86WORX
Old 02-20-2014, 09:57 PM   #211
Captain Insano
Yep, they are fantastic. Pics don't do justice.
The Following User Says Thank You to Captain Insano For This Useful Post:
suaveflooder (02-21-2014)
Old 02-21-2014, 02:36 AM   #212
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Are new extended studs required?
Also what lug nuts is everyone running?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-05-2014, 01:20 AM   #213
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Need better pics from the blue Subie... lol
tigermack is offline   Reply With Quote
Old 10-20-2014, 01:38 PM   #214
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
The Following 6 Users Say Thank You to tigermack For This Useful Post:
androopoo (01-03-2015), JMon85 (10-13-2017), justint5387 (10-22-2014), SG02WRX (02-03-2015), SuperDave (09-05-2016), tbox (10-25-2014)
Old 10-20-2014, 02:10 PM   #215
df.dima
Drives: FR-S and Mazda 3 Sky
Originally Posted by tigermack View Post
What a beauty . What are your specs on the lows and alignment?
Thanks.
df.dima is offline   Reply With Quote
Old 10-20-2014, 05:47 PM   #216
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
oh ya i was supposed to get a better pic of the black/gunmetal/Dark grey/(color words here) version of these...
G-Man is offline   Reply With Quote
Old 10-20-2014, 05:50 PM   #217
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Thanks.
Not quite sure on the alignment but the front is at around -3.2 camber.
Old 10-23-2014, 03:11 PM   #218
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
Originally Posted by CircuitJerk View Post
You know my answer will be biased.
I'm on the eibach pro-kit like you are, i currently only have camber bolts in the front. What parts did you use and what's your final camber numbers to clear these wheels both with the fenders and the spring perch like you've done? Any issues with rubbing?
These will be my track wheels and won't be driving them on the street much. Just trying to figure out what all I "need" to make these work right and what would simply be nice to have.
Thanks
stoked_on_spool is offline   Reply With Quote
Old 10-30-2014, 07:35 PM   #219
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Thanks
I had the Whiteline Camber bolts up front and I think I managed to get about 1-7 - 1.9 degrees of negative camber. No issues.
I had Cusco and when Whiteline Lower Control Arms with about the same.
I've since moved to Stance coils running about -3 all around.
Again, no issues even with about 1.5 up front.
Hope that helps.
CircuitJerk is offline   Reply With Quote
The Following User Says Thank You to CircuitJerk For This Useful Post:
stoked_on_spool (11-04-2014)
Old 11-04-2014, 04:52 PM   #220
stoked_on_spool
I had the Whiteline Camper bolts up front and I think I managed to get about 1-7 - 1.9 degrees of negative camber. No issues.
Hope that helps.
Just what I wanted to know! Thanks @CircuitJerk
The Following User Says Thank You to stoked_on_spool For This Useful Post:
CircuitJerk (11-05-2014)
Old 11-15-2014, 10:46 PM   #221
Buurz
Drives:
Just ordered mine from evasive, wanted to go a different route than black wheels on a white car or even the gunmetal.
I got the 17x9 +35 and going to put Bridgestone Potenza RE-11A 245/40R17
Sent from my SAMSUNG-SM-G900A using Tapatalk
Buurz is offline   Reply With Quote
The Following User Says Thank You to Buurz For This Useful Post:
tigermack (11-16-2014)
Old 11-25-2014, 09:42 PM   #222
Buurz
Drives:
Got my wheels in and on my car
The Following 2 Users Say Thank You to Buurz For This Useful Post:
DuMa (06-21-2015), Keenercarguy (03-30-2017)
Old 11-26-2014, 08:02 PM   #223
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Those 17x9? So much poke?
The Following User Says Thank You to tigermack For This Useful Post:
Buurz (11-26-2014)
Old 11-26-2014, 08:07 PM   #224
Buurz
Drives:
Yeah 17x9 +35
Front camber is only - 0.3°
dunlop, frs, jrz, rally armor, renzo marsano, star spec, tc105n, wedssport
Wedssport TC105N 17x9+25 5x100 YDNA Wheels and Tires 24 04-04-2014 02:05 PM
FS: Wedssport TC105n 17x9 +25 donutfilling Wheels and Tires 19 03-26-2014 07:59 PM
Wedssport TC105N 17x9 and 17x8 donutfilling Wheels and Tires 9 09-27-2013 05:04 AM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 12:49 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
