#29 |
Drives: anyone seen my steering wheel?
You could do something like a Gear Vendors overdrive unit... It's not the "perfect solution" as it requires 5,000 mile fluid changes and adds 32+#'s, and it's expensive, and one would have to be custom made for the application... but it would give you 22% higher overdrive.
#30 | |
Drives: '13 Ultramarine
#31 | |
Drives: JDM LN130 Toyota Hilux Surf
| The Following User Says Thank You to jehu For This Useful Post: | Wes B. (10-01-2012) |
#32 | |
Drives: SSM LT MT BRZ
You cannot change the ratio on a gear after it has been hobbed...and you do not turn gears, that is a term used for working a part on a lathe, and since the features on a gear are more than 2 dimensional, you cannot do the required work on simple machinery, you need a gear hobbing machine or a special grinder with gear blanks or a cnc grinder. That being said there are companies that do just this and it may be possible to get a quote for a small run of overdrive gears, but you would want to pre-sell most if not all of them and make sure the replacement process is fairly straight forward. Last edited by SkullWorks; 09-21-2012 at 01:49 PM. |
#33 |
actually races
Drives: Mazda3
No. Corvettes routinely can hit 26-30mpg with freeway cruising due to gearing, a decent coefficient of drag, and even the base 'Vettes now-a-days have 400 horsepower. Hell, my roommates 'Speed3 can easily do 35+mpg on the freeway, turbocharger + DI = efficient motor, and that is an Intake+Tune car making over "300" crank horsepower. On long roadtrips, we have maxxed the car out at 39.x MPG, and yes those are not trip computer guesses, but actual miles driven/gallons used calculated numbers.
![]() Yes, that's my car in the avatar. |
#34 |
actually races
Drives: Mazda3
This is smart man, right here. Warning, Generalization Ahead: It seems most Asian car companies in general cannot figure out gearing. Make 1-4 short, and well-spaced for good acceleration/fun, and make 5th and 6th a good bit taller for relaxed freeway jaunts. It seems most Asian manual cars are turning ~3000+rpm at freeway speed. Say it out loud folks, "overdriven gears are not the devil, they are goooood."
#35 | |
That said most manufacturers normally leave plenty of reserve capacity in the engine, so increasing the engine load (ie reducing RPMs) will normally have positive results in regards to fuel mileage. |
| Tags |
| aftermarket gear set, close ratio, dog engagement, quaife, trd |
| Straight from Japan: Motorfan 86 BRZ Magazine Sets! | ksin86 | Miscellaneous | 1 | 08-27-2020 04:18 PM |
| Bespoke radio, 3 sets of RCAs? | -max- | Electronics | Audio | NAV | Infotainment | 13 | 10-21-2017 07:09 PM |
| What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime | NeedsmoreCowbell | Scion FR-S / Toyota 86 GT86 General Forum | 67 | 03-28-2013 01:21 PM |
| Aftermarket Seats sets off SRS light? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-25-2012 06:09 PM |
