#15 | |
Drives: BR86
Yeah, he is a high volume seller, and that's his usual price for that sort of tyre/size. Have known him for a long time, he's great ! Also a fan of Dunlop & Yokohama road tyres but in recent memory the Potenzas out perform them, at least for me & my lightly modified Celica. |
#16 |
Drives: Toyota 86
Looking for tyre at the moment.
KU36, pretty decent grip and lasted as expected (10-12thou on a r33) Toyo R1R, much better than KU36 for a cheaper price. Last similar to KUs Looking at possibly trying the RSR's next. Other options are Nitto NT05 or Hankook RS3s but can't find anyone in Aus with the latter. |
#17 |
Drives: 2jz
Have tried several tyres , for street I recommend federal 595 rsr and proxes r888 for track use.
Keeping price in mind offcourse |
#18 |
Drives: Altezza RS200-Z 6MT
Potenza RE002 are good value for money but if you want real grip look at Michelin PS3 or Goodyear Eagle F1 Asymmetric 2. I have the latter on my car & they're phenomenal
#19 |
Drives: Fiesta XR4, Toyota 86 on order
Driven a GT with AD08s on 17x8.0" RPF1s. In my opinion they might be a little too sticky for the stock suspension.
I'm weirdly considering going to a 17x8.0" wheel but then sticking Primacys back on it, at least for road use. |
#20 |
Drives: Toyota 86 GTS Velocity Orange
I wonder how well the stock tyres will stretch over 17x8's myself. Pretty sure it is pushing the limits a bit
#21 |
Yeah, I'd need to go up to 225 or 235. I think you *can* do it in theory but it's not the right size.
#22 |
Drives: Mt Fuji Red 86 GT
215s are not a stretch on 8in rims at all. a 215 tyre is 215mm and an 8in rim is 200mm. 205 will fit comfortably on an 8. Its not "the norm", but its no issue.
#23 |
Drives: 2jz
I would like to get some feedback from tyre experts on sizing as to what will be the best size for maximum grip on a 9" / 9.5" wide rim on the rear end.
Would a 265/35 fit without rubbing or compromising on handling characteristics. |
#24 |
Drives: Slowly
It should fit fine on a wheel with around a 45mm offset, but is pretty pointless unless you're making more than 300hp.
#25 |
^^ Agreed on being pointless unless you have alot more power.
Why do you want a tyre that wide? It really isn't necessary with the weight of the car and the power it produces. A 225 or 235 will be sufficient. A 235 could also go on a 9in rim without stretch, but a 225 will be a little stretch. Otherwise an 8.5in rim. |
#26 | ||
Drives: 2jz
I do have plans to add boost and the car will be at the track once a month, and maximum grip is the priority as the stock setup will break traction at those levels. I am thinking 17s would be best to start off with a 245/40 tyre plus. |
#27 |
Fair enough if you are going boost, but still think a 245 would be sufficient with well set up suspension and good tyres.
For what it’s worth I will be tracking mine reasonably regularly with 215’s (not the stock Michelins), but I am not planning to boost at all. |
#28 |
Drives: Slowly
| Random Fitments of Wheels & Tyres (MUST SEE!) | dnjshin0bi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 10-09-2012 12:23 PM |
| WTB GTS Wheels with Tyres | Loki556 | Australia Classifieds | 0 | 08-31-2012 11:31 PM |
| Swap out stock wheels and tyres upon car delivery or no? | lokvo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 08-07-2012 11:09 PM |
| This is why the AS1 is on prius tyres!! | Slide | Scion FR-S / Toyota 86 GT86 General Forum | 73 | 01-17-2012 10:26 PM |
