#43 | |
Drives: '06 AM V8V Coupe
Yea about that, 3500rpm on the highway + softtop really really sucks...again, I don't drive this everyday but I make 1 hour trips sometimes and I find myself wishing for there to be a bit of congestion on the freeway so I can go slower and deal with less noise. Never sat in an S2000 before but it probably has just as bad wind noise. Additionally, when you get up to higher speeds you can start hearing the soft top flap around in the wind. It feels incredibly weird cruising at a higher rpm than you use to accelerate...like a little fire started in your wallet :P I try to go slower so my ears don't ring, mpg is also pretty good under 60mph lol. When the clutch needs work I'm putting a lower 5th gear in even if the mpg increase doesn't pay off. When they released the AP2 they should've at least kept the primary reduction ratio the same, they freaking stroked the engine, why do they need higher revs at the same time? Stupidest gearing choice ever made. |
#44 |
My VTEC fluid is full
Drives: EFF JAY
I drove a BRZ (granted not this topic's FRS) this past weekend. I must say, it is a great car! I really like the creature comforts and the space. Although I didn't like the feel of the clutch. The clutch's resistance wasn't the same through out its range. But that's something than I can get use to.
I wouldn't get rid of my CR for one. But if I didn't have a CR, I would most definitely get a new BRZ/FRS over a used s2k. IMO, the BRZ/FRS is 8/10ths the performance of an s2k. BUT it can do alot of things that an s2k cannot do -- fit tires in the trunk, space for groceries, etc...just better daily use. I liked it so much that I want to add a BRZ/FRS to the garage. Last edited by iLuveKetchup; 10-03-2012 at 12:41 AM. |
| The Following User Says Thank You to iLuveKetchup For This Useful Post: | raz0rbladez909 (10-03-2012) |
#45 | ||
#46 |
Drives: Whiteout FR-S
#47 |
#48 | |
Drives: Nevermorange FRS
In my AP1 I would turn about 4k at 70mph (as did the Integra Type R) but my FRS at 70mph is closer to 3200rpms (6MT) and the AT is even less. I don't know about the S2k Speedo, it seemed pretty accurate, buti recall Honda speedos not being very accurate. CRX, Accord, Integra and my 4th gen prelude.. compared them all against radar (and some against GPS) and they were off, by as much as 5mph. |
#49 | |
3000 RPM is exactly 70MPH for us according to the BRZ's digital speedo, but GPS indicates 68.7. This number might be slightly off, since we're running 215/45/17 on a 8" wheel, rather than the factory 7". |
#50 | |
Drives: 17' 86
Almost everyone in the s2k prefers the AP1 despite the mileage. |
#51 | |
I looked on some S2k forum and someone wrote "3500rpm at 65mph" so I thought that was accurate. I know the AP2 has a longer 6th gear but only by a little since the primary reduction ratio is bigger. Mileage? AP2 gets worse gas mileage no? Shorter gears + more displacement? What I'm saying is that the AP2 gearing isn't a whole lot better for comfortable cruising, I would get an AP1 if I got an S2000, then I'd probably swap out the 6th gear for the .762 one. |
#52 | |
| The Following User Says Thank You to rice_classic For This Useful Post: | CSG Mike (10-03-2012) |
#53 | |
#54 |
Drives: EFF JAY
Are you speaking of the AP1 gearing? As an AP2 motor with an AP1 trans?
The reason I ask is that if you have ever driven an AP1 you'll know that it's excruciatingly slow. It seems to take forever to get to redline. I wouldn't want an AP1 at all!! While it might not show on paper, the difference from AP1 & AP2 is night and day. However, the ideal combination would be an 06+ AP2 with AP1 transmission. |
| The Following User Says Thank You to iLuveKetchup For This Useful Post: | CSG Mike (10-03-2012) |
#55 | |
However it is accurate to less than half a tenth of a second to my AMB transponder lap times which is massively impressive so I'm sure it will be accurate enough. |
| FR-S vs S2000 | vang | FR-S / BRZ vs.... | 436 | 09-19-2012 05:52 PM |
| E36 M3 vs FR-S vs S2000 (for me) | RearDrive | FR-S / BRZ vs.... | 48 | 07-02-2012 11:46 PM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 03:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 10:05 PM |
