#15 |
Drives: '13 Ultramarine
My car came from the factory over filled (between 1/4-1/2 quart) and I never had any issues because of it. Others have reported the same. That said, your bumper does look pretty ugly...are the insides of your exhaust tips greasy with oil residue?
#16 | |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Later today I will take a pic of the current level.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#17 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
That much shouldn't really make much of a difference as long as you don't beat on it nonstop. But if your worried just jack it up and drain a little bit
#18 |
Team ScioNRG President
Drives: 2017 WRB BRZ
To be honest, from my experience with the EJ engine series they are very tolerant to being over-filled. In the turbo WRX/STi you might get some blow by, but never really any engine issues.
The FA20 I really cant say, I guess time will tell.
2017 Subaru WRB Limited BRZ w/ PP |
#19 |
Drives: 2014 Widebody Cosworth FR-S
Generally, the oil being a little bit low is better than being too high. The quote from the Forester forum covers this, but the crank can aerate the oil which means you have air where oil should be and that can cause an issue. Aerated oil will not have as much pressure and you can run dry in some spots.
To be safe I would have the dealership drain some oil and tell them that there is a high mark on the dipstick for a reason if they contest it. Also make them note that the oil was high for their records in case there are any warranty issues in the future. -Zach |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | @Art_Mighty (10-10-2012) |
#20 |
uosɹǝdʎɐl ʇɹǝdxǝ
Update!
Yeah there was WAY too much oil in there. I didn't want to go back to a dealership and have them make the same mistake so I bought one of these...
![]() ... and pulled out over a quart of oil until the dipstick read in-between the dots! So now a few follow up questions: I'm pretty sure the smoke I saw last week from the motor was probably oil blow by. Should I consider the oil in the engine "good" or has it been aerated and should be changed? Is there any other follow up I need to consider?
#21 |
Pull my finger...
Drives: Silver Scion Slushbox
What did the tailpipes look like?
That almost looks like fresh oil from road construction... I can't see how a 1/2 quart would do that. Mine came with that much overfilled and I extracted it when I got home. Car already had 50 miles on it and the tailpipes are clean.... |
#22 | |
uosɹǝdʎɐl ʇɹǝdxǝ
![]() Now that I have all of that excess oil out of the car I'm going put a few hard rev happy miles into the car and see of anything funny comes out of the tail pipe...
#23 | |
Pull my finger...
#24 |
uosɹǝdʎɐl ʇɹǝdxǝ
I did check the air filter and it looked pretty clean. I replaced it just in case.
#25 |
uosɹǝdʎɐl ʇɹǝdxǝ
Indeed. I just posted in the other thread about that. I think we're good to go...
#26 | |
Just keep an eye on the level and when you check it, do it about 2 mins after you shut the engine off to get an accurate reading. It can take some time for it to all drain back into the pan after it is shut off. -Zach |
#27 |
Drives: Raven Black
I'd keep an eye on your dipstick and watch for any abnormal oil consumption. if you are burning oil - ask for a new engine
| The Following User Says Thank You to CBR600RR For This Useful Post: | @Art_Mighty (10-11-2012) |
#28 |
Drives: Scion FRS Firestorm
Hey @@Art_Mighty, what was your outcome?
| BRZ / FR-S Boxer Engine Dyno Powerband revealed | Levi | Engine, Exhaust, Transmission | 217 | 06-01-2012 01:20 AM |
| total noob with boxer engine | NickDude84 | Engine, Exhaust, Transmission | 35 | 04-27-2012 09:51 PM |
| Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 01:04 AM |
| Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 11:55 PM |
| More proof of FT-86 Boxer engine appears in logo | Hachiroku | Engine, Exhaust, Transmission | 33 | 01-03-2011 02:47 AM |
