#15 |
Drives: Audi S5
I've used my OEM jack a couple times now with no issues. I actually like it. It's pretty quick for a scissor jack.
diirk
15 Audi S5 DSG Daytona Grey | Pinnacle Tint <SOLD>13 SWP BRZ Prem MT |
#16 |
Drives: Honda Fit
#17 |
First 86
Drives: Whiteout MT FR-S
Bottle jacks aren't particularly large, and it's not terribly difficult to affix to something such that it doesn't move about as you drive.
Brett
Don't shop, adopt!
#18 |
DEEEERP
The person who posted this on FB has put a picture of the jack up. I can log on to it cuz on im a goverment computer. Ill post it once i get home.
#19 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Keep a jack stand or two in your car at least. The scissor jack should be able to get it up, but I have not and never will trust one. Hell, I put my tire under the car even when I have jackstands. I mean, can't hurt. Lol
#20 |
i'm sorry, what?
Drives: Canada
This thread is worthless without pics
The OEM emergency jack is standard issue that’s been in cars for as long as I’ve been alive. Hell, back in Russia this was the ONLY jack I ever knew of, I have personally used such a jack about 6 times on a variety of vehicles ranging from lightweight eight Ladas to Dodge Caravans. I have already been required to use it on my FRS when I blew out a tire catching a 1mm allan key on the freeway. The jack must be placed in a specific zone under the car along those vertical rails, perpendicular to the road, on level ground Although it has been done in more adverse conditions… :/ Some of this fear mongering is unfounded. Would I just lay under the car on the freeway under severe crosswinds twiddling my thumbs? No. Hell I wouldn’t even do that if the car was on proper jackstands, freaks the shit out of me. But for quick roadside repair of deflated wheels the jack works and IS reliable. And if you think the jack in the Scion/Subaru is scary, go look at the one they (used?) to put in Volkswagens. ![]()
#21 |
Drives: 2013 MT Asphalt FR-S
I used mine a couple weekends ago, the car sat on the emergency jack for near 30 minutes without a hiccup. Easy to use and quick compaired to other's I have used (the low clearance helped).
#22 | |
Drives: SWP BRZ
it's good to carrying hydraulic jack but it's heavy and big. unless it's flat surface and safe to work on, |
#23 | |
The Answer
Drives: Mazda 2
#24 |
DEEEERP
here's the pic.
![]() Here's the link: https://www.facebook.com/photo.php?f...type=1&theater Again, im not trying to meddle in anyones business but if the guy had an issue with a piece of equipment im just trying to pass the word.
#25 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I used to use Dodge/Chrysler emergency jacks (they had a 19mm hex drive on the end of the screw) along with a cordless drill or impact to jack my car up at autocrosses to swap tires. They usually lasted about a season before they failed or appeared to be unsafe to use. I'd just buy another for $10-20. I'd always make sure to be on a flat, hard, level surface, I would never get under the car when just supported by the emergency jack, and most of the time I was dealing with rather lightweight cars. Back then the Neon I raced weighed 1990 lbs.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#26 | |
Site Moderator
Drives: ichi 86 Project
#27 |
SLO NO MO
#28 |
i'm sorry, what?
Drives: Canada
keep in mind you're never supposed to over-extend the jack, you only need to lift the car a hair off the ground so the wheel can be pulled off/on.
i'm no engineer but when you turn what is supposed to be a rhombus into a straight line (that pivots on the bottom point no less) you'll get instability again there is more to this story just like the people who use torque wrenches to untorque things, or overtorque things with normal wrenches then think everything is fine if their torque wrench clicks when they "check" it... and the list goes on.
| $10 Jack Buddies | blalor | DIY (Do-It-Yourself) Guides | 24 | 10-20-2017 08:16 PM |
| usb/3.5 jack relocate + usb charger | BRZranger | Electronics | Audio | NAV | Infotainment | 22 | 11-13-2012 11:42 PM |
| Where ti jack car up at? | skatery1989 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-13-2012 02:53 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 12:43 PM |
| Jack Spots? | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-11-2012 10:09 AM |
