#15 |
Drives: gti, nsx, integra type r,porsche911
complete waste...
either do a roll bar, bucket, 5/6pt harness. Or do a CG lock with stock belt. That's my oppinion.
| The Following User Says Thank You to CyberFormula For This Useful Post: | mike2100 (09-21-2012) |
#16 |
Drives: 23 BRZ
OP are you planning on keeping the harness bar in or only for track days? Are you doing autocross or HPDE?
Assuming it's a permanent install for HPDE purposes: If you have a harness bar it's safe to assume you're running harnesses. If you're running harnesses I hope you're using a fixed back racing bucket. If you're using a fixed back racing bucket and get into a roll over, your body is forced to remain perfectly up right while the roof above you is subjected to crushing forces. Not a good day for your spine. This is why it's smart to add a roll bar when doing seats/harnesses, not just a harness bar. A roll bar also makes for good attachment points for a harness bar. A full cage is not necessary, nor desired for any car driven on the street. You can bang your unhelmeted head on one of the overhead bars and it's lights out. A stock vehicle is designed to soften the blows of impact during a crash. Your body is allowed to conform around the 3 point belt, because you're expected to be cushioned by air bags. Oh and I wouldn't run harnesses without a head and neck restraint. If you fix your body in an upright position the only remaining part that is free to move forward in a frontal impact is your head and neck, subjecting you to a basilar skull fracture. Head and neck restraints are now required in I think both SCCA and NASA racing. This all may seem like overkill to someone not familiar. It certainly did to me, before I researched it. Here are the configurations I would consider safe: 1) Beginner to Intermediate HPDE: Stock, wear a helmet 2) Intermediate to Advanced HPDE: Roll bar, 5/6 point harness, fixed back racing bucket, head and neck restraint, helmet (swap in the seat only for track days) 3) Wheel to wheel racing: Full cage, 5/6 point, fixed back, head and neck, helmet, fire suppression, fire suit/gloves (all required for w2w racing anyway) Personally, I don't think I'd be this cautious for autocross because of the lower speed and zero traffic. I hear there have been rollovers in autocross before though! |
| The Following User Says Thank You to mike2100 For This Useful Post: | diirk (09-21-2012) |
#17 | |
Drives: Audi S5
You make some valid point and have some good info. My plan is to install and leave the harness bar in the car. Primary use is for track days/HDPE. Possibly autocross but nothing firm there. My desire from this is solely to have something keep me in the seat better. That's it. I've run track days with just the standard 3-point in my WRX and I had way too much movement in the seat. I do wear a helmet as mandated, no issues. Again, coming from offroad racing I'm pretty familiar with roll cages, harnesses, and associated gear. I do have a neck restraint, fire suit, etc, but I'm really not a fan of a HANS device, even offroad. And yes, I've been in a rollover before too. So for the time being I'm likely to try out a track day completely stock as you mentioned wearing just a helmet and see how it goes.
diirk
15 Audi S5 DSG Daytona Grey | Pinnacle Tint <SOLD>13 SWP BRZ Prem MT |
#18 | |
Drives: 23 BRZ
Another thing besides the cg-lock that might help is the JDM knee pads/braces. |
#19 | |
Drives: Audi S5
Have you tried a CG-Lock? I've been curious if they actually work and are safe to use.
diirk
#20 |
Drives: 2012 BRZ Premium WRB 6MT
Hi Guys,
My company (Essex Parts Services) is very deep into our harness bar design. We will likely show some pics in the next couple of weeks. It is a very stout design anchored at four points. It has an adjustable bar height to match different seat/driver heights. It will allow the OEM seat belts to be retained. I don't want to get into an endless debate over the merits of a harness bar. I'm just answering the OP's question. I personally have used harness bars in my past fixed roof cars. Most recently I had one in my C5Z06. For my Miata, I went with a four point rollbar because it is a convertible. In my opinion, every time you go on track it's a calculated risk. A lot of things can happen out there. In my 13 years of doing track days, I've seen far more cars stuffed into walls or other objects vs. rollovers (that said, rollovers happen plenty of times!). For me, I would rather have the car control gained from having a proper race bucket and harness. Also, a harness allows you to run a Hans. After seeing so many cars stuffed, I refuse to go on track without one ever again. We are also working on seat rails. We have a Sparco Evo II in our car on the prototypes currently.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
| The Following User Says Thank You to JRitt For This Useful Post: | diirk (09-21-2012) |
#21 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I have CG-Locks on my Miata and Mustang for autocrossing, and did a track day at Midohio a few weeks ago with the Mustang. IMHO the CG-Locks work very well, I wasn't flopping around in the crappy seat in the Mustang on track at all. I've had a full race harness (with roll cage and race bucket) in another car in the past and used Schroth ASM 4-pt harnesses in several cars as well. I'll definitely be putting a CG-Lock in the BRZ, and for HPDE/PDX/autocross use I feel that is adequate for casual use until I step up to a roll bar, fixed race seat, and 6-pt harness for more serious track days and time trials.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| The Following User Says Thank You to Miniata For This Useful Post: | diirk (09-21-2012) |
#22 | |
#23 | |
Drives: Scion FRS
Take a look at Draco-REX's thread below http://www.ft86club.com/forums/showthread.php?t=15051
| The Following User Says Thank You to YoKeutla For This Useful Post: | diirk (09-21-2012) |
#24 |
Drives: Audi S5
I'll keep those in mind as well. They do look like a reasonable option.
diirk
#25 | |
Drives: Scion FR-S
Stock belts: just one day on track and just four 20-minutes sessions -- my knees hurt, especially left one. Could be much worse if it was two-days event. I'm first in the line for the harness bar. |
#26 | |
Drives: Scion FR-S
I'm definitely interested in the both products! |
#27 | |
Drives: Nevermorange FRS
All of this needed to be quoted again due to the importance of it. Anti-submarining is bad and having a normal 5pt without a roll cage can be deadly if/when you end up on your lid. The roof of the 86 isn't exactly "robust". |
#28 | |
Volunteer Fire and Rescue
Drives: Ambulance... sideways.
This, anything else and you might as well slap a shower curtain rod in there.
It's more fun to drive a slow car fast, than a fast car slow.
| wiring harness | so26 | Electronics | Audio | NAV | Infotainment | 5 | 10-30-2013 04:19 AM |
| Seat harness | CB762 | Tracking / Autocross / HPDE / Drifting | 16 | 08-11-2012 03:18 AM |
| 3rd harness wiring? | kndonlee | Electronics | Audio | NAV | Infotainment | 3 | 07-01-2012 08:49 PM |
| Wiring harness | sastexan | Electronics | Audio | NAV | Infotainment | 0 | 06-17-2012 12:41 AM |
| ECU Extension Harness available | Ishii Motors | Engine, Exhaust, Bolt-Ons | 2 | 06-07-2012 04:20 PM |
