Old 04-23-2014, 05:21 AM   #253
yatesy27
yatesy27's Avatar
Drives: MY14 BRZ Premium WR Blue
I didn't end up using all 5 on mine...
I took the two lower bumper splitter/cooling panel trim thingies on the underside of the front bar, and then had to swap out a small duct panel for the mounting bracket for the tS/STi badge. I reused the two screws in the existing duct panel, and used a new one to mount the badge to the mounting bracket.
yatesy27 is offline   Reply With Quote
Old 04-23-2014, 12:55 PM   #254
DSOmegaX
DSOmegaX's Avatar
Originally Posted by ucsmfu View Post
how do you install the front STI emblem ?
are all 5 tapping screws used ? thanks
You're suppose to use 3, but I ended up using 2: the one that taps behind them emblem, and 1 of 2 to the bumper. I don't remember if it was top or bottom that had extremely tight space but that was the one I didn't do. Holds firm regardless and never at risk of falling apart. I have a bike transmission screwdriver with a 90 degree gear clip that I can use for the other one but just haven't gotten around to it
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
chanomatik (04-23-2014)
Old 05-03-2014, 07:24 PM   #255
DSOmegaX
DSOmegaX's Avatar
STi radiator cap added
@dsomegax.cars
The Following 2 Users Say Thank You to DSOmegaX For This Useful Post:
chanomatik (05-17-2014), Trap63 (05-09-2014)
Old 05-17-2014, 03:27 PM   #256
DSOmegaX
DSOmegaX's Avatar
Going for the last major push to "finish" the car. Purchased the tS coil+damper kit, and just pulled the trigger on a used set of 2012 STi black calipers. As parts come in, will be finishing off with the rear control arms, lateral links, DBA rotors, new pads, and possible the draw stiffener (although I might leave that til' later). Hoping to get all this into the car by Subaru Summer Solstice at end of June! *fingers crossed
@dsomegax.cars
The Following 6 Users Say Thank You to DSOmegaX For This Useful Post:
chanomatik (05-17-2014), Guillaume (05-17-2014), SkAsphalt (05-30-2014), SuperDave (05-18-2014), Turkish (05-17-2014), ucsmfu (05-21-2014)
Old 05-23-2014, 12:04 PM   #257
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Would you mind sharing the part number(s) for the tS coil+damper kit once you've received it? Japanparts only shows their own internal reference and I can't seem to find the STxxxxxxx number online.
Looking forward to the next of your awesome build
Old 05-24-2014, 03:15 PM   #258
DSOmegaX
DSOmegaX's Avatar
Will do so! Yeah its taking quite a while to get them, but I'll be sure to snap up some pics and everything when I do receive them
@dsomegax.cars
Guillaume (05-24-2014)
Old 05-29-2014, 09:37 PM   #259
DSOmegaX
DSOmegaX's Avatar
While everyone be talking about the USDM Series.Blue coming soon, I'm just here going wheeeee: tS springs + struts, pinstripe, OEM Audio+ Reference, and STi BBK coming soon!
@Guillaume I havent forgotten about you, will post the part numbers when I get everything ready and assembled tomorrow
@dsomegax.cars
chanomatik (05-30-2014), Guillaume (05-30-2014)
Old 05-30-2014, 02:40 AM   #260
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Excellent, thanks @DSOmegaX. That didn't take long (far less than the 40 to 60 days mentionned on Japanparts).
Old 05-30-2014, 07:35 PM   #261
DSOmegaX
DSOmegaX's Avatar
Front L: ST20310AS010
Front R: ST20310AS000
Rears: ST20365AS000 x2
@dsomegax.cars
Old 05-30-2014, 07:53 PM   #262
MVLSCROWNZ
MVLSCROWNZ's Avatar
Drives: 2014 Subaru SS BRZ LMTD
Good build. keep up the good work!
MVLSCROWNZ is offline   Reply With Quote
Old 05-31-2014, 04:26 AM   #263
DSOmegaX
DSOmegaX's Avatar
Got the coil spring set assembled off the tS car. Updated pink springs plus shocks. The package came with all hardware to fully assemble before installing it onto the car.
So the obvious question is how are they? Well, I could say for sure that I was very surprised how smooth it makes the car, especially as the front shocks have significantly more travel. Where the road changes in elevation is where I felt the most significant difference. The car really just sticks itself to the road, making the steering feel sharper. It's pretty confidence-inducing lol. The springs themselves retain the 15mm drop that I previously had, although because all the parts are brand new, my car appears to be sitting back at stock height until everything settles . I will report back on additional driving impressions after installing the lateral links, control arms, and having the car properly aligned and balanced.
In addition to the fun-factor, I also added more creature comfort. Got my OEM Audio+ 400 upgraded to reference series. Another pleasant surprise as it added even more clarity to the sound in the cabin. Definitely a great upgrade!
Didn't get a chance to get the pinstripe on the car yet. After everything went in, it was already pretty late and everyone involved was tired. So saved for another day!
@dsomegax.cars
The Following 5 Users Say Thank You to DSOmegaX For This Useful Post:
Beyer Subaru (05-31-2014), Createddeleted (05-31-2014), Guillaume (05-31-2014), SuperDave (05-31-2014), switchlanez (06-01-2014)
Old 06-01-2014, 06:08 AM   #264
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Thanks a lot man. So to clarify, these parts numbers are the dampers only, and you need to add the springs which have the following part numbers :
Front: ST20330AS010
Rear: ST20380AS000
Correct ?
Old 06-01-2014, 10:23 AM   #265
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
I read this thread, and I go back and forth between being super duper jealous and hearing John Hammond in my head saying, "We spared no expense."
Annahra is offline   Reply With Quote
The Following 2 Users Say Thank You to Annahra For This Useful Post:
DSOmegaX (06-01-2014), t.chk (06-09-2014)
Old 06-01-2014, 12:36 PM   #266
DSOmegaX
DSOmegaX's Avatar
Front: ST20330AS010
Rear: ST20380AS000
Correct ?
Yeap!
@dsomegax.cars
Guillaume (06-02-2014)
Search this Thread:
Advanced Search
Completed build JK21 Member's Car Journals 46 12-11-2014 10:48 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 02:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-31-2013 12:10 AM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 11:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 10:18 AM
