#1191 |
frank
Drives: Subaru BRZ WRB
I just sat down and read through the whole thread for last 90 minutes or so..
there were so many information to take in and so many good looking rides! i've found some answers but still left with some questions. please understand that I am a noob at this.. first, let me list out the things i noticed/learned 1. i love 527 looks 2. i am going to keep stock tire, and stretch on 17x8.25 looks ok to me. 3. i am not going to lower my car (i already have hard time driving my car around) 4. if i am buying this wheel, i need to purchase lug-nuts that fits and hubcentric ring questions 1. TPMS, can they be transferred to new wheels and cause no problems? 2. from my understanding of "off set" +35 will make the wheel poke 'less' than the +25.. am I correct? (i don't like poke at all) 3. does anyone know a retailer in southern california who carries XXR? (if not, where's a good place to look?) 4. what does hubcentric rings do? thank you, in advance
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA Build Photo Album - http://bit.ly/brz_wrb SoCal LA 86 Club Member ![]() |
#1192 | |
Drives: scion fr-s
1. tpms, yes it can be transfered. 2. the less offset the more it will poke out. so +25 offset will poke out more than 35. 3. get the wheels offline fron nlmotoring.com and put the coupon code i think is 25xxxr or xxr25. 4. idk lol all i know is that i ordered some for my wheels havent arrived. addition: you will also need to get aftermarket lug nuts for your new wheels, you can get tunner lug nuts 12x1.5 set of 20. |
#1193 | |
Drives: scion fr-s
#1194 | |
Drives: JRSC'd Asphalt FR-S
2. yes 3. Check out LSD Motorsports in Cypress. Tell them I referred you 4. Will help prevent vibrations and stuff from wheel, you don't need them, but I would recommend. It's pretty cheap anyway. I'm lowered an inch on H&R Sports and it was pretty low on stock wheels, but I got 18x8.75 +35 on 225/40 and it raised my car up a bit lol. |
| The Following User Says Thank You to Wes For This Useful Post: | wrb (10-31-2013) |
#1195 | |
Drives: scion fr-s
#1196 |
Hm you can but you don't need it if you don't want. I poke a tiny bit but I don't mind it. Since you're lower than me, you probably have slightly more natural camber.
| The Following User Says Thank You to Wes For This Useful Post: | juanam0909 (10-31-2013) |
#1197 |
Seems Legit
Drives: Toyota
This thread is pretty expansive. I'm new to the wheel/tire world. I like the look of these wheels. Just a couple of questions for anyone willing to help the n00b....
1) Where are you guys buying them from (i.e. who has the best prices)? 2) The size that seems to be most popular is 18.x8.75 ET35 so what all is required to have these mounted? (hub centric rings, spacers, tuner lugs, tires, TPMS sensors, etc?) If hub rings and spacers are necessary, can you be specific as to which model/part number you suggest unless universal. 3)Which size tires do you recommend? Thanks in advance.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#1198 | |
Drives: scion fr-s
2) you're going to need tuner lugs set of 20 12x1.5. i just found out that hub centric rings arent necesary as mention on the post above this one. so hub size is 73 and 56.1 if im not wrong look it up in this thread. 3) 225/40/18 ? |
#1199 |
Drives: 13' Subaru BRZ Limited SWP 6MT
| The Following 4 Users Say Thank You to mwjcyber For This Useful Post: |
#1200 | |
2. hub rings (73.1 to 56.1). lug nuts (the shop I bought it from just gave them free with purchase 12x1.25) Dont need spacers, you don't need hub rings either, but recommended. The shop will switch the TPMS over for you. The shop I was at had the hub rings, not sure what brand. 3. with 18x8.75 go with 225/40 or you can also do 235/40 if you want. |
#1201 |
Drives: 2013 FR-S Argento
Nah you don't need them, but if you don't like the poke you currently have then you need camber bolts.
As you lower, the rears will gain quite a bit of camber, but not the fronts - so you need the bolts to adjust and bring the tops in flush with the fenders. The factory crash bolts would be all you need, and they're very cheap... alignments aren't cheap so IMHO it's best to spend the few bucks and have them on hand when you get aligned. That way if you need them to dial in camber they can do it. Also a little bit of front camber will help the car handle better with your lowering springs. |
#1202 | |
Drives: scion fr-s
#1203 |
Factory crash bolts at dealer, subaru part is 901000394, scion has the same bolt under a different number. $6 each, or you can go with SPC or white line brand camber bolts (identical bolts, google for where to buy) a bit more, but might get you a little more adjustability.
Sent from my iPad using Tapatalk - now Free |
#1204 | |
Drives: 2013 Red Subaru Brz
| Tags |
| 17 wheels |
| Wheel Directory: ProDrive GC-012L 18x8.5 +48 | MarkMash | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 05-12-2013 04:55 PM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 01:24 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 01:28 PM |
