#15 | |
Drives: Toyota GT86
With only 20 psi, is a pressure cooker really necessary? Or was it just what you had available and handy when making it? Something similar must be possible with a simple plastic bottle, a pickup line through a fitting and pressure being supplied through a nipple by a spare tire for us without an air compressor. Especially for smaller quantities.
#16 | |
Drives: Full race 4cyl boxer
Yes, it curves into the "corner" of the pot. You could try putting 20 PSI into a plastic bottle full of oil if you like. Please record for posterity.
#17 | ||
Drives: Toyota GT86
http://www.gunson.co.uk/items/pdf/Pr...uctions_GB.pdf 10-20 PSI from a spare is feeding a plastic bottle. I would take the chance on a homemade solution with a thicker plastic bottle (Euro 1 l. Cocacola bottles as an example are really rigid). Or I might get that kit for brake bleeding and modify it so I can connect to my AN10 fitting. It's just to flush a small 13 row cooler. Probably it's way overkill and would be easier just to leave it. Though I think I'd sleep better knowing ALL my oil has been changed. ![]() Quote:
#18 |
Drives: 2014 GT86
Using spare as compressed air tank - clever idea. Makes kit so much simpler/cheaper yet still mobile.
#19 |
Thanks
How much difference does it really make if you change it?
Have a more frequent change if you don't, less frequent if you do. Does anyone actually flush out their cooler? Never heard of it. Any OEM cars with oil coolers have service recommendations or anything?
#20 |
Drives: 2014 GT86
Still it would be nice to have oil cooling kits designed to ease complete flush. If for nothing else, then at least for peace of mind .. some customers may value that.
#21 |
Drives: 2015 86 GTS + Mitsi Lancer GSR
Setrab/Perrin instructions stated you don't need to worry about the old oil in cooler/lines. You'll never get all the old oil out unless you fill, run, drain, fill run drain, fill etc etc.
I service every 7500 because E85, hard driving and when I have nothing to do it's an easy $40 and keeps me happy
#22 |
#23 |
Drives: 2013 Asphalt FRS
I use compressed air and blow out as much oil as possible then fill the cooler and lines back up. It might be over kill but I like knowing the oil has a fresh extra quart in the system
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#24 | |
If your not boosted and not a super serious track warrior then you could avoid this issue by using the forester/wrx OEM heat exchanger cooler. and not have high pressure oil lines that may fail/leak or worry about a rock or something damaging oil radiator. http://www.ft86club.com/forums/showthread.php?t=73684 their fine for NA cars hard street use and light track work. |
#25 |
Drives: Toyota GT86
#26 |
Just a 4.
Otherwise known as a NARP. (not a real Porsche) However, it can keep up with my BRZ as long as the BRZ has street tires and the 914 has hoosiers :-) My brother's TR4 is faster than my BRZ but he has spent tens of thousands of dollars over the last 10 years figuring out how to squeeze every last bit of performance from that tractor motor. |
#27 | |
[ame="http://www.amazon.com/Motive-Products-107-System-Bleeder/dp/B00CJ5DZE2"]Amazon.com: Motive Products 107 Brake System Power Bleeder: Automotive[/ame] it holds 15 PSI easy (that's the pressure I use to bleed my brakes). I bought it for $30 a few years ago... at the current price I am not sure if it's worth it lol.
#28 |
...Just add nauseum
Drives: 2003 (AP1) S2000
OEM cars with air oil heat exchangers just have shorter oil change intervals. Nothing creative.
Inline 4 is best 4
There are many ways to displace. -Spartarus |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 09:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| Greddy oil cooler coming soon | DIG1992 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 08-20-2012 01:02 AM |
| Greddy Oil and Diff Cooler | pdreams | Engine, Exhaust, Transmission | 3 | 06-13-2012 09:41 PM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 01:55 AM |
