#239 |
STX 188
Yeah, it's like all over the thread...
#240 |
Drives: 2014 Lighting Red BRZ
#241 | |
Drives: 2015 BRZ Limited 6MT
did your stock tpms sensors fit flush/flat on your weds wheels? no gap? |
#242 |
#teamswagoi
Drives: 2014 Raven FR-S Monogram
Can anyone tell me what size hub centeric rings you are using for your current setup with these wheels ?
#243 | |
Vtec Jesus
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
#244 |
Drives: 2017 BRZ
DGM on CBS
Lowered ~1.4" (recommended settings for Tein SRC) with -3.3° front, -2.8° rear camber. 255/40/17 Bridgestone RE71-R. Pondering ordering a run of those custom centercap/centering rings. ![]() ![]()
#245 |
Drives: 2013 BRZ black
These take a 56mm x 65mm hub centric ring @Pish
SOOOO excited about these Weds I just picked up second hand. Took them straight to the powdercoater. Finished in a Spanish gold plus clear coat at Killer Koatings in Cincinnati Ohio. Couldn't be happier. These are 17x9+35 wrapped in 245/40r17 Hankook Ventus R-S3s. Cant wait to see these mounted on my black BRZ! ![]() ![]() ![]() ![]()
| The Following 7 Users Say Thank You to xkalelx For This Useful Post: | BeRZed (09-11-2015), JMon85 (10-17-2017), Metabrz (09-11-2015), oldlostcory (09-11-2015), Pish (09-10-2015), Plumbus (08-02-2020), Timmy_Jones (09-10-2015) |
#246 |
Pothead
Drives: Dark grey GT86
#247 |
Drives: 2013 WRB BRZ
I suppose I'm the newest member with these wheels and couldn't be happier!
Specs to help others: 17x9 +35 (obviously) 245/45 Hankook Ventus V12 MachV lowering springs for about a 1" drop Front Camber: -1.5* (SPC camber bolts in the LOWER hole) Rear Camber: -2.0* (Au naturel) No rubbing at all, roughly 1cm of clearance to the spring perch. ![]()
| The Following User Says Thank You to BigTuna For This Useful Post: | MisterSheep (02-08-2017) |
#248 |
Drives: '15 Ultramarine FR-S
#249 |
Drives: GR Corolla
Hyper silver with 245/40/17 Continental tires
![]() ![]() ![]() ![]() Got the Weds from Gruppe-S and tires from America's tire. |
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | JRRIII (05-11-2016) |
#250 |
Drives: LR BRZ Limited
Mine are 17x9 +25 Titan Silver version.
I'm toying with the idea of dipping them white. they look so good here: ![]() ![]()
| The Following 3 Users Say Thank You to DuMa For This Useful Post: |
#251 |
Drives: SWP WRX HATCHBACK
#252 |
Aloha!
| Tags |
| dunlop, frs, jrz, rally armor, renzo marsano, star spec, tc105n, wedssport |
| Wedssport TC105N 17x9+25 5x100 | YDNA | Wheels and Tires | 24 | 04-04-2014 02:05 PM |
| FS: Wedssport TC105n 17x9 +25 | donutfilling | Wheels and Tires | 19 | 03-26-2014 07:59 PM |
| Wedssport TC105N 17x9 and 17x8 | donutfilling | Wheels and Tires | 9 | 09-27-2013 05:04 AM |
| WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** | RavSpec | Wheels and Tires | 47 | 06-22-2013 12:49 PM |
| WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel | RavSpec | Wheels and Tires | 72 | 12-04-2012 04:58 PM |
