Old 05-19-2014, 06:21 PM   #24963
jeffsides
AZ FRS 86
jeffsides's Avatar
Pretty sure this is the road. Name:  ImageUploadedByTapatalk1400534468.289273.jpg
Size:  223.5 KBName:  ImageUploadedByTapatalk1400534475.636266.jpg
Size:  274.8 KBName:  ImageUploadedByTapatalk1400534509.988660.jpg
Sent from ARIZONA86 HQ
@AZFRS86
Gusha0426 (05-19-2014)
Old 05-19-2014, 06:25 PM   #24964
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Thanks.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
jeffsides (05-19-2014)
Old 05-19-2014, 06:58 PM   #24965
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Ok, so when I was 19, I kept copius notes while racing the different cars I owned or drove. I found my old "Toe Notes" and it answered some of my set up thoughts differently, and is going to be used when I align my car tonight. Thought I'd share in case anyone else was interested.
Fine tuning toe settings will allow a measure of control that I'm often overlooking. It also has a significant effect on how a car behaves in a corner.
Front toe: settings make a big difference in how a car handles in the first third of the turn, the critical turn in phase where cornering force is initiated.
Rear toe: settings can be critical for helping a RWD car get on the gas on the exit of a corner harder and sooner.
The cool thing is that toe settings are probably one of the easiest alignment settings to do and all cars are toe adjustable with the exception of rear toe in cars with beam and solid rear axles like project porsche. This makes it so I can experiment with different toe settings and get a feel for how they affect chassis balance.
__________________________
TOE SETUP - FRONT TOE OUT
On a really high powered FWD car too much toe out can cause a lot of torque steer. Front toe out is a useful tool that can really help a car when used in moderation. Many cars and situations can be helped with a little toe out. Generaly front toe out speeds steering response and reduces understeer in the first quarter to third of a turn.
AWD cars like the EVO and Subie almost always benefit from front toe out as well. Nose heavy AWD cars with transverse engines derived from FWD cars can particularly benefit. (Like the evo)
*** TOO MUCH ***
Car twitchy under breaking
Unstable in straights
Car refusing to turn + 1/4"
Super Pushy & crown sensitive on road tracks
*** Just Right ***
EG2 and Subie have less push @ + 1/32" - + 1/8", Less is more.
Super responsive at + 1/16"
FRONT TOE in
MK1 & other mid-mounts seem to need Toe in. Spin happy at toe out.
Too much makes car sluggish & slow to turn & wanders under braking -- no " noticed
Just right feels like a street car in stability.
Tested on F/R porsche, and Toe in (Low ") is super helpful in creating balanced push/pull in turn.
REAR TOE OUT
Rear toe out has limited use. One of the times it sometimes works is on a FWD car being used for stock class in autocross. It can help the car rotate in tight low speed turns where it would normally get grinding understeer and you are not allowed to do anything else in the way of mods to fix the issue. Sometimes it can work surprisingly well.
*** It can make the car tricky as fuck to drive at high speeds so caution must be used. ***
Rear toe out is not a very useful setting, for me. It hurts in all testing except for helping rotation on a FWD car when you are completely out of tuning options or running Low bucks rally in dirt. We have only used this successfully for Stock Class Autocross and Rally in the EG2 & tC.
- Cars became super tail happy and were prone to violent rotations.
REAR TOE IN
Rear toe in is a useful setting that can make the car more stable under power application while turning. We can also be used to reduce trailing throttle oversteer or snap oversteer. Don't overdo it, too much rear toe can cause initial understeer and snap oversteer, making it super dangerous and unreliable in the dirt.
*+*+ LESS IS MORE +*+*
Could be used if I take up drifting.
Old 05-19-2014, 07:14 PM   #24966
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
The car went away today. They tell me it could take as long as 25 days for it to reach Honolulu, but could be less. So begins my month without a decent car Upside: the paperwork was surprisingly easy and it took about an hour of them inspecting the car and typing up crap before doing a walk around with them and then signing for the car and my box of stuff (floor mats, jumper cables, other spare stuff stored in trunk). Sad to see it go, but the next time I'll see it, we'll be in Hawaii!
The Following 2 Users Say Thank You to RedLeader For This Useful Post:
Cycotech (05-19-2014), nelsmar (05-19-2014)
Old 05-19-2014, 07:42 PM   #24967
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Is anyone here sporting ST coils other than kevin?
WDE
Old 05-19-2014, 07:53 PM   #24968
jeffsides
AZ FRS 86
jeffsides's Avatar
Took my little guy out to canyon lake today. Name:  ImageUploadedByTapatalk1400539971.146668.jpg
Size:  193.4 KBName:  ImageUploadedByTapatalk1400539981.525002.jpg
@AZFRS86
The Following 9 Users Say Thank You to jeffsides For This Useful Post:
Celadrielas (05-19-2014), Cross (05-20-2014), Cycotech (05-21-2014), FReSh_86 (05-19-2014), Gusha0426 (05-19-2014), jack43 (05-19-2014), MaddBaggins (05-19-2014), Shad0ez (05-20-2014), SpyderMS (05-19-2014)
Old 05-19-2014, 08:03 PM   #24969
Gusha0426
Gusha0426's Avatar
Drives: 2013 Pearl white FRS
Originally Posted by SirBrass View Post
Considering that it caused such a fuss, it would be nice to know where so that those of us who weren't there can be extra cautious in case someone calls the cops just b/c we were there.
It happened in a residential neighborhood which means no matter where your at you should obey the the speed limit in residential areas.
Sent from my SM-G900T using Tapatalk
Gusha0426 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gusha0426 For This Useful Post:
jeffsides (05-19-2014), SirBrass (05-19-2014)
Old 05-19-2014, 08:14 PM   #24970
B.Rice85
B.Rice85's Avatar
Drives: 2013 Subie BRZ 6MT
Is this really what its coming to people? Kinda sad really. Name:  uploadfromtaptalk1400541285174.jpg
Sent from my SAMSUNG-SGH-I747 using Tapatalk
B.Rice85 is offline   Reply With Quote
The Following 4 Users Say Thank You to B.Rice85 For This Useful Post:
Gusha0426 (05-19-2014), jeffsides (05-19-2014), SirBrass (05-19-2014), SpyderMS (05-19-2014)
Old 05-19-2014, 09:06 PM   #24971
jeffsides
AZ FRS 86
jeffsides's Avatar
Size:  213.9 KBName:  ImageUploadedByTapatalk1400544255.497315.jpg
Size:  236.0 KBName:  ImageUploadedByTapatalk1400544262.397747.jpg
Size:  207.0 KBName:  ImageUploadedByTapatalk1400544269.298478.jpg
Size:  91.1 KBName:  ImageUploadedByTapatalk1400544276.867497.jpg
Size:  199.9 KBName:  ImageUploadedByTapatalk1400544283.934468.jpg
Size:  190.1 KBName:  ImageUploadedByTapatalk1400544291.383518.jpg
Size:  143.0 KBName:  ImageUploadedByTapatalk1400544298.834305.jpg
Size:  175.6 KBName:  ImageUploadedByTapatalk1400544305.401412.jpg
Size:  113.3 KBName:  ImageUploadedByTapatalk1400544311.468599.jpg
Size:  88.0 KBName:  ImageUploadedByTapatalk1400544318.520829.jpg
Size:  225.4 KBName:  ImageUploadedByTapatalk1400544325.321462.jpg
Size:  219.8 KBName:  ImageUploadedByTapatalk1400544332.170334.jpg
Size:  152.9 KBName:  ImageUploadedByTapatalk1400544339.972799.jpg
Size:  94.8 KBName:  ImageUploadedByTapatalk1400544347.607266.jpg
Size:  198.7 KBName:  ImageUploadedByTapatalk1400544356.955975.jpg
Size:  154.7 KBName:  ImageUploadedByTapatalk1400544363.556439.jpg
Size:  152.9 KBName:  ImageUploadedByTapatalk1400544370.006983.jpg
Size:  100.7 KBName:  ImageUploadedByTapatalk1400544377.657728.jpg
Size:  181.1 KBName:  ImageUploadedByTapatalk1400544385.308002.jpg
@AZFRS86
The Following 5 Users Say Thank You to jeffsides For This Useful Post:
bignrichlll (05-19-2014), Celadrielas (05-19-2014), kavanagh (05-19-2014), MaddBaggins (05-19-2014), SpyderMS (05-19-2014)
Old 05-19-2014, 09:07 PM   #24972
jeffsides
AZ FRS 86
jeffsides's Avatar
Size:  193.4 KBName:  ImageUploadedByTapatalk1400544419.677976.jpg
Size:  130.8 KBName:  ImageUploadedByTapatalk1400544429.747048.jpg
Size:  217.6 KBName:  ImageUploadedByTapatalk1400544438.114425.jpg
Size:  176.9 KBName:  ImageUploadedByTapatalk1400544446.546731.jpg
@AZFRS86
The Following 4 Users Say Thank You to jeffsides For This Useful Post:
bignrichlll (05-19-2014), Celadrielas (05-19-2014), kavanagh (05-19-2014), SpyderMS (05-19-2014)
Old 05-19-2014, 09:45 PM   #24973
bignrichlll
Because Bacon
bignrichlll's Avatar
Originally Posted by Celadrielas View Post
Are you on springs and struts too or just ties and sways? I feel like a stiff strut, moderate spring, and ties would be solid with a smudge of push in the nose. I feel like it would be more sparing on the tires to take just a dip off the tail happiness of our platform
Sent from my SAMSUNG-SM-G900A using Tapatalk
Springs, ties, & sway. As much as I like it, I think theres a better setup to match front/rear leaving the apex. I like the toe write-up.
Like a BOSS!!
Old 05-19-2014, 09:49 PM   #24974
MaddBaggins
MaddBaggins's Avatar
Drives: Big guy in a little car...
Cool pics Jeff. What are you using to get those?
14 FRS - daily driver "Dory"
11 Rav4 - wifes ride "Ruby"
94 Landcruiser - camping/hunting rig "Tortuga"
MaddBaggins is offline   Reply With Quote
Old 05-19-2014, 10:03 PM   #24975
jeffsides
AZ FRS 86
jeffsides's Avatar
Most of them were my GoPro.
@AZFRS86
Old 05-19-2014, 10:12 PM   #24976
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Just got it back and I love it! Will have better pictures tomorrow
TwoFourFive is offline   Reply With Quote
The Following 6 Users Say Thank You to TwoFourFive For This Useful Post:
brenesk91 (05-19-2014), Celadrielas (05-19-2014), Gusha0426 (05-20-2014), MaddBaggins (05-19-2014), nelsmar (05-20-2014), NinjaRxMan (05-20-2014)
Search this Thread:
Advanced Search
