#71 |
Potato Farmer
Drives: #SLOBRZ
You can use the stock Eclipse Satnav i believe, there is a plug that go's into the back that has RCA's that come out of it.
Jump on the Eclipse website, look at the unit you have and it's install details and you will see the plug/cable i mean.
Something something butter..
www.vic86brzclub.com |
#72 |
Drives: Celica 04
Is this for the 86 as well or only for the BRZ?
#73 |
Potato Farmer
Drives: #SLOBRZ
The BRZ for sure, but i believe the Satnav in the 86 is identical as Toyota use Eclipse units also. When i get home ill get some details.
#74 |
Drives: Celica 04
There is very little information about the 86 satnav and whether or not it supports RCA at the back. This is probably because only Australia and a few other countries around the world have the Toyota Satnav as an option, i.e. not Scion.
#75 | |
Drives: 86 GTS White
#76 | |
Drives: Toyota 86 GTS 6AT (Tornado Grey)
The eclipse/fujitsu-ten unit in the aussie 86 GTS does not have that extra rca cable as an option unfortunately - I called them up and quoted the model number but no luck. I just went with the line out converter option instead. |
#77 |
Potato Farmer
Drives: #SLOBRZ
http://www.eclipse-web.com/au/downlo...0_AVN827GA.pdf
Item 6 is what i believe you need. But you need to find out what unit you have, go to your glove box, pull out the manual, it will tell you. once you get that, i can point you in the right direction if you can use the RCA.
#78 |
how annoying is the rattling brake light! it gives me the shits
#79 | |
Who wants to go halfies on a dynamatt bulk pack in sydney haha.Sweet build mate, starting my audio upgrade with a pioneer 8450BT this wednesday! |
#80 | |
Drives: Sonic Blue GTS AT
Just relax.
#81 |
Potato Farmer
Drives: #SLOBRZ
Ok, seems as if the units in the BRZ and 86 are different..
This makes things a little harder.. ill see if i still have contacts and Eclipse.
#82 |
I've got Focal BAM sound deadening throughout the doors, they don't rattle at all, and in the trunk, the rear deck doesn't make any noise for me just that brake light. Might take it out.
#83 |
86DESU
Drives: 86 GTS, S13, CB9
Skorov; Just saw your install. Looks tight! Congrats on a show-quality install. And thanks for spruiking your guys (again).
| The Following User Says Thank You to Nezz For This Useful Post: | Skorov (10-09-2012) |
#84 |
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Does anyone know, if you remove the rear speakers... are you able to replace them with 6.5" subs? I know Kicker do them...
| purchasing area 86 stuff | pkptd447 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-15-2014 03:09 PM |
| Help Me Get This Stuff OFF!!! | wootwoot | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 09-07-2012 11:38 AM |
| Any more cool stuff? | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-24-2012 04:28 PM |
| More HKS stuff! | uspspro | Engine, Exhaust, Transmission | 0 | 04-25-2012 01:27 PM |
| Dimman's technical stuff. | Dimman | Other Vehicles & General Automotive Discussions | 74 | 10-17-2011 02:15 PM |
