002 WRX
![]() The presence of the flex joint ahead of the resonator is what caused our issues. The combination of heat and the presence of that flex joint allowed the resonator to move away from the installed position and start making contact with the body. The cold/hot photos show the deviation in position between cold temperatures and hot. If you have similar clearance, I would suggest running to the auto store and picking up some radiant foil like we used. While driving around, I pulled the e-brake boot and slid my hand between the carpet and the body -- HOT! Really, really hot. After banging-out the small u-shaped channel and applying the radiant foil, I could hardly feel any heat in that same location. It may save you from a slow deterioration of the metal in that shaft tunnel.
#40 |
Spaceman
Drives: 2013 Firestorm Scion FR-S
Love this writeup.... thanks.
Perrin is definitely a top contender for my exhaust dollars.
#41 |
Drives: 2013 FR-S Argento MT
Nice write up....and nice Europa!
#42 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
how many hangers do we need?
| Tags |
| exhaust, headerback, perrin |
| Perrin Catback Exhaust vs Nameless Performance Exhaust. | vignesh | Engine, Exhaust, Transmission | 201 | 06-05-2013 10:47 PM |
| NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! | AJ@ECSMotorsports | Engine, Exhaust, Bolt-Ons | 31 | 04-06-2013 10:05 AM |
| Brand New SRT Headerback Exhaust System | prest1ge | Southwest | 5 | 10-16-2012 07:06 PM |
