Old 09-20-2012, 10:18 PM   #71
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by alyon View Post
Mine also feels like this.
I have driven a manual for around 4 years before owning this and never had any issues. Unless I am going downhill I have to give it a blip to around 1.3k-1.5k. Backing up on a hill is the worst though. There is no fucking good way to not ride the clutch.
This clutch also seems very light. Even a little bit of riding or a crappy start and you will smell it.
Am I doing something stupid? or does the Boxer just idle very low? I also found the throttle is not very sensitive for the first .5" or so of travel making it easy to over rev.
Theres not a whole lot of torque, so you have to give it more gas to get going. In my CL I practically let the clutch out half way before giving it gas and the car likes it. In the FR-S I need to rev up to ~1-1.2k rpms for a smooth engagement. My CL makes more then twice the torque of this car though.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-21-2012, 12:08 AM   #72
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by MRZ415 View Post
Well for you MT Pro out there, any advice to a future noob so I don't blow the clutch at 700 miles ..
I intend to STEP on Break and Let go of clutch till car shakes then let it engage
naturally without gas first, Next Step I will watch for RPM DIP, as I give it a bit of
gas n let go of more clutch RPM drops and I've been told thats when I let go of the
clutch totally n give even more gas... right ? wrong ?
Even though I've been told this isn't technically true, it seems to have worked for me since I have a 3rd vehicle approaching the 160000 mile mark with the original clutch...but here goes:
The less time your foot is on the clutch, the longer it will last.
I'd rather make a jerky 1st gear start instead of roasting the clutch too long and having a smooth start. That translates to less time "on the clutch" and has proven successful for nearly half a million miles of manual driving for me, almost all of it(95%+) in city traffic.
Also, you don't have to push the clutch pedal to the floor to shift, except for 1st and reverse, both of those gears require the clutch pedal being all the way down. On all my Hondas, the clutch engaged at the top 1/4 or 1/3 of the overall travel so when you're shifting into any gear other than 1st or reverse, you only had to press it a little. Every clutch is different I'm sure, your job is to find out where it engages and simply let it become a "muscle memory". You'll find yourself doing it automatically in no time...but if you ever get a little lazy doing it that way, you'll get some gear grind so be careful and pay attention.
For what it's worth, I've fallen into the lazy shifting hundreds of times in the 9.5 years on my current car/clutch/tranny with hundreds of little grinds here and there and it all still works just fine at 159000+ miles. It's those loooong drawn out griiiiiiind/zzzzzzztt you want to be afraid of.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
civicdrivr (09-21-2012)
Old 09-21-2012, 12:25 AM   #73
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
When driving alone I always have jerky starts to save the clutch, but I find when driving with someone else in the car it seems a bit rude, so I make smooth starts.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 09-22-2012, 06:06 AM   #74
Bluecille
Drives: Scion FR-S Ultramarine
E-brake technique
Originally Posted by whtchocla7e View Post
What about creeping up a hill? I have a stop sign at an incline. There's a line of cars in front of me stopping at the sign and taking off one by one. What do I do?
I would recommend using the ebrake. It might take some practice but anytime I worry about rolling back I engage the ebrake. Simple to do when the handle is at your hip. And I have not read all the posts so my apologizes if I am repeating something someone already mentioned
Bluecille is offline   Reply With Quote
Old 09-22-2012, 08:51 AM   #75
Joe Schmoe
Drives: '04 MR2 '10 MX5
You guys really should learn heal-toeing for hills.
1. Sit in neutral with your foot on the brake
2. Clutch in and select first, foot still on the brake
3. Swivel your ankle and use the other half of your right foot to give the car a little gas while keeping pressure on the brake (right foot is now on two pedals)
4. Begin to lift your clutch foot while maintaining the little pressure on the gas and slowly removing pressure from the brake until the clutch is engaged.
Notes:
- if you have small feet, turn your whole leg and foot so the heel of your foot is operating the brake and your toes are operating the gas (hence the name).
- it's an art to master it.....you bought a manual sports car, learn it.
- creeping is creeping and there's nothing you can do to not ride the clutch.
- if you get good at it, if you're on a flat road and someone is being a d*ck behind you at a light, the hill technique above lets you drag your brakes enough to keep your brake lights on as you leave the light and pull away from the aforementioned d*ck (at whatever speed is appropriate lol)...they are left sitting there without the cue of your brake lights turning off.
Joe Schmoe is offline   Reply With Quote
Old 09-22-2012, 11:59 AM   #76
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Joe Schmoe View Post
You guys really should learn heel-toeing for hills.
Notes:
Fixed...
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-22-2012, 01:16 PM   #77
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by Hawaiian View Post
Fixed...
But what if your toe is hurt?
Parting out HERE
Old 09-23-2012, 10:32 PM   #78
White64Goat
What.........turf toe?
Search this Thread:
Advanced Search
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 02:12 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
