Old 04-04-2014, 06:20 PM   #267
FRSHunter
Drives: Asphalt FRS
Would a square setup of 18x9.5 +40 fit on stock suspension?
FRSHunter is offline   Reply With Quote
Old 04-05-2014, 09:30 AM   #268
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
No, not enough clearance with the spring perches. You need coilovers, or possibly spacers, but then you'd probably run into rubbing issues with the fender and require extreme camber. I'd definitely go with coilovers.
immaculate is offline   Reply With Quote
Old 04-05-2014, 10:12 AM   #269
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Not convinced it won't fit. I belive there are some ppl in the fitment thread that are making it work.
Sent from my SM-T520 using Tapatalk
TONYpepperon1 is offline   Reply With Quote
Old 04-05-2014, 10:55 AM   #270
immaculate
immaculate's Avatar
I have the same exact wheel setup on order, and did a LOT of research before pulling the trigger because I was worried about rubbing even with coilovers. I guarantee it won't fit properly on a completely stock suspension. With spacers, maybe, but it will still likely be a rubbing nightmare.
Old 04-05-2014, 11:13 AM   #271
TONYpepperon1
So do I. Gonna be running RCE Yellow springs though instead of coils
Old 04-05-2014, 12:56 PM   #272
djdnz
1337
Drives: 2013 BRZ WRB S/C
Good luck, let us know what spacers you end up with.
djdnz is offline   Reply With Quote
Old 04-11-2014, 09:36 PM   #273
landon_John
landon_John's Avatar
Would a staggered setup of 18x8.5 +33 front/ 18x9.5 +33 rear fit on Eibach springs?
landon_John is offline   Reply With Quote
Old 04-13-2014, 08:53 PM   #274
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
fitment calc.
http://www.rimsntires.com/specspro.j...r%20H2%20wheel
dunnr is offline   Reply With Quote
Old 04-16-2014, 06:50 PM   #275
Eightysexy
GBC [HI]
Drives: Haole FRS
My Sunlight Silver Set.
Eightysexy is offline   Reply With Quote
The Following 2 Users Say Thank You to Eightysexy For This Useful Post:
dunnr (04-16-2014), SkAsphalt (04-17-2014)
Old 04-18-2014, 06:02 PM   #276
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Yo hey! More pictures of this please! They look great!!!!
Pablitomarrero is offline   Reply With Quote
Old 04-18-2014, 09:42 PM   #277
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by Supermassive View Post
Well I have the 18x8.5" front's and Wilwoods and I can say that for a fact the 18x9.5s will fit for sure. There is so much clearance for the calipers that it's actually kinda ridiculous. I'd say the closest the wheel comes to the caliper is about an inch...I don't have any great pics to prove it, but here's a pic showing the front's mounted up.
so if you havethat much clearance would a + 47 on a 8.5" wide wheel still clear you think?
FullTuneZN6 is offline   Reply With Quote
Old 04-18-2014, 09:47 PM   #278
FullTuneZN6
Novice Drifter
9.5s square or 8.5s up front staggered?
Old 04-21-2014, 05:34 PM   #279
Eightysexy
GBC [HI]
Drives: Haole FRS
Will do, once the weather clears up been raining a whole week straight! Thanks!
18x9.5 +40 all around. Square.
Old 04-22-2014, 03:49 AM   #280
CreinCrein
19x8.5 +33/19x9.5 +43
225/35/19 and 255/30/19
CreinCrein is offline   Reply With Quote
Search this Thread:
Advanced Search
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 10:20 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 07:46 PM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 10:04 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 06:01 PM
